LGT preset configuration and how to combine that with the fett263 style library so that it doesn't FLASH overflow
Hey peeps,
so my old core that I fried, see proffibeoard is now replaced with a new core, and the features on this new core are sweet, it has illuminated pcb where as the older version didn’t it’s wired in parrallel so I don’t need a second preset for it and I love it.
however I’m trying to add the infinity gauntlet to the sound fonts and I’m getting a Flash Overwrite error and I was wondering should I use all fett263 presets or can I combine.
I recall that all edit mode saves the state but does that apply to the standard presets as well.
my config is as follows.
LGT1Button36v2.h (64.3 KB)
You’ve got a lot of older syntax styles. Mixing those with newer styles wastes memory in my experience. If you generate all styles in the library you’ll typically fit more (depending on complexity).
You can also use my Config Helper to set up Using Functions for Option Styles and Style Arguments to fit even more presets.
