is your config compiling correctly and uploading
im pretty sure it is? it lets me verify all the way until the end until it says that error message
paste your config, i will have a look at it for you
// This is a sample configuration file.
// This saber has:
// o Proffieboard V1 hardware.
// o Two buttons
// o An XP-E2 RGB LED star on LED 4-5-6
// o A neopixel blade on LED 1-2-3 and neopixel data 1.
// If you have a saber similar to this one, make a copy and use the copy.
// This is also the default configuration file. Pre-programmed boards will
// use this configuration file.
// CONFIG CREATED BY: SeanSoloSabers.com
#define VOLUME 1800
#define CLASH_THRESHOLD_G 2.0
#define FETT263_TWIST_ON
Preset presets = { //2022.7.25����Ϊ23����Ч
{ “Ani-Mation”, “tracks/BattleOfHeros.wav”, //1
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Blue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “Obi EP3”, “tracks/hellstyle.wav”,//2–
{ “Dmaul”, “tracks/hellstyle.wav”,//3–
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Red>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
{ “THE BEGGINER”, “tracks/Luke.wav”,//4–
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,DeepSkyBlue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<900>,Black>>>()
{ “L-Skywalker”, “tracks/hanszimmer.wav”,//5–
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Green>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
{ “Emperor”, “tracks/BattleOfHeros.wav”,//6–
{ “Angelic Plazma”, “tracks/Angelic Plazma.wav”, //7–
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<White,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,White,DeepSkyBlue>,Stripes<1500,-2500,White,DeepSkyBlue>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “DSR”, “tracks/Dark Path.wav”, //8–
StylePtr<Layers<Pulsing<Stripes<3000,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,Stripes<3000,3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,3000>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,White,RotateColorsX<Variation,Red>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{“ThePrize”, “tracks/The Highlander Theme.wav”,//9–
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<175,175,225>>,TrDelay<1000>,RotateColorsX<Variation,Rgb<175,175,225>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black>,White,RotateColorsX<Variation,Rgb<100,100,150>>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Red,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<Red,AudioFlicker<Red,Black>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Red,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,MultiTransitionEffectL<TrConcat<TrDelay<300>,RandomPerLEDFlickerL,TrDelay<1000>,RandomPerLEDFlickerL,TrFade<500>>,EFFECT_STAB>,AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>,
ResponsiveBlastWaveL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
ResponsiveBlastWaveL<Red,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<2400>>,Int<22000>,Int<40000>>,Int<22000>>>,
LockupTrL<AlphaL<BrownNoiseFlickerL<Red,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
InOutTrL<TrWipe<300>,TrWipeIn<500>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<100,100,150>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<100,100,150>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<100,100,150>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{“Sebulba”, “tracks/sebulba.wav”,//10–
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<30,0,66>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<48,0,105>>,RotateColorsX<Variation,Rgb<19,0,41>>,RotateColorsX<Variation,Rgb<95,0,210>>>,
AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,
EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,
Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,1018>,TrWipeInSparkTip<White,2017>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,
AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,
BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<95,0,210>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<95,0,210>>,
RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<95,0,210>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{“STARGATE”, “tracks/Stargate.wav”,//11–
StylePtr<Layers<
Layers<
TransitionLoop<RotateColorsX<Variation,Rgb<100,100,150>>,TrConcat<TrBoing<500,3>,Layers<
Stripes<10000,100,RotateColorsX<Variation,Rgb<50,50,75>>,RotateColorsX<Variation,Rgb<10,10,15>>,RotateColorsX<Variation,Rgb<78,78,118>>>,
AlphaL<Stripes<8000,-200,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<24,24,35>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,
TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrWipe<200>,AlphaL<White,Int<0>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>>>>>,
AlphaL<StrobeL<White,Int<20>,Int<1>>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<Black,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>>,TrConcat<TrInstant,Black,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Red>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
ResponsiveStabL,
ResponsiveBlastL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
InOutTrL<TrWipe<2000>,TrWipeIn<3000>>,
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<PulsingL<Red,Int<1000>>,Bump<Int<15000>,Int<10000>>>,TrFade<5000>,AlphaL<SparkleL<>,Bump<Int<15000>,Int<15000>>>,TrFade<3000>,StrobeL<White,Int<15>,Int<1>>,TrBoing<1000,1>>,EFFECT_PREON>>>()
{“(Heavy)”, “tracks/mando.wav”,//12–
StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,100>,
RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,RotateColorsX<Variation,Rgb<4,0,8>>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,
Rgb<30,0,66>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,
Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,
TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,2056>,TrConcat<TrWipe<200>,Mix<SmoothStep<Int<27500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<200>,Int<300>,Int<200>,Int<0>>,Mix<SmoothStep<Int<22000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<250>,Int<300>,Int<250>,Int<0>>,Mix<SmoothStep<Int<16500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<0>>,Mix<SmoothStep<Int<11000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<350>,Int<300>,Int<350>,Int<0>>,Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrInstant>,Black>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,
EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrDelay<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<3000>>>,TrFade<2000>,
AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<4000>>>,TrFade<2500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrBoing<1950,7>>,
EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<500>,Int<32768>>>,TrDelay<1500>,
TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,
Int<32768>>>,TrDelay<3000>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>>>()
{ “ElectricEssence”, “tracks/mars.wav”,//13–
StylePtr<Layers<
Layers<
AudioFlicker<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,60,200>>>,
TransitionLoopL<TrWaveX<HumpFlickerL<RotateColorsX<Variation,Cyan>,40>,Int<250>,Int<100>,Int<200>,Int<0>>>,
TransitionLoopL<TrWaveX<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,40>,Int<350>,Int<100>,Int<300>,Int<0>>>>,
TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrDelay<1000>,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>,SwingSpeed<600>>,
LockupTrL<White,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<300>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL,
SimpleClashL,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrFade<1200>>,EFFECT_IGNITION>,
InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,500>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,DeepSkyBlue>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Int<4000>,RotateColorsX<Variation,DeepSkyBlue>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{ “Jurassic”, “tracks/Jurassic Park.wav”,//14–
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>>,
LockupTrL<Layers<
AlphaL<Yellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Red>,Stripes<1500,-2500,White,Red>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Black,AudioFlicker<Black,Blue>,50,1>,TrConcat<TrInstant,AlphaL<Black,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
AlphaL<White,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,
ResponsiveStabL,
ResponsiveBlastL<Yellow,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
LockupTrL<AlphaL<BrownNoiseFlickerL<Green,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
InOutTrL<TrWipe<500>,TrWipeInSparkTip<White,500>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_PREON>>>()
{ “JUMPBIKE”, “tracks/Endor.wav”,//15–
StylePtr<Layers<
TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrDelay<30000>,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Green>,Stripes<1500,-2500,White,Green>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Blue,AudioFlicker<Blue,White>,50,1>,TrConcat<TrInstant,AlphaL<Blue,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Blue,Int<16000>>,30>,TrSmoothFade<600>>>,
ResponsiveStabL,
ResponsiveBlastL<OriginalBlastL<ResponsiveBlastWaveL>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL,TrFade<800>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL,TrFade<1500>>,EFFECT_RETRACTION>,
InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,1000>>,
TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
{ “UnHinged”, “tracks/mars.wav”,//16–
StylePtr<Layers<
StyleFire<Strobe<RotateColorsX<Variation,Rgb<95,0,210>>,Strobe<Rgb<100,100,150>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,50,1>,100,1>,RotateColorsX<Variation,Rgb<23,0,65>>,0,5,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,1000,5>>,
TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>>,TrDelay<1000>,AudioFlickerL<RotateColorsX<Variation,Yellow>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,White,RotateColorsX<Variation,Rgb<95,0,210>>,White>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<DeepPink,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Blue,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
ResponsiveStabL,
ResponsiveBlastWaveL<Yellow,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,800>>,
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Magenta,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Magenta,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<Magenta,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,0>>,EFFECT_PREON>>>()
{ “ULTRON”, “tracks/The Avengers.wav”,//17–
StylePtr<Layers<
StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,DarkOrange>,Black,100>,Strobe<Black,Blue,15,100>,RotateColorsX<Variation,Rgb<255,59,25>>,RotateColorsX<Variation,Rgb<128,34,0>>>,RotateColorsX<Variation,Rgb<80,11,0>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,
AlphaL<AudioFlickerL,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL,
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
{ “RgueCmdr”, “tracks/KyloRen.wav”,//18–
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<50,0,0>>,RotateColorsX<Variation,Red>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “SmthFuzz”, “tracks/mercury.wav”,//19–
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “SmthGrey”, “tracks/mercury.wav”,//20–
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “SmthJedi”, “tracks/uranus.wav”,//21–
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “TthCrstl”, “tracks/mars.wav”,//22–
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<RotateColorsX<Variation,Rgb<150,255,150>>,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ “TeenysSF”, “tracks/mercury.wav”,//23 —2022.7.25����
StylePtr<InOutHelper<EASYBLADE(OnSpark, WHITE), 300, 800> >()
{ "BOBAS1E5MANDO ", “tracks/mercury.wav”,//24 —2022.8.11���� ��ɫ
{ “FALLENORDERCALBUNDLE”, “tracks/uranus.wav”,//23 —2022.8.11���� ����
{“Decay”, “tracks/uranus.wav”, //23
StylePtr<Layers<
StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
//Bright purple absorb effect
//StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,0,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
//Alternate darker purple absorb effect, color change friendly (for reds and such)
AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,300>,SwingSpeed<400>>,
//Unstable swing
AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,Black,RotateColorsX<Variation,Rgb<95,0,210>>,Black>,SwingSpeed<500>>,
//Ripple down swing
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
//Bright hard swings
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>,StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,TrFade<1225>,RotateColorsX<Variation,Rgb<160,60,255>>,TrFade<250>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with reset
//Responsive lightning block
AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Sparking emitter flare
//AlphaL<RotateColorsX<Variation,Rgb16<45025,0,65535>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
//Alternate darker sparking emitter flare, color change friendly (for reds and such)
ResponsiveStabL,
//Responsive stab
ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<175,80,255>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1650>>,EFFECT_IGNITION>,
//Bright unstable ignition
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
//Bright HumpFlicker retraction
//Drag
//Responsive melt
//Power save, if using fett263’s prop file hold Aux and click PWR while ON (pointing up) to dim blade in 25% increments.
