Fett263 ProffieOS6 Style Library
Battery Level button/styles work when blade is off only to match my prop. Press Power, then click BatteryLevel button
Hi Fett263,
ok so I enabled the postoff effect and the battery level effect, clicked the battery level and nothing happened.
Post the style code generated by the library and I’ll have a look tomorrow to see if there’s something not working right.
I haven’t tested it on the saber, it’s the library button.
I know, click Get Style Code for the style you built and post, it will give me the info I need to troubleshoot the library.
so I had compiled,
Arduino: 1.8.19 (Linux), Board: "Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from /home/maxb/Documents/ProffieOS/ProffieOS.ino:563:
/home/maxb/Documents/ProffieOS/config/Proffiev6_7v2.h:145: error: template argument 4 is invalid
  145 | StylePtr<Layers<Layers<StripesX<Int<6000>,Scale<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<100>,Int<500>>,Scale<SwingAcceleration<>,Int<8000>,Int<4000>>>,Int<-1200>,Int<-3000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<24000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<18000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,TransitionEffectL<TrSelect<Scale<TwistAngle<>,Int<0>,Int<3>>,TrConcat<TrJoin<TrDelay<1500>,TrWipe<200>>,Stripes<6000,-3000,Rgb<118,0,194>,Mix<Int<10000>,Black,Rgb<118,0,194>>,Mix<Int<20000>,Black,Rgb<118,0,194>>>,TrWipe<200>>,TrSparkX<RandomFlicker<Red,RandomPerLEDFlicker<Red,Mix<Int<12000>,Black,Red>>>,Int<50>,Int<400>,Int<0>>,TrConcat<TrJoin<TrDelay<600>,TrSparkX<Pulsing<Mix<Int<16000>,Black,DarkOrange>,DarkOrange,600>,Int<100>,Int<200>,Int<0>>>,AlphaL<DarkOrange,Int<0>>,TrJoin<TrDelay<1500>,TrJoinR<TrWipeIn<300>,TrFade<300>>>,Stripes<10000,300,Mix<Int<16000>,Black,DarkOrange>,DarkOrange,Mix<Int<12000>,Black,DarkOrange>>,TrJoinR<TrWipeIn<600>,TrFade<600>>>>,EFFECT_BLAST>,AlphaL<ColorSelect<Scale<TwistAngle<>,Int<0>,Int<3>>,TrInstant,Pulsing<Rgb<118,0,194>,Rgb<59,0,97>,2000>,Pulsing<Red,Rgb<128,0,0>,2000>,Pulsing<DarkOrange,Rgb<128,17,0>,2000>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-1000>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<1000>,TrWipe<200>>,Stripes<8000,-600,BrownNoiseFlicker<Rgb<180,130,0>,Mix<Int<8000>,Black,Rgb<180,130,0>>,100>,BrownNoiseFlicker<Rgb<180,130,0>,Mix<Int<12000>,Black,Rgb<180,130,0>>,20>>,TrJoin<TrDelay<1000>,TrWipe<200>>,AlphaL<Pulsing<Rgb<180,130,0>,Mix<Int<16000>,Black,Rgb<180,130,0>>,600>,LayerFunctions<SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-1000>>,SmoothStep<Int<30000>,Int<1000>>>>,TrFade<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrCenterWipeIn<200>>,Mix<LinearSectionF<Int<16384>,Int<2000>>,Remap<CenterDistF<>,Stripes<4000,1200,Mix<Int<8000>,Black,Blue>,Blue>>,AudioFlicker<White,Black>,Black>,TrCenterWipeIn<200>>,EFFECT_FORCE>,LockupTrL<StripesX<Int<12000>,Scale<TwistAngle<1>,Int<-1000>,Int<1000>>,Green,Mix<Int<18000>,Black,Green>,Mix<Int<10000>,Black,Green>>,TrConcat<TrJoin<TrDelay<1000>,TrWipe<400>>,Stripes<12000,-600,Green,Mix<Int<18000>,Black,Green>,Mix<Int<10000>,Black,Green>>,TrFade<400>,Green,TrJoin<TrDelay<1500>,TrFade<400>>,Stripes<12000,1000,Green,Mix<Int<18000>,Black,Green>,Mix<Int<10000>,Black,Green>>,TrFade<400>>,TrFade<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<5000,2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Remap<CenterDistF<>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>>,TrFade<800>>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Remap<CenterDistF<>,Stripes<3000,-3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>>>>,TrFade<800>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrConcat<TrJoin<TrDelay<10000>,TrInstant>,AlphaL<Black,SmoothStep<IncrementWithReset<ThresholdPulseF<SwingSpeed<400>,Int<18000>>,EffectPulseF<EFFECT_IGNITION>,Int<33000>,Int<11000>>,Int<0>>>,TrWipeX<IgnitionTime<300>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeX<RetractionTime<0>>,TrJoin<TrCenterWipeX<RetractionTime<0>,Int<16384>>,TrSmoothFadeX<RetractionTime<0>>>,TrConcat<TrFadeX<RetractionTime<0>>,White,TrFadeX<RetractionTime<0>>,DarkOrange,TrFadeX<RetractionTime<0>>,Red,TrFadeX<RetractionTime<0>>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Rgb<118,0,194>,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<Rgb<118,0,194>,Mix<Int<16000>,Black,Rgb<118,0,194>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Blue,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<300,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<300,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Red,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<250,