// This is a sample configuration file.
// This saber has:
// o Proffieboard V1 hardware.
// o Two buttons
// o An XP-E2 RGB LED star on LED 4-5-6
// o A neopixel blade on LED 1-2-3 and neopixel data 1.
// If you have a saber similar to this one, make a copy and use the copy.
// This is also the default configuration file. Pre-programmed boards will
// use this configuration file.
// CONFIG CREATED BY: SeanSoloSabers.com
#define VOLUME 1800
#define CLASH_THRESHOLD_G 2.0
#define FETT263_TWIST_ON
Preset presets[] = { //2022.7.25����Ϊ23����Ч
{ "Ani-Mation", "tracks/BattleOfHeros.wav", //1
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Blue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "Obi EP3", "tracks/hellstyle.wav",//2--
{ "Dmaul", "tracks/hellstyle.wav",//3--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Red>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
{ "THE BEGGINER", "tracks/Luke.wav",//4--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,DeepSkyBlue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<900>,Black>>>()
{ "L-Skywalker", "tracks/hanszimmer.wav",//5--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Green>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
{ "Emperor", "tracks/BattleOfHeros.wav",//6--
{ "Angelic Plazma", "tracks/Angelic Plazma.wav", //7--
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<White,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,White,DeepSkyBlue>,Stripes<1500,-2500,White,DeepSkyBlue>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "DSR", "tracks/Dark Path.wav", //8--
StylePtr<Layers<Pulsing<Stripes<3000,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,Stripes<3000,3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,3000>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,White,RotateColorsX<Variation,Red>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{"ThePrize", "tracks/The Highlander Theme.wav",//9--
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<175,175,225>>,TrDelay<1000>,RotateColorsX<Variation,Rgb<175,175,225>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black>,White,RotateColorsX<Variation,Rgb<100,100,150>>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Red>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Red,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<Red,AudioFlicker<Red,Black>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Red,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,MultiTransitionEffectL<TrConcat<TrDelay<300>,RandomPerLEDFlickerL<Red>,TrDelay<1000>,RandomPerLEDFlickerL<Red>,TrFade<500>>,EFFECT_STAB>,AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>,
ResponsiveBlastWaveL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
ResponsiveBlastWaveL<Red,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<2400>>,Int<22000>,Int<40000>>,Int<22000>>>,
LockupTrL<AlphaL<BrownNoiseFlickerL<Red,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
InOutTrL<TrWipe<300>,TrWipeIn<500>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<100,100,150>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<100,100,150>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<100,100,150>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{"Sebulba", "tracks/sebulba.wav",//10--
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<30,0,66>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<48,0,105>>,RotateColorsX<Variation,Rgb<19,0,41>>,RotateColorsX<Variation,Rgb<95,0,210>>>,
AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,
EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,
Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,1018>,TrWipeInSparkTip<White,2017>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,
AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,
BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<95,0,210>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<95,0,210>>,
RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<95,0,210>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{"STARGATE", "tracks/Stargate.wav",//11--
StylePtr<Layers<
Layers<
TransitionLoop<RotateColorsX<Variation,Rgb<100,100,150>>,TrConcat<TrBoing<500,3>,Layers<
Stripes<10000,100,RotateColorsX<Variation,Rgb<50,50,75>>,RotateColorsX<Variation,Rgb<10,10,15>>,RotateColorsX<Variation,Rgb<78,78,118>>>,
AlphaL<Stripes<8000,-200,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<24,24,35>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,
TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrWipe<200>,AlphaL<White,Int<0>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>>>>>,
AlphaL<StrobeL<White,Int<20>,Int<1>>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<Black>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<Black,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>>,TrConcat<TrInstant,Black,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Red>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
ResponsiveStabL<White>,
ResponsiveBlastL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
InOutTrL<TrWipe<2000>,TrWipeIn<3000>>,
