OK first try using all of the new tools to generate a small config with party mode 2. Config helper V3.0 allowed me to chose “spinmode” and “hold button lockup”, but when I got my initial error when compiling about it I saw that there’s text telling me to pick one. Fixed in the config helper and redownloaded the config.
Sounds not set up yet so I left in some placeholder names. I chose some interesting and somewhat random effects for each of the blades. Should I be able to see all of my selections in the blade description?
Otherwise I could rebuild it if its saved in the browser (which it is) , or I should take notes.
Not compiling.
Config:
// ProffieOS7 Config File
#define NUM_BLADES 2
#define VOLUME 1250
#define BOOT_VOLUME 80
#define CLASH_THRESHOLD_G 1
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define MOTION_TIMEOUT 60 * 1 * 1000
#define IDLE_OFF_TIME 60 * 1 * 1000
#define SAVE_PRESET
#define DISABLE_TALKIE
#define FETT263_USE_BC_MELT_STAB
{ "font0;common", "font0/tracks/track.wav",
https://fett263library.com/early-access/#CustomBlade
OS7.8 v1.01
Multi Phase (Special Abilities)
Default: Audio Rotoscope - Single Color (Original Trilogy)
1: Death Star Blast
Base Color: BaseColorArg (0)
Multi Phase Control: use Special Abilities controls to change Phase. Supports Alt Font.
*This style supports Alt Fonts alt000/ to alt009/. Uses altchng.wav on change
Special Ability 1: Next Phase
Special Ability 2: Previous Phase
Special Ability 3: Select Random Phase
Special Ability 4: Toggle Swing Change (Random / Party Mode)
Special Ability 5: Play Sound - Ignite Uses quote.wav #0
StylePtr<Layers<ColorSelect<AltF,TrInstant,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,1400>>,AudioFlicker<Stripes<10000,-2600,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Stripes<3500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,StaticFire<RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>,0,5,0,3000,5>,StripesX<Int<2000>,Int<0>,Rgb<255,0,255>,Rgb<128,128,128>>,Stripes<15000,-2400,Rgb<255,68,0>,Mix<Int<16000>,Black,Rgb<255,68,0>>,Stripes<6000,-1800,Rgb<255,68,0>,Mix<Int<12000>,Black,Rgb<255,68,0>>,Rgb<255,68,0>>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,Rgb<115,15,240>,Mix<Int<10280>,Black,Rgb<115,15,240>>,Rgb<115,15,240>,Mix<Int<2570>,Black,Rgb<115,15,240>>,Rgb<115,15,240>>,AudioFlicker<Rgb<100,100,150>,Mix<Int<24576>,Black,Rgb<100,100,150>>>,Remap<SmoothStep<Int<20000>,Int<42000>>,Stripes<2400,-1600,Rgb<180,130,0>,Mix<Int<4000>,Black,Rgb<180,130,0>>,Rgb<180,130,0>,Mix<Int<12000>,Black,Rgb<180,130,0>>>>,Stripes<5000,-1500,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>>>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<10>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<10>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<9>>>,Int<10>>,Int<-1>>,EFFECT_USER3>,TransitionPulseL<TrSelect<IncrementModuloF<EffectPulseF<EFFECT_USER4>,Int<2>>,TrInstant,TrDoEffectX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<9>>>,Int<10>>,Int<-1>>>,ThresholdPulseF<SwingSpeed<320>,Int<31000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<EffectPulseF<EFFECT_USER5>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrWipeX<BendTimePowX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrInstant>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<600>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeX<Int<300>>>,EFFECT_USER5>TransitionEffectL<TrDoEffectAlwaysX<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_QUOTE,Int<0>>,EFFECT_USER5>>>(),
OS7.8 v1.01
1: Death Star Blast
"YodaZone"
{ 0, WS281XBladePtr<125, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<14, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
/* Generated with Fett263 Config Helper v3.0 */
Error:
Arduino: 1.8.19 (Mac OS X), Board: "Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from /Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/ProffieOS.ino:614:
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:84: error: wrong number of template arguments (3, should be 4)
84 | StylePtr<Layers<ColorSelect<AltF,TrInstant,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,1400>>,AudioFlicker<Stripes<10000,-2600,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Stripes<3500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,StaticFire<RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>,0,5,0,3000,5>,StripesX<Int<2000>,Int<0>,Rgb<255,0,255>,Rgb<128,128,128>>,Stripes<15000,-2400,Rgb<255,68,0>,Mix<Int<16000>,Black,Rgb<255,68,0>>,Stripes<6000,-1800,Rgb<255,68,0>,Mix<Int<12000>,Black,Rgb<255,68,0>>,Rgb<255,68,0>>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,Rgb<115,15,240>,Mix<Int<10280>,Black,Rgb<115,15,240>>,Rgb<115,15,240>,Mix<Int<2570>,Black,Rgb<115,15,240>>,Rgb<115,15,240>>,AudioFlicker<Rgb<100,100,150>,Mix<Int<24576>,Black,Rgb<100,100,150>>>,Remap<SmoothStep<Int<20000>,Int<42000>>,Stripes<2400,-1600,Rgb<180,130,0>,Mix<Int<4000>,Black,Rgb<180,130,0>>,Rgb<180,130,0>,Mix<Int<12000>,Black,Rgb<180,130,0>>>>,Stripes<5000,-1500,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>>>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