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<250,Red,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<DarkOrange,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<200,DarkOrange,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<200,DarkOrange,Red,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Green,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<150,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<150,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5470>>>,TrWaveX<Rgb<180,130,0>,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<100,Rgb<180,130,0>,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<100,Rgb<180,130,0>,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>>,200>>,TrInstant>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelayX<Int<500>>,TrFade<500>>,,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFade<500>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_RETRACTION>>>(),
/home/maxb/Documents/ProffieOS/config/Proffiev6_7v2.h:145: error: template argument 1 is invalid
/home/maxb/Documents/ProffieOS/config/Proffiev6_7v2.h:145: error: template argument 13 is invalid
/home/maxb/Documents/ProffieOS/config/Proffiev6_7v2.h:145: error: no matching function for call to 'StylePtr<<expression error> >()'
In file included from /home/maxb/Documents/ProffieOS/styles/fire.h:4,
                 from /home/maxb/Documents/ProffieOS/ProffieOS.ino:426:
/home/maxb/Documents/ProffieOS/styles/style_ptr.h:93:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr()'
   93 | StyleAllocator StylePtr() {
/home/maxb/Documents/ProffieOS/styles/style_ptr.h:93:16: note:   template argument deduction/substitution failed:
the code is below
{"Infinity Gauntlet;common", "tracks/endgame.wav",
    /* copyright Fett263 InfinityStones (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#InfinityStones
OS6.7 v4.014
This Style Contains 432 Unique Combinations
Base Style: Infinity Guantlet Full Interactive
Base Color: Rgb<100,100,150> (Color Shift (Swing Reset))
Infinity Guantlet Full Interactive Interactive Controls: Twist to select Power, Reality or Soul Stone for blast effect. Use force to activate Space Stone. Use Ligntning Block to activate Time Stone. Use Stab to activate Mind Stone. Timed Shift, reset with Swing. Timed Shift, reset with Swing. Timed Shift, reset with Swing. Timed Shift, reset with Swing.
Preon Effect Options: Default (0): Infinity Stone Collection, 1: Power Absorb (Base Color), 2: Erratic (PreOn Color), 3: Pulsing (PreOn Color), 4: Sparking (PreOn Color), 5: Power Absorb (PreOn Color)
Ignition Effect Options: Default (0): Assemble, 1: SparkTip Ignition, 2: Stack, 3: Dual Mode Wipe (Up = Fast), 4: Glitch On, 5: Multi-Point Out
Retraction Effect Options: Default (0): Unstack + Fade, 1: Dual Mode Wipe In (Down = Fast), 2: SparkTip Retraction, 3: Glitch Off, 4: Blink Off, 5: Disassemble
PostOff Effect Options: Default (0): Emitter Spark (Preon Size), 1: Emitter Glow (Emitter Size)
Lockup Effect: Intensity Lockup V1, Begin Effect: Real Clash, End Effect: Power Burst
LightningBlock Effect: 0
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
Battery Level: Full Blade (Green to Red)
Battery Monitor: Passive Battery Monitor (Retraction)
StylePtr<Layers<Layers<StripesX<Int<6000>,Scale<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<100>,Int<500>>,Scale<SwingAcceleration<>,Int<8000>,Int<4000>>>,Int<-1200>,Int<-3000>>,Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Mix<Int<24000>,Black,Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>>,Mix<Int<18000>,Black,Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>>>,TransitionEffectL<TrSelect<Scale<TwistAngle<>,Int<0>,Int<3>>,TrConcat<TrJoin<TrDelay<1500>,TrWipe<200>>,Stripes<6000,-3000,Rgb<118,0,194>,Mix<Int<10000>,Black,Rgb<118,0,194>>,Mix<Int<20000>,Black,Rgb<118,0,194>>>,TrWipe<200>>,TrSparkX<RandomFlicker<Red,RandomPerLEDFlicker<Red,Mix<Int<12000>,Black,Red>>>,Int<50>,Int<400>,Int<0>>,TrConcat<TrJoin<TrDelay<600>,TrSparkX<Pulsing<Mix<Int<16000>,Black,DarkOrange>,DarkOrange,600>,Int<100>,Int<200>,Int<0>>>,AlphaL<DarkOrange,Int<0>>,TrJoin<TrDelay<1500>,TrJoinR<TrWipeIn<300>,TrFade<300>>>,Stripes<10000,300,Mix<Int<16000>,Black,DarkOrange>,DarkOrange,Mix<Int<12000>,Black,DarkOrange>>,TrJoinR<TrWipeIn<600>,TrFade<600>>>>,EFFECT_BLAST>,AlphaL<ColorSelect<Scale<TwistAngle<>,Int<0>,Int<3>>,TrInstant,Pulsing<Rgb<118,0,194>,Rgb<59,0,97>,2000>,Pulsing<Red,Rgb<128,0,0>,2000>,Pulsing<DarkOrange,Rgb<128,17,0>,2000>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-1000>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<1000>,TrWipe<200>>,Stripes<8000,-600,BrownNoiseFlicker<Rgb<180,130,0>,Mix<Int<8000>,Black,Rgb<180,130,0>>,100>,BrownNoiseFlicker<Rgb<180,130,0>,Mix<Int<12000>,Black,Rgb<180,130,0>>,20>>,TrJoin<TrDelay<1000>,TrWipe<200>>,AlphaL<Pulsing<Rgb<180,130,0>,Mix<Int<16000>,Black,Rgb<180,130,0>>,600>,LayerFunctions<SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-1000>>,SmoothStep<Int<30000>,Int<1000>>>>,TrFade<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrCenterWipeIn<200>>,Mix<LinearSectionF<Int<16384>,Int<2000>>,Remap<CenterDistF<>,Stripes<4000,1200,Mix<Int<8000>,Black,Blue>,Blue>>,AudioFlicker<White,Black>,Black>,TrCenterWipeIn<200>>,EFFECT_FORCE>,LockupTrL<StripesX<Int<12000>,Scale<TwistAngle<1>,Int<-1000>,Int<1000>>,Green,Mix<Int<18000>,Black,Green>,Mix<Int<10000>,Black,Green>>,TrConcat<TrJoin<TrDelay<1000>,TrWipe<400>>,Stripes<12000,-600,Green,Mix<Int<18000>,Black,Green>,Mix<Int<10000>,Black,Green>>,TrFade<400>,Green,TrJoin<TrDelay<1500>,TrFade<400>>,Stripes<12000,1000,Green,Mix<Int<18000>,Black,Green>,Mix<Int<10000>,Black,Green>>,TrFade<400>>,TrFade<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,TrJoin<TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSmoothFade<150>>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrConcat<TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<IgnitionTime<300>,Int<6554>>,Int<32768>>,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<IgnitionTime<300>,Int<6554>>,Int<32768>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<IgnitionTime<300>,Int<6554>>,Int<32768>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<IgnitionTime<300>,Int<6554>>,Int<32768>>,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<IgnitionTime<300>,Int<6554>>,Int<32768>>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrConcat<TrInstant,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrDelayX<Mult<IgnitionTime<300>,Int<8192>>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrDelayX<Mult<IgnitionTime<300>,Int<8192>>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrDelayX<Mult<IgnitionTime<300>,Int<8192>>>,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrDelayX<Mult<IgnitionTime<300>,Int<8192>>>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<300>,Int<16384>>,IgnitionTime<300>>>,TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<300>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<6144>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,IgnitionTime<300>,Int<0>>,Int<12288>,Int<0>>>,LinearSectionF<Int<16384>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,IgnitionTime<300>,Int<0>>,Int<12288>,Int<0>>>,LinearSectionF<Int<26624>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,IgnitionTime<300>,Int<0>>,Int<12288>,Int<0>>>>>,TrDelayX<IgnitionTime<300>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrConcat<TrInstant,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrSmoothFadeX<Mult<RetractionTime<0>,Int<8172>>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrSmoothFadeX<Mult<RetractionTime<0>,Int<8172>>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrSmoothFadeX<Mult<RetractionTime<0>,Int<8172>>>,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrSmoothFadeX<Mult<RetractionTime<0>,Int<8192>>>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<0>,Mult<RetractionTime<0>,Int<16384>>>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,TrJoin<TrBoingX<RetractionTime<0>,3>,TrWipeInX<RetractionTime<0>>>,TrConcat<TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<RetractionTime<0>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<RetractionTime<0>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<RetractionTime<0>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<RetractionTime<0>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<100>,Mult<RetractionTime<0>,Int<6554>>,Int<0>>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrConcat<TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Rgb<118,0,194>,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<Rgb<118,0,194>,Mix<Int<16000>,Black,Rgb<118,0,194>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Blue,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<300,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<300,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Red,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<250,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<250,Red,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<DarkOrange,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<200,DarkOrange,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<200,DarkOrange,Red,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