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<PulsingL<Red,Int<1000>>,Bump<Int<15000>,Int<10000>>>,TrFade<5000>,AlphaL<SparkleL<>,Bump<Int<15000>,Int<15000>>>,TrFade<3000>,StrobeL<White,Int<15>,Int<1>>,TrBoing<1000,1>>,EFFECT_PREON>>>()
{"(Heavy)", "tracks/mando.wav",//12--
StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,100>,
RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,RotateColorsX<Variation,Rgb<4,0,8>>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,
Rgb<30,0,66>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,
Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,
TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,2056>,TrConcat<TrWipe<200>,Mix<SmoothStep<Int<27500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<200>,Int<300>,Int<200>,Int<0>>,Mix<SmoothStep<Int<22000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<250>,Int<300>,Int<250>,Int<0>>,Mix<SmoothStep<Int<16500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<0>>,Mix<SmoothStep<Int<11000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<350>,Int<300>,Int<350>,Int<0>>,Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrInstant>,Black>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,
EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrDelay<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<3000>>>,TrFade<2000>,
AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<4000>>>,TrFade<2500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrBoing<1950,7>>,
EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<500>,Int<32768>>>,TrDelay<1500>,
TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,
Int<32768>>>,TrDelay<3000>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>>>()
{ "ElectricEssence", "tracks/mars.wav",//13--
StylePtr<Layers<
Layers<
AudioFlicker<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,60,200>>>,
TransitionLoopL<TrWaveX<HumpFlickerL<RotateColorsX<Variation,Cyan>,40>,Int<250>,Int<100>,Int<200>,Int<0>>>,
TransitionLoopL<TrWaveX<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,40>,Int<350>,Int<100>,Int<300>,Int<0>>>>,
TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrDelay<1000>,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>,SwingSpeed<600>>,
LockupTrL<White,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<300>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL<Red>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrFade<1200>>,EFFECT_IGNITION>,
InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,500>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,DeepSkyBlue>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Int<4000>,RotateColorsX<Variation,DeepSkyBlue>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
{ "Jurassic", "tracks/Jurassic Park.wav",//14--
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<Yellow>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<Yellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Red>,Stripes<1500,-2500,White,Red>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Black,AudioFlicker<Black,Blue>,50,1>,TrConcat<TrInstant,AlphaL<Black,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
AlphaL<White,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,
ResponsiveStabL<Orange>,
ResponsiveBlastL<Yellow,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
LockupTrL<AlphaL<BrownNoiseFlickerL<Green,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
InOutTrL<TrWipe<500>,TrWipeInSparkTip<White,500>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_PREON>>>()
{ "JUMPBIKE", "tracks/Endor.wav",//15--
StylePtr<Layers<
TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrDelay<30000>,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Green>,Stripes<1500,-2500,White,Green>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Blue,AudioFlicker<Blue,White>,50,1>,TrConcat<TrInstant,AlphaL<Blue,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Blue,Int<16000>>,30>,TrSmoothFade<600>>>,
ResponsiveBlastL<OriginalBlastL<ResponsiveBlastWaveL<Red>>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1500>>,EFFECT_RETRACTION>,
InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,1000>>,
TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
{ "UnHinged", "tracks/mars.wav",//16--
StylePtr<Layers<
StyleFire<Strobe<RotateColorsX<Variation,Rgb<95,0,210>>,Strobe<Rgb<100,100,150>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,50,1>,100,1>,RotateColorsX<Variation,Rgb<23,0,65>>,0,5,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,1000,5>>,
TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>>,TrDelay<1000>,AudioFlickerL<RotateColorsX<Variation,Yellow>>,TrFade<800>>,EFFECT_FORCE>,
AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,White,RotateColorsX<Variation,Rgb<95,0,210>>,White>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<HotPink>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<DeepPink,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<Blue,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
ResponsiveBlastWaveL<Yellow,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,800>>,