<10>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<10>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<9>>>,Int<10>>,Int<-1>>,EFFECT_USER3>,TransitionPulseL<TrSelect<IncrementModuloF<EffectPulseF<EFFECT_USER4>,Int<2>>,TrInstant,TrDoEffectX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<9>>>,Int<10>>,Int<-1>>>,ThresholdPulseF<SwingSpeed<320>,Int<31000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<EffectPulseF<EFFECT_USER5>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrWipeX<BendTimePowX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrInstant>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<600>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeX<Int<300>>>,EFFECT_USER5>TransitionEffectL<TrDoEffectAlwaysX<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_QUOTE,Int<0>>,EFFECT_USER5>>>(),
In file included from /Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/ProffieOS.ino:563:
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/transitions/doeffect.h:71:7: note: provided for 'template<class TRANSITION, EffectType EFFECT, class WAVNUM, class LOCATION> class TrDoEffectAlwaysX'
71 | class TrDoEffectAlwaysX : public TRANSITION {
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:84: error: template argument 1 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:84: error: two or more data types in declaration of 'type name'
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:84: error: template argument 14 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:84: error: no matching function for call to 'StylePtr<<expression error> >()'
In file included from /Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/styles/fire.h:4,
from /Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/ProffieOS.ino:462:
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/styles/style_ptr.h:100:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr()'
100 | StyleAllocator StylePtr() {
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/styles/style_ptr.h:100:16: note: template argument deduction/substitution failed:
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/styles/style_ptr.h:124:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr(const char*)'
124 | StyleAllocator StylePtr(const char* default_arguments) {
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/styles/style_ptr.h:124:16: note: template argument deduction/substitution failed:
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:117: error: wrong number of template arguments (3, should be 4)
117 | StylePtr<Layers<ColorSelect<AltF,TrInstant,StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<8000>,Int<3000>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<-2600>,Int<-3600>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,1400>>,AudioFlicker<Stripes<10000,-2600,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,255,255>>>,Stripes<3500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,StaticFire<RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>,0,5,0,3000,5>,StripesX<Int<2000>,Int<0>,Rgb<255,0,255>,Rgb<128,128,128>>,Stripes<15000,-2400,Rgb<255,68,0>,Mix<Int<16000>,Black,Rgb<255,68,0>>,Stripes<6000,-1800,Rgb<255,68,0>,Mix<Int<12000>,Black,Rgb<255,68,0>>,Rgb<255,68,0>>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,Rgb<115,15,240>,Mix<Int<10280>,Black,Rgb<115,15,240>>,Rgb<115,15,240>,Mix<Int<2570>,Black,Rgb<115,15,240>>,Rgb<115,15,240>>,AudioFlicker<Rgb<100,100,150>,Mix<Int<24576>,Black,Rgb<100,100,150>>>,Remap<SmoothStep<Int<20000>,Int<42000>>,Stripes<2400,-1600,Rgb<180,130,0>,Mix<Int<4000>,Black,Rgb<180,130,0>>,Rgb<180,130,0>,Mix<Int<12000>,Black,Rgb<180,130,0>>>>,Stripes<5000,-1500,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<80,50,210>>>>>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<10>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<10>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<9>>>,Int<10>>,Int<-1>>,EFFECT_USER3>,TransitionPulseL<TrSelect<IncrementModuloF<EffectPulseF<EFFECT_USER4>,Int<2>>,TrInstant,TrDoEffectX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Scale<RandomF,Int<1>,Int<9>>>,Int<10>>,Int<-1>>>,ThresholdPulseF<SwingSpeed<320>,Int<31000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<EffectPulseF<EFFECT_USER5>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrWipeX<BendTimePowX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrInstant>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<600>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeX<Int<300>>>,EFFECT_USER5>TransitionEffectL<TrDoEffectAlwaysX<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_QUOTE,Int<0>>,EFFECT_USER5>>>(),
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:117: error: template argument 1 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:117: error: two or more data types in declaration of 'type name'
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:117: error: template argument 14 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOS7.8/ProffieOS/config/LyleStyleOS78.h:117: error: no matching function for call to 'StylePtr<<expression error> >()'
