Thank, I think it is a great idea.
The clock circuit is the place to avoid if possible. The crystal and the two capacitors next to it.
Most of the time itâs fine, but sometimes, putting things in contact with the clock circuit will make the chip half as fast, which makes for weird-sounding audio and other stuff.
I just place the rubber plunger thing on the middle at the CPU (v2.2). It doesnât exert that much pressure.
I hope you donât mind, I made a v2:
Edit: v2 deleted, v3 posted further down.
donât mind at all!
Did you look at the other side ? Did I put B(oot) & R(eset) in the correct spot ?
Looks good to me.
Can you fit a lego 2x8 flat through that window? (my preferred button pressing tool.)
From what I am seeing online, a flat brick is 5x15.8mm. My window is 3.5x10.5mm, so at the moment - no. But I could modify it. ![]()
I personally prefer the back of two flat wooden wooden skewers, the Lego keeps on slipping in uncontrollable ways. In fact I was already thinking of adding some plunger buttons for my v3.
I 3d printed a tuning fork like tool that I use, and I can ârockerâ it to do the reset combo, or use the other end to push a single button. I initially tried toothpicks but I was straining my eyes, even with magnification. This works greatâI just block out the gold colored area with my tool and press.
Happy to share the STL if anyone wants itâbut anyone could recreate it in 10 minutes in tinkercad.
If you share it, I 'll try it.
Letâs see if this works: ProffieResetTool.stl
Thank you, I like the design. I will change it a bit and make it way more complicated than it needs to be (I like round edges/arches on my 3D prints).
And cherry on the cake, it fits in âOrntarâs windowâ from his ProffiePusher.stl
After a few hours of playing around in Thinkercad, hereâs what I came up with:
ProffieResetTool_rouded.stl (1.3 MB)
The markings are for the sequence:
1 press Boot
2 press Reset
3 release Reset
4 release Boot
If you print it on a Bamboolab A1/A1mini, I recommend a 0.2 mm nozzle.
Here is the Proffie pusher v3, it can only fit one way and fits perfectly around the USB port:
ProffiePusher_corners_MT.USB.BWY_v3.1.stl (198.1 KB)
If you use transparent PETG, the Proffie on board light appears to shine much brighter.
Just throwing this out there, but wouldnât you want the reset leg to be slidable?
So inserting the tool makes the rigid boot button leg press the button, then sliding the reset pusher down clicks reset and releases it, then removing the tool releases boot.
Maybe it works like this (top view of slider)
or this
That seems like total overkill when you can just angle the tool to press one button at a time.
My question is why you need space between the âlegsâ ? why not just make one solid, wider tool?
Agreed, however I think this tool is inserted down through a hole above thatâs in a 3D printed cover/guide thing? Hence the mechanical adjustment I suggested.
Also I was just gettin jiggy wit it.
I love the idea, total engineering overkill. I know, I am weird.
I hope my printer can print that.
It is better than rocking because I can be sure the tool doesnât slip witch happens too often with the Lego 2x8 and with two âindependentâ legs you can get tactile feedback for each button press without having to worry/guess if it came from the other button.