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Magenta,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Magenta,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<Magenta,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,0>>,EFFECT_PREON>>>()
{ "ULTRON", "tracks/The Avengers.wav",//17--
StylePtr<Layers<
StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,DarkOrange>,Black,100>,Strobe<Black,Blue,15,100>,RotateColorsX<Variation,Rgb<255,59,25>>,RotateColorsX<Variation,Rgb<128,34,0>>>,RotateColorsX<Variation,Rgb<80,11,0>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,
AlphaL<AudioFlickerL<White>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
{ "RgueCmdr", "tracks/KyloRen.wav",//18--
StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<50,0,0>>,RotateColorsX<Variation,Red>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "SmthFuzz", "tracks/mercury.wav",//19--
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "SmthGrey", "tracks/mercury.wav",//20--
StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "SmthJedi", "tracks/uranus.wav",//21--
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "TthCrstl", "tracks/mars.wav",//22--
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<RotateColorsX<Variation,Rgb<150,255,150>>,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
{ "TeenysSF", "tracks/mercury.wav",//23 ---2022.7.25����
StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >()
{ "BOBAS1E5MANDO ", "tracks/mercury.wav",//24 ---2022.8.11���� ��ɫ
StylePtr<InOutHelper<EASYBLADE(OnSpark<WHITE>, WHITE), 300, 800> >()
{ "FALLENORDERCALBUNDLE", "tracks/uranus.wav",//24 ---2022.8.11���� ����
StylePtr<InOutHelper<EASYBLADE(OnSpark<DeepSkyBlue>, WHITE), 300, 800> >()
{ "Exalted", "tracks/sebula.wav",//25
StylePtr<Layers<
Mix<SwingSpeed<400>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,AudioFlicker<RotateColorsX<Variation,Rgb16<65535,8357,0>>,RotateColorsX<Variation,Rgb16<42307,1982,0>>>>,
AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,0,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<2000>,Int<3500>>,Int<-3000>>>,
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<65535,8357,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>>,TrFade<1200>>,EFFECT_IGNITION>,
InOutTrL<TrWipeSparkTip<White,250>,TrColorCycle<1450>,Black>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>()
{ 0, WS281XBladePtr<129, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
That’s a hell of a title, you don’t have a “major issue”, being new it can seem daunting but we’re here to help. In your case you’re just missing a comma.
This preset needs a comma at the end like so:
{ “FALLENORDERCALBUNDLE”, “tracks/uranus.wav”,//24 —2022.8.11���� ����
StylePtr<InOutHelper<EASYBLADE(OnSpark, WHITE), 300, 800> >()
You always need a comma between presets so if you add a preset to the end you need to add the comma to the previous last preset.
The rest looked fine but if another error pops up just post the updated config you uploaded (I recommend using pastebin.com, it makes it easier for us to read, especially on mobile devices) and you can post the full error message from Arduino, by using the Copy error message button and pasting here as well. ![]()
the comma worked so thank you so much! but new issue, im trying to add new fonts but its not working? i did the same process for the other font i added and made sure to add the comma at the end, the fonts im trying to download is made by the same exact person so none of the code should be too different. it doesnt say “font directory not found” or anything. it just isnt recognizing it at all.
all the results of flashing the board is perfect, its just that the new fonts i tried to add arent showing up in my saber, the config has them all there and arduino has no issues with the config so im kinda confused.
Ok, so here is the list of things that can cause that:
- it’s not actually upploading (but we already ruled that out)
- KEEP_SAVEFILES_WHEN_PROGRAMMING (but I don’t see that in your config posted above, so that shouldn’t be it either.)
- Arduino is using a different config file than you think it is. The way to test this is to intentionally put an error in your config file and press verify. If it compiles, then something fishy is going on. Of course, this is exactly what you did before, with the commas, so this really shouldn’t be the cause either.
- Something else.
The “something else” is a little harder to pin down, but we should be able to use serial monitor commands like “pwd” and “effects” to figure out what directories it’s actually using, and what files it’s actually finding there.
now i really dont know whats happening, ill paste my new code but all i did was add 1 new code from the same people that made my old code, but its still not recognizing the name.
1. // This is a sample configuration file.
2. // This saber has:
3. // o Proffieboard V1 hardware.
4. // o Two buttons
5. // o An XP-E2 RGB LED star on LED 4-5-6
6. // o A neopixel blade on LED 1-2-3 and neopixel data 1.
7. // If you have a saber similar to this one, make a copy and use the copy.
8. // This is also the default configuration file. Pre-programmed boards will
9. // use this configuration file.