InOutTrL<TrWipeInSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
//Spark tip in ignition and retraction
//InOutTrL<TrWipeSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
//Alternate spark tip ignition and retraction
//On demand battery level, if using fett263’s prop file Hold AUX and click PWR while OFF, the battery level is represented by the location on the blade; tip = full, hilt = low and color; green = full, yellow = half, red = low
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrWipe<150>,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrBoing<350,2>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<9000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,Bump<Int<0>,Int<13000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<18000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<23000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,50>,Bump<Int<0>,Int<19000>>>,TrBoing<1950,9>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<400>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<115>,Int<375>,Int<115>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1750>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<450>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1450>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<4350>,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<5000>,Int<3000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<56306,0,65535>>,RotateColorsX<Variation,Rgb16<21919,0,22863>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<33124,0,65535>>,RotateColorsX<Int<2750>,RotateColorsX<Variation,Rgb16<33124,0,65535>>>>,RotateColorsX<Variation,Rgb16<42753,14386,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-5000>,Int<42500>>,Int<-4000>>>,TrDelay<7750>>,EFFECT_PREON>
//Life force drain preon
BladeConfig blades = {
{ 0, WS281XBladePtr<129, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
mate that config was fooked up big time, ive fixed it for but theres not a chance on gods green earth your gonna fit that blade style for “decay” on your board, ive added it in but its just a with simple blade style, if you want the decay blade style you need to delete some presents
// This saber has:
// o Two buttons
#define VOLUME 1800
Preset presets[] = { //2022.7.25Ôö¼ÓΪ23Ì×ÒôЧ
{ "Ani-Mation", "tracks/BattleOfHeros.wav", //1
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Blue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "Obi EP3", "tracks/hellstyle.wav",//2--
{ "Dmaul", "tracks/hellstyle.wav",//3--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Red>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
{ "THE BEGGINER", "tracks/Luke.wav",//4--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,DeepSkyBlue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<900>,Black>>>()
{ "L-Skywalker", "tracks/hanszimmer.wav",//5--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Green>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
{ "Emperor", "tracks/BattleOfHeros.wav",//6--
{ "Angelic Plazma", "tracks/Angelic Plazma.wav", //7--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<White,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,White,DeepSkyBlue>,Stripes<1500,-2500,White,DeepSkyBlue>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "DSR", "tracks/Dark Path.wav", //8--
StylePtr<Layers<Pulsing<Stripes<3000,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,Stripes<3000,3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,3000>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,White,RotateColorsX<Variation,Red>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{"ThePrize", "tracks/The Highlander Theme.wav",//9--
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<175,175,225>>,TrDelay<1000>,RotateColorsX<Variation,Rgb<175,175,225>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black>,White,RotateColorsX<Variation,Rgb<100,100,150>>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Red>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Red,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<Red,AudioFlicker<Red,Black>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Red,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,MultiTransitionEffectL<TrConcat<TrDelay<300>,RandomPerLEDFlickerL<Red>,TrDelay<1000>,RandomPerLEDFlickerL<Red>,TrFade<500>>,EFFECT_STAB>,AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>,
{"Sebulba", "tracks/sebulba.wav",//10--
AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,
{"STARGATE", "tracks/Stargate.wav",//11--
StylePtr<Layers<
Layers<
LockupTrL<Layers<
AlphaL<AudioFlickerL<Black>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
ResponsiveStabL<White>,
{"(Heavy)", "tracks/mando.wav",//12--
{ "ElectricEssence", "tracks/mars.wav",//13--
StylePtr<Layers<
