It all looks right, are you sure you uploaded this config? I see you commented out the default Party Mode preset above your modified one, is it possible you forgot to save the change before you uploaded? I would re-upload and check again, everything in the config and style code in pastebin should work as you intended but if you uploaded the version with the commented out preset instead, then it would work as you’re seeing now.
I’ll double check.
OK, it was user error. The configs I had open were for 7.10, and I was flashing 7.11.
Sorry for wasting your time.
No worries, glad you figured it out.
Here’s the list I just received and have verified it on my laptop. They’re on Chrome. I got it on Chrome and Safari.
Ok, so Seismic Charge is the constant. You don’t need to test multiple styles if it says “Missing Preon Style” and the trigger is Seismic Chrage, that’s all I need. I’ll have a look in the morning.
I found the issue with Seismic Charge preon, I’ll post a fix over the weekend, have to get Phase 2 prepped first.
Sounds good, thanks!
Question: Have the bladestyles such as ‘hyper responsive rotoscope’ changed since OS6? Are they implemented in a more efficient way that makes it worth redoing them?
I found a style bug when opening the colour picker at the edge of the window…
The Base effect is relatively unchanged but various Enhancements have been updated so it depends what effects you’re running in the style.
I’ll have a look when I get a chance.
Seismic Charge preon should be fixed now.
Awesome, thanks!
was this fixed?
It should be
Hey! I’m using the Survivor blade styles on my saber (running 7.11) with the rain mode special ability active. I have a sound I’d like to play for it, and I’ve tried two different naming systems (the first being trloop00.wav in the font folder, and the second being folders, trloop/000/000.wav). Both of them get the sound to play, but after I activate rain mode, the ability to turn it off usually doesn’t work. If I somehow can manage to turn it off, the blade stops the animation but the sound continues until I switch fonts. The file even keeps playing if I retract the blade. Am I doing anything wrong?
Use the link at the top of the library, this is a Phase 2 question
. Already handled in Phase 2 Q&A.
Ah, ok. Sorry about that. My access expired as I only needed a month of the library.
Currently, is there any way to have two completely separate styles when using altfont? As in each style could have separate ignitions, retractions, and force/swings. For example, the alt000 style could be a static with standard ignition, retraction, and unstable swing effects, but alt001 would use a blade with glitch on/off ignition/retraction and have a force ice blade effect. Are we there yet?
Yup, Multi-Phase. Although only some effects are set up for Multi-Phase in Phase 1, Phase 2 expanded to more.
If you build a Multi-Phase (Special Abilities) blade in the Blade Builder it will give you checkboxes for Ignition, Retraction and a few other effects to “Use Multi-Phase Effects” this will allow separate effects for each phase. I believe I covered in the videos at the top of the library which I recommend all users watch.