10. // CONFIG CREATED BY: SeanSoloSabers.com
* #ifdef CONFIG_TOP
11. #include "proffieboard_v2_config.h"
12. #define NUM_BLADES 1
13. #define NUM_BUTTONS 2
14. #define VOLUME 1800
15. const unsigned int maxLedsPerStrip = 144;
16. #define CLASH_THRESHOLD_G 2.0
17. #define ENABLE_AUDIO
18. #define ENABLE_MOTION
19. #define FETT263_TWIST_ON
20. #define FETT263_TWIST_ON_NO_BM
21. #define FETT263_TWIST_OFF
22. #define MOTION_TIMEOUT 60 * 5 * 1000
23. #define ENABLE_WS2811
24. #define ENABLE_SD
25. #endif
* #ifdef CONFIG_PROP
26. #include "../props/saber_fett263_buttons.h"
27. #endif
* #ifdef CONFIG_PRESETS
28. Preset presets[] = { //2022.7.25����Ϊ23����Ч
* { "Ani-Mation", "tracks/BattleOfHeros.wav", //1
29. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Blue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
30. },
* { "Obi EP3", "tracks/hellstyle.wav",//2--
31. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Blue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
32. },
* { "Dmaul", "tracks/hellstyle.wav",//3--
33. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Red>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
34. },
* { "THE BEGGINER", "tracks/Luke.wav",//4--
35. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,DeepSkyBlue>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<900>,Black>>>()
36. },
* { "L-Skywalker", "tracks/hanszimmer.wav",//5--
37. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Green>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
38. },
* { "Emperor", "tracks/BattleOfHeros.wav",//6--
39. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,AlphaL<AudioFlickerL<RotateColorsX<Variation,Red>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<450>,TrWipeIn<500>,Black>>>()
40. },
* { "Angelic Plazma", "tracks/Angelic Plazma.wav", //7--
41. StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,AlphaL<White,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<1000>>,Stripes<1500,2000,White,DeepSkyBlue>,Stripes<1500,-2500,White,DeepSkyBlue>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
42. },
* { "DSR", "tracks/Dark Path.wav", //8--
43. StylePtr<Layers<Pulsing<Stripes<3000,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,Stripes<3000,3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<255,50,50>>,RotateColorsX<Variation,Rgb<128,0,0>>>,3000>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,White,RotateColorsX<Variation,Red>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
44. },
* {"ThePrize", "tracks/The Highlander Theme.wav",//9--
* StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<175,175,225>>,TrDelay<1000>,RotateColorsX<Variation,Rgb<175,175,225>>,TrFade<800>>,EFFECT_FORCE>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black>,White,RotateColorsX<Variation,Rgb<100,100,150>>,White>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Red>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Red,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<Red,AudioFlicker<Red,Black>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Red,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,MultiTransitionEffectL<TrConcat<TrDelay<300>,RandomPerLEDFlickerL<Red>,TrDelay<1000>,RandomPerLEDFlickerL<Red>,TrFade<500>>,EFFECT_STAB>,AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>,
45. ResponsiveBlastWaveL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
46. ResponsiveBlastWaveL<Red,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
47. AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<2400>>,Int<22000>,Int<40000>>,Int<22000>>>,
48. LockupTrL<AlphaL<BrownNoiseFlickerL<Red,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
49. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
50. InOutTrL<TrWipe<300>,TrWipeIn<500>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<100,100,150>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<100,100,150>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<100,100,150>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
51. },
* {"Sebulba", "tracks/sebulba.wav",//10--
* StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<30,0,66>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<48,0,105>>,RotateColorsX<Variation,Rgb<19,0,41>>,RotateColorsX<Variation,Rgb<95,0,210>>>,
52. AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,
53. Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
54. AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
55. ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
56. AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,
57. ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,
58. EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,
59. Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,1018>,TrWipeInSparkTip<White,2017>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,
60. AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,
61. BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<95,0,210>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb<95,0,210>>,
62. RotateColorsX<Int<4000>,RotateColorsX<Variation,Rgb<95,0,210>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
63. },
* {"STARGATE", "tracks/Stargate.wav",//11--
* StylePtr<Layers<
64. Layers<
65. TransitionLoop<RotateColorsX<Variation,Rgb<100,100,150>>,TrConcat<TrBoing<500,3>,Layers<
66. Stripes<10000,100,RotateColorsX<Variation,Rgb<50,50,75>>,RotateColorsX<Variation,Rgb<10,10,15>>,RotateColorsX<Variation,Rgb<78,78,118>>>,
67. AlphaL<Stripes<8000,-200,RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<24,24,35>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,
68. TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrWipe<200>,AlphaL<White,Int<0>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>>>>>,
69. AlphaL<StrobeL<White,Int<20>,Int<1>>,SwingSpeed<600>>,
70. LockupTrL<Layers<
71. AlphaL<AudioFlickerL<Black>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
72. AlphaL<Black,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>>,TrConcat<TrInstant,Black,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
73. ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Red>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
74. ResponsiveStabL<White>,
75. ResponsiveBlastL<Red,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
76. ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
77. TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,
78. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
79. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
80. InOutTrL<TrWipe<2000>,TrWipeIn<3000>>,
81. TransitionEffectL<TrConcat<TrFade<100>,AlphaL<PulsingL<Red,Int<1000>>,Bump<Int<15000>,Int<10000>>>,TrFade<5000>,AlphaL<SparkleL<>,Bump<Int<15000>,Int<15000>>>,TrFade<3000>,StrobeL<White,Int<15>,Int<1>>,TrBoing<1000,1>>,EFFECT_PREON>>>()
82. },
* {"(Heavy)", "tracks/mando.wav",//12--
* StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,100>,
83. RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<21,0,52>>,RotateColorsX<Variation,Rgb<4,0,8>>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<42,0,105>>>,RotateColorsX<Variation,
84. Rgb<30,0,66>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,AlphaL<Stripes<2500,-3000,Red,Rgb<60,0,0>,Pulsing<Rgb<30,0,0>,Black,800>>,
85. SwingSpeed<600>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
86. AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,
87. TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,
88. TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,
89. Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,
90. SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,
91. TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTip<White,2056>,TrConcat<TrWipe<200>,Mix<SmoothStep<Int<27500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
92. TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<200>,Int<300>,Int<200>,Int<0>>,Mix<SmoothStep<Int<22000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
93. TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<250>,Int<300>,Int<250>,Int<0>>,Mix<SmoothStep<Int<16500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
94. TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<0>>,Mix<SmoothStep<Int<11000>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
95. TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<350>,Int<300>,Int<350>,Int<0>>,Mix<SmoothStep<Int<5500>,Int<-2000>>,Black,RotateColorsX<Variation,Rgb<95,0,210>>>,
96. TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<400>,Int<300>,Int<400>,Int<0>>,Black,TrInstant>,Black>,
97. TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,
98. EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrDelay<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<3000>>>,TrFade<2000>,
99. AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<4000>>>,TrFade<2500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrBoing<1950,7>>,
100. EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<500>,Int<32768>>>,TrDelay<1500>,
101. TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,
102. Int<32768>>>,TrDelay<3000>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>>>()
103. },
* { "ElectricEssence", "tracks/mars.wav",//13--
* StylePtr<Layers<
104. Layers<
105. AudioFlicker<RotateColorsX<Variation,Rgb<0,40,128>>,RotateColorsX<Variation,Rgb<0,60,200>>>,
106. TransitionLoopL<TrWaveX<HumpFlickerL<RotateColorsX<Variation,Cyan>,40>,Int<250>,Int<100>,Int<200>,Int<0>>>,
107. TransitionLoopL<TrWaveX<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,40>,Int<350>,Int<100>,Int<300>,Int<0>>>>,
108. TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrDelay<1000>,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrFade<800>>,EFFECT_FORCE>,
109. AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>,SwingSpeed<600>>,
110. LockupTrL<White,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<300>>,SaberBase::LOCKUP_NORMAL>,
111. ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
112. ResponsiveStabL<Red>,
113. ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
114. SimpleClashL<White>,
115. TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<90,180,255>>>,TrFade<1200>>,EFFECT_IGNITION>,
116. AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<2400>>,Int<22000>,Int<40000>>,Int<22000>>>,
117. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
118. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
119. InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,500>>,
120. TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,DeepSkyBlue>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Int<4000>,RotateColorsX<Variation,DeepSkyBlue>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<6000>>,EFFECT_PREON>>>()
121. },
* { "Jurassic", "tracks/Jurassic Park.wav",//14--
* StylePtr<Layers<
122. AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>>,
123. AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,White,RotateColorsX<Variation,Red>,White>,SwingSpeed<600>>,
124. LockupTrL<Layers<
125. AlphaL<AudioFlickerL<Yellow>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
126. AlphaL<Yellow,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Red>,Stripes<1500,-2500,White,Red>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
127. ResponsiveLightningBlockL<Strobe<Black,AudioFlicker<Black,Blue>,50,1>,TrConcat<TrInstant,AlphaL<Black,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
128. AlphaL<White,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,
129. ResponsiveStabL<Orange>,
130. ResponsiveBlastL<Yellow,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
131. ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
132. TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,
133. LockupTrL<AlphaL<BrownNoiseFlickerL<Green,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
134. LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
135. InOutTrL<TrWipe<500>,TrWipeInSparkTip<White,500>>,
136. TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_PREON>>>()
137. },
* { "JUMPBIKE", "tracks/Endor.wav",//15--
* StylePtr<Layers<
138. AudioFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,
139. TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrDelay<30000>,AudioFlickerL<RotateColorsX<Variation,Rgb<150,255,150>>>,TrFade<800>>,EFFECT_FORCE>,
140. AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,60,0>>,Pulsing<RotateColorsX<Variation,Rgb<0,30,0>>,Black,800>>,SwingSpeed<600>>,
141. LockupTrL<Layers<
142. AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
143. AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Green>,Stripes<1500,-2500,White,Green>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
144. ResponsiveLightningBlockL<Strobe<Blue,AudioFlicker<Blue,White>,50,1>,TrConcat<TrInstant,AlphaL<Blue,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<Blue,Int<16000>>,30>,TrSmoothFade<600>>>,
145. AlphaL<White,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,
146. ResponsiveStabL<Red>,
147. ResponsiveBlastL<OriginalBlastL<ResponsiveBlastWaveL<Red>>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
148. ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,
149. TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,
150. TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<1500>>,EFFECT_RETRACTION>,
151. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
152. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
153. InOutTrL<TrWipe<300>,TrWipeInSparkTip<White,1000>>,
154. TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
155. },
* { "UnHinged", "tracks/mars.wav",//16--
* StylePtr<Layers<
156. StyleFire<Strobe<RotateColorsX<Variation,Rgb<95,0,210>>,Strobe<Rgb<100,100,150>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,50,1>,100,1>,RotateColorsX<Variation,Rgb<23,0,65>>,0,5,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,1000,5>,FireConfig<2,1000,5>>,
157. TransitionEffectL<TrConcat<TrFade<400>,AudioFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>>,TrDelay<1000>,AudioFlickerL<RotateColorsX<Variation,Yellow>>,TrFade<800>>,EFFECT_FORCE>,
158. AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,White,RotateColorsX<Variation,Rgb<95,0,210>>,White>,SwingSpeed<600>>,
159. LockupTrL<Layers<
160. AlphaL<AudioFlickerL<HotPink>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
161. AlphaL<DeepPink,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
162. ResponsiveLightningBlockL<Strobe<Blue,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
163. AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<1600>>,Int<1000>,Int<4000>>,Int<-4000>>>,
164. ResponsiveStabL<Red>,
165. ResponsiveBlastL<Yellow,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
166. ResponsiveBlastWaveL<Yellow,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
167. AlphaL<Black,SmoothStep<Scale<SlowNoise<Int<2400>>,Int<22000>,Int<40000>>,Int<22000>>>,
168. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
169. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
170. InOutTrL<TrWipeSparkTip<White,300>,TrWipeInSparkTip<White,800>>,
171. TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Magenta,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Magenta,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<Magenta,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,0>>,EFFECT_PREON>>>()
172. },
* { "ULTRON", "tracks/The Avengers.wav",//17--
* StylePtr<Layers<
173. StyleFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RotateColorsX<Variation,DarkOrange>,Black,100>,Strobe<Black,Blue,15,100>,RotateColorsX<Variation,Rgb<255,59,25>>,RotateColorsX<Variation,Rgb<128,34,0>>>,RotateColorsX<Variation,Rgb<80,11,0>>,0,5,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>,FireConfig<3,3000,0>>,
174. AlphaL<AudioFlickerL<White>,SwingSpeed<600>>,
175. LockupTrL<Layers<
176. AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
177. AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrJoinR<TrWipe<100>,TrWipeIn<100>>>,SaberBase::LOCKUP_NORMAL>,
178. ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
179. ResponsiveStabL<Red>,
180. ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
181. ResponsiveBlastWaveL<White,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,EFFECT_CLASH>,
182. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
183. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
184. InOutTrL<TrWipe<300>,TrWipeIn<500>>,
185. TransitionEffectL<TrConcat<TrFade<100>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<4000>>>,TrFade<100>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<5000>>>,TrFade<100>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()
186. },
* { "RgueCmdr", "tracks/KyloRen.wav",//18--
187. StylePtr<Layers<Stripes<10000,-1700,RotateColorsX<Variation,Rgb<80,0,0>>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<50,0,0>>,RotateColorsX<Variation,Red>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
188. },
* { "SmthFuzz", "tracks/mercury.wav",//19--
189. StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
190. },
* { "SmthGrey", "tracks/mercury.wav",//20--
191. StylePtr<Layers<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,Black,20>,RotateColorsX<Variation,Rgb<4,4,6>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<115,115,170>>,70>,RotateColorsX<Variation,Rgb<50,50,75>>>,RotateColorsX<Variation,Rgb<31,31,47>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
192. },
* { "SmthJedi", "tracks/uranus.wav",//21--
193. StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<Black,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
194. },
* { "TthCrstl", "tracks/mars.wav",//22--
195. StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,AlphaL<StrobeL<RotateColorsX<Variation,Rgb<150,255,150>>,Int<20>,Int<1>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,SimpleClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
196. },
* { "TeenysSF", "tracks/mercury.wav",//23 ---2022.7.25����
197. StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >()
198. },
* { "BOBAS1E5MANDO ", "tracks/mercury.wav",//24 ---2022.8.11���� ��ɫ
199. StylePtr<InOutHelper<EASYBLADE(OnSpark<WHITE>, WHITE), 300, 800> >()
200. },
* { "FALLENORDERCALBUNDLE", "tracks/uranus.wav",//24 ---2022.8.11���� ����
201. StylePtr<InOutHelper<EASYBLADE(OnSpark<DeepSkyBlue>, WHITE), 300, 800> >()
202. },
* { "Exalted", "tracks/sebulba.wav",//25--
* StylePtr<Layers<
203. Mix<SwingSpeed<400>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,AudioFlicker<RotateColorsX<Variation,Rgb16<65535,8357,0>>,RotateColorsX<Variation,Rgb16<42307,1982,0>>>>,
204. AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<60,0,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,0,0>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
205. LockupTrL<Layers<
206. AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
207. AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
208. ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
209. AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<2000>,Int<3500>>,Int<-3000>>>,
210. ResponsiveStabL<Orange>,
211. EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
212. ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
213. TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb16<65535,8357,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Rgb<60,0,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>>,TrFade<1200>>,EFFECT_IGNITION>,
214. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
215. LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
216. EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<8192>>,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<24576>>,AlphaL<Black,Int<0>>>,
217. InOutTrL<TrWipeSparkTip<White,250>,TrColorCycle<1450>,Black>,
218. TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>()
219. },
* { "Decay", "tracks/sebulba.wav",//29--
* StylePtr<Layers<
220. StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
221. AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,300>,SwingSpeed<400>>,
222. AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,Black,RotateColorsX<Variation,Rgb<95,0,210>>,Black>,SwingSpeed<500>>,
223. AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
224. LockupTrL<Layers<
225. AlphaL<AudioFlickerL<Azure>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
226. AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>,StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,TrFade<1225>,RotateColorsX<Variation,Rgb<160,60,255>>,TrFade<250>>,SaberBase::LOCKUP_NORMAL>,
227. ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
228. AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
229. ResponsiveStabL<Red>,
230. EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
231. ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
232. TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<175,80,255>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1650>>,EFFECT_IGNITION>,
233. TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
234. LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
235. LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
236. EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<8192>>,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<24576>>,AlphaL<Black,Int<0>>>,
237. InOutTrL<TrWipeInSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
238. TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,
239. TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrWipe<150>,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrBoing<350,2>>,EFFECT_PREON>,
240. TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<9000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,Bump<Int<0>,Int<13000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<18000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<23000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,50>,Bump<Int<0>,Int<19000>>>,TrBoing<1950,9>>,EFFECT_PREON>,
241. TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<400>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<115>,Int<375>,Int<115>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1750>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<450>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1450>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>,
242. TransitionEffectL<TrConcat<TrDelay<4350>,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<5000>,Int<3000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<56306,0,65535>>,RotateColorsX<Variation,Rgb16<21919,0,22863>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<33124,0,65535>>,RotateColorsX<Int<2750>,RotateColorsX<Variation,Rgb16<33124,0,65535>>>>,RotateColorsX<Variation,Rgb16<42753,14386,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-5000>,Int<42500>>,Int<-4000>>>,TrDelay<7750>>,EFFECT_PREON>>>()
243. },
244. BladeConfig blades[] = {
245. { 0, WS281XBladePtr<129, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
246. };
247. #endif
* #ifdef CONFIG_BUTTONS
248. Button PowerButton(BUTTON_POWER, powerButtonPin, "pow");
249. Button AuxButton(BUTTON_AUX, auxPin, "aux");
250. #endif
What exactly do you mean by this.
What happens when you try to go to the new preset?
Which preset is new?
Do you have a font for this preset on the SD card?
What does the serial monitor say when you try to go to the new preset?
The new code is “Decay”. It doesnt say anything, its kinda acting like the code isnt there at all. I have all the soundfonts in my sd card with the right names and everything
Scratch what i just replied, for some reason the blade fonts are fully on there but the soundfonts are not. I go to my new fonts and it makes 1 “beep” and then when i turn it on theres no sound. Im also having a new issue where when i hold the aux button instead of going into volume mode it rapidly switches between fonts.
The beep would indicate that it cannot find the “font.wav” for that font.
I can think of three possible reasons for this:
- The directory containing the sound font on your SD card isn’t called
Decay. - The Decay directory has all the sound files in some subdirectory. (Maybe it has sub-directories called
Proffie,CFXandGHfor instance?) - The font upload was interrupted before it was finished, causing SD card corruption. (This happens if you drag the font to the SD card and then hit upload in arduino before the files are done copying.) The proffieboard “mass storage” is pretty slow, and uploading a font usually takes a couple of minutes.
The way to check these things is to use the serial monitor.
You can use pwd to see what directory it is looking for.
You can use dir to list the contents of a directory, as seen by ProffieOS.
You can use effects to see what files ProffieOS has found when it scanned the directory.
So i was doing a lot of pc stuff for a bit and ended up reinstalling windows. But now that i reinstalled everything and redid proffie im getting this same issue again. The name is the exact same so im really not sure why its not working.
is your config file saved in the config folder within the proffoe OS folder
yes, in the screenshot in this reply you can see the tabs, im honestly confused why this is happening.
yes, im opening arduino from the proffie folder and its all extracted
how dont they match up?
one say (1)copy 1 and one says (2) copy 2
your config is stored in copy 2, open arduino from copy 2
ohhhhhhhhhhhhhhh i deleted the copies and that seemed to have worked
so i have tried moding my saber before and it worked kinda well but this error message is new, i am getting “collect2.exe: error: ld returned 1 exit status” before that is a bunch of error messages but the guy im watching said that its nothing is wrong with it if i get that error message its super common