Layers<
ResponsiveStabL<Red>,
{ "Jurassic", "tracks/Jurassic Park.wav",//14--
StylePtr<Layers<
LockupTrL<Layers<
AlphaL<AudioFlickerL<Yellow>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
ResponsiveStabL<Orange>,
{ "JUMPBIKE", "tracks/Endor.wav",//15--
StylePtr<Layers<
LockupTrL<Layers<
ResponsiveBlastL<OriginalBlastL<ResponsiveBlastWaveL<Red>>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1500>>,EFFECT_RETRACTION>,
{ "UnHinged", "tracks/mars.wav",//16--
StylePtr<Layers<
LockupTrL<Layers<
AlphaL<AudioFlickerL<HotPink>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
{ "ULTRON", "tracks/The Avengers.wav",//17--
StylePtr<Layers<
AlphaL<AudioFlickerL<White>,SwingSpeed<600>>,
LockupTrL<Layers<
{ "RgueCmdr", "tracks/KyloRen.wav",//18--
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<50,0,0>>,RotateColorsX<Variation,Red>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "SmthFuzz", "tracks/mercury.wav",//19--
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "SmthGrey", "tracks/mercury.wav",//20--
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "SmthJedi", "tracks/uranus.wav",//21--
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "TthCrstl", "tracks/mars.wav",//22--
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<RotateColorsX<Variation,Rgb<150,255,150>>,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "TeenysSF", "tracks/mercury.wav",//23 ---2022.7.25Ìí¼Ó
StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >()
{ "BOBAS1E5MANDO ", "tracks/mercury.wav",//24 ---2022.8.11Ìí¼Ó °×É«
StylePtr<InOutHelper<EASYBLADE(OnSpark<WHITE>, WHITE), 300, 800> >()
{ "FALLENORDERCALBUNDLE", "tracks/uranus.wav",//23 ---2022.8.11Ìí¼Ó ±ùÀ¶
StylePtr<InOutHelper<EASYBLADE(OnSpark<DeepSkyBlue>, WHITE), 300, 800> >()
{ "Decay", "tracks/mars.wav",//22--
copy this into your config and save it, it should now work
its still giving me the same error message, here ill copy the full message and send it
c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\evilr\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region SRAM2' not declared c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 16 bytes c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 16 bytes c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\evilr\AppData\Local\arduino\sketches\50F8F7DB91769AD1CD726DBB10EA20C3/ProffieOS.ino.elf section .text’ will not fit in region FLASH' c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 16 bytes c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 16 bytes c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 16 bytes c:/users/evilr/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: region FLASH’ overflowed by 4016 bytes
This is your problem.
Too large of a config file. Try these steps:
It defo works I’ve just done it on my computer it compiles at 96% are u sure your saving it
yeah im fully saving it, i even go into my config files after to make sure it saved properly. maybe my arduino is bugged?
Copy the code I sent, highlight everything in your config and replace it, then save
i just compiled it on ProffieOS 7.14 and got:
Sketch uses 261936 bytes (99%) of program storage space. Maximum is 262144 bytes.
Then I added:
#define KILL_OLD_PLAYERS
and got:
Sketch uses 243032 bytes (92%) of program storage space. Maximum is 262144 bytes.
Arduino settings:
Version 1.8.19
Proffieboard plugin = V3.6
USB Type = Serial
Optimize: Smallest Code
i got 96 with serial, webusb and mass storage, it defo works im not sure what hes goin wrong
You should remove screenshots. They are not allowed If the contents of what you are showing can be expressed as written text.
im using v2 proffie so this prolly wouldnt work
i never knew that. noted
Anakin_EP3_Proffie_2_Button.h (46.3 KB)
drop this into your config folder in proffieOS and click replace, make sure its named the same with NO copies attached (1)
I have an optimized version of Decay in my style library. It uses a fraction of memory
, just select from dropdown list and customize as needed. I have most of the Greyscale styles optimized so they csn easily fit.
https://fett263library.com/early-access/#Greyscale
Note, mixing older syntax styles like Greyscale originals with OS7 library styles also wastes a lot of memory inherently. My library is fully optimized if you generate all styles in the library you will typically fit many more presets.
You can further optimize your config with my config helper tool and Using functions, see here:
What do you mean?
If you’re referring to the plugin version, thata’s unrelated to the board version.
What plugin version are you using?
im using version 3.6, i thought you meant the board version
That’s a good shout, I don’t wanna do anything more to that config now tho to be honest
, he still needs to figure out how to upload it
