Here’s an updated Part Map for both sides of the V2.2 Proffieboard.
Pairs nicely with the BOM here:
Sheet1
Id,Designator,Package,Quantity,Designation,substitution notes,Supplier and ref
1,U60,XDFN4,1,NCP177,no substitutions,https://www.digikey.com/product-detail/en/on-semiconduct...
and this existing partial page of descriptions:
https://fredrik.hubbe.net/lightsaber/v5/partmap.html
Maybe @profezzorn will get a chance someday to add some more descriptions, maybe swap in this image, etc…
The partmap I have was originally designed to focus on parts around the edges, because those are most commonly messed up by users.
Here is a few more helpful descriptions of what things do:
U0 - main cpu, does everything
U2 - motion chip
U1 - amplifier
U3 - booster
L1 - booster coil
Q7 - dual pFET, used to control current to SD card and as reverse-current protection for most of the board. (Except for Q1-Q6)
Y1 - clock crystal (together with C7/C8)
RN4 - usb protection resistors
U40 - usb ESD protection diodes
RN3 - i2c pullup resistors
Great, thanks. Started a Wiki page because … why not?
So, I have heard mentions of a ProffieBoard v3.7… So, is that still in BETA/DEV? Will that specify the use of USB-C for data and / or charging? What other incredible advancements might it also entail? Does the move in the industry to SoC’s make a difference for ProffieBoard? Bluetooth as a standard part of the board? I am curious because, well I am curious… LOL.
It’s been sort of put on hiatus due to parts shortages. Beta boards were sent out and have been tested.
I figured as much, but my curiosity was aroused, and I am just excited for what a new version of ProffieBoard could mean for even more interesting sabers and other props.
For us grunts, the main thing is more storage space for flashing the config.
More information about the V3 board can be found here:
[image]
This board will be using a new CPU. The new CPU runs at the same speed and mostly the same as the old CPU, but it has a few important differences: More RAM, FLASH and pins.
Here is a list of improvements I’m making for Proffieboard V3:
More FLASH (512kB instead of 256kB): This means more presets, but it also means we can now turn on optimization without running of of memory
More RAM (160kB instead of 64kB): No immediate effect, but makes mp3 and echo effects possible
More PINS: New CPU is BGA with 64 pins instead of 48. This means more data pins, and and other things, listed below
Faster SD card access. The new board uses SDIO instead of SPI to access the SD card. SDIO is significantly faster than SPI. In initial testing I got 20 parallel streams. This means less problems with SD card and more CPU for doing other things.
USB charging: The V3 board has onboard charging configured for 450mA charge speed.
An onboard status LED helps show what the board is doing and when something goes wrong.
Three new “free” pads. These can either be used to drive 20mA LEDs directly, or as neopixel data pads, button pads or servos. The SWDIO, SWDCLK and RESET pads have been moved to the bottom of the board to make room for these new pads.
DM/DP/VBUS pads for external USB
spot for additional large capacitor if needed (helps when driving BT modules)
Two CPU pins are already tied together for Data1, making blade ID work without additional components
Power and AUX buttons are wakeup capable, unlocking the possibility of a deep sleep mode
Several other pins have been tied together as well, giving each pin more functions. This unlocks additional serial/SPI/I2S/I2C ports and analog pins. There are a LOT new possibilities for interfacing with other boards.
All of this in exactly the same size as a Proffieboard V2.
Right now, this board is in the prototyping stage. While most things have already been decided, if something doesn’t work out, there may still be changes.
After prototyping comes beta testing, (which will be by invitation only) Beta testing takes a while because people will need to install boards in sabers, try them out and make sure nothing catches on fire.
Once beta testing is over, we’ll move on to production. And after that I will release all the schematics, BOM and such things so that people can build their own if they wish.
@profezzorn . Sourcing alternates for main Q1-6 FETs.
Do both of these look acceptable as substitutes?
Links TO PARTS here:
Original: https://tinyurl.com/yc4ny2j9
Sub 1: https://tinyurl.com/yayh2y6y
Sub 2: https://tinyurl.com/yb6xftav
Those are screenshots. I’m not reading that.
Give me links to the parts instead.
Ah, those tinurls seems to be links to the parts.
Please don’t do that, it makes it impossible to know if they are links to the screenshots, parts or rickrolls.
DMT6008LFG-7 looks like a reasonable replacement for DMG7430LFG-7, AON6414A is not (too big)
DMP2065UFDB-7 and DMP2160UFDB-7 both look like reasonable replacements forDMP2075UFDB-7
Please beware that “looks like a reasonable replacement” isn’t a guarantee. They are likely to work fine, but it is entirely possible that I missed something important while reviewing the data sheets.
understood
FYI I found that Newark prices and availability are better than Digikey and Mouser.
LOL ESPECIALLY that rick rolling part.
