2 posts were split to a new topic: WebUSB problems
I have pushed an update with several new styles including the first batch of my Star Wars Visions based blade styles:
First off, thanks for all your work on this. Fernando.
I am getting some errors on config below. Included pastebin links to both config and errors. Any help is appreciated. Thanks!
Error link not available
Too big for pastebin, I guess. Removed the code to just show the line and the error message. Hope this is OK.
OK, fixed Unstable Flare, just refresh the page.
That fixed the issues with the main blade style. But my 2 accent blades still have issues. lines 355 and 374. They are identical. Their errors are listed in the pastebin link from earlier. If you need the newest set, though, let me know.
Need new error and new config or it’s a needle in a haystack
Fixed Fallen Order Cal Kestis style, had wrong code loaded.
Hmm, that’s going to take a little longer to fix. Looks like there’s a bug in the assembly script -might not be able to fix that until tomorrow.
Understood. Thanks for your time and expertise.
I think I figured it our, Rey TROS Spark Power Up is not compatible with Crystals or Accents because it’s tied to Emitter styles. I’ve removed from selection for those style types for now.
I refreshed, recopied the style from the library; this time without the Rey RTOS Spark Power Up and reuploaded. Unfortunately, I am still having issues. See errors and config below.
Same issue in Power Burst Emitter, those effects aren’t compatible with crystal or accent code. Removed from options list.
That did it. Thanks!!
Pushed an update to fix the “Intensity Lockup Up V1” for Side Blades, Crystals and Accents. Style code was missing a parameter so it would freeze the board.
If using this style be sure to refresh library and pull new style.
Library should say “v1.017” in lower right corner to represent this fix.
Awesome!! Now to play with the new styles ya put in.
Post this in OS6.5 is Live thread, this thread is for library beta testing.
Or maybe this thread?