5460>>>,TrWaveX<Green,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<150,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<150,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>>,200>>,TrJoin<TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<5470>>>,TrWaveX<Rgb<180,130,0>,Mult<WavLen<EFFECT_PREON>,Int<3700>>,Int<200>,Mult<WavLen<EFFECT_PREON>,Int<1821>>,Int<32768>>>,Mix<SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-1000>>,Black,Pulsing<ColorSequence<100,Rgb<180,130,0>,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>,Mix<Int<16000>,Black,ColorSequence<100,Rgb<180,130,0>,Green,DarkOrange,Red,Blue,Rgb<118,0,194>>>,200>>,TrInstant>,TrConcat<TrInstant,TransitionLoopL<TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<200>,Int<500>,Int<32768>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<6144>>>,TransitionLoopL<TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<300>,Int<300>,Int<32768>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,TransitionLoopL<TrSparkX<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,Int<400>,Int<100>,Int<32768>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<12288>>>,AlphaL<Mix<IncrementWithReset<ThresholdPulseF<Saw<Int<20>>,Int<16384>>,Sum<EffectPulseF<EFFECT_IGNITION>,ThresholdPulseF<SwingSpeed<400>,Int<18000>>>,Int<32768>,Int<1000>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,RotateColorsX<Int<4096>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<6144>>,5>>,TrConcat<TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,5>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<100>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,3>,Black,TrBoingX<Mult<Int<7260>,WavLen<EFFECT_PREON>>,3>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<3664>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrInstant,TransitionLoopL<TrSparkX<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<200>,Int<500>,Int<32768>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<6144>>>,TransitionLoopL<TrSparkX<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<300>,Int<300>,Int<32768>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<8192>>>,TransitionLoopL<TrSparkX<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<400>,Int<100>,Int<32768>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<12288>>>,AlphaL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<6144>>,5>>>,EFFECT_PREON>,TransitionEffectL<TrSelect<IntArg<OFF_OPTION_ARG,0>,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrJoin<TrDelay<1000>,TrInstant>,AlphaL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrSmoothFadeX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,Mix<BatteryLevel,Red,Green>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_RETRACTION>>>(),
OS6.7 v4.014
This Style Contains 12 Unique Combinations
Base Color: Rgb<100,100,150> (0)
Preon Effect: Infinity Stone Collection
Ignition Effect Options: Default (0): SparkTip Ignition, 1: Interactive Stack (3 Swings)
PowerUp Effect Options: Default (0): Power Burst Reverse, 1: Unstable Power Up Center Out
Retraction Effect Options: Default (0): Run Up, 1: Split Retraction + Fade, 2: Metal Forge (Cool Down)
CoolDown Effect: Unstable Cool Down Center Out
PostOff Effect: Battery Glow (Preon Size)
There’s a double comma. Looks like a transition is missing 10 lines up from the bottom in the paste above.
Search TrJoin<TrDelayX<Int<500>>,TrFade<500>>,,AlphaL<Mix<BatteryLevel
awesome that fixed it, looks like the copy config is adding a comma
This should be fixed, it was just a typo in the script “double comma” as Brian noted. You’ll just need to refresh the page for latest version.
2 styles in here getting arduino compile errors
E:\Saber Stuff\Proffie6.5\ProffieOS\config\test_config.h:64: error: cannot convert ‘StyleFactory*’ to ‘const char*’ in initialization
64 | StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>()},
In file included from E:\Saber Stuff\Proffie6.5\ProffieOS\ProffieOS.ino:571:
E:\Saber Stuff\Proffie6.5\ProffieOS\config\test_config.h:87: error: cannot convert ‘StyleFactory*’ to ‘const char*’ in initialization
87 | StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,AlphaL<AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<255,0,0>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>()},
Getting error messages while verifying ::
error: cannot convert ‘const char*’ to ‘StyleFactory*’ in initialization
{ “LukeEp6Cave;common”,
OS6.7 v4.017
Base Color: Rgb<0,255,0> (0)
–Effects Included–
Stab Effect: Normal Stab
Clash Effect: Real Clash V2
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(), “lukeep6cave”},
{ “LukeEp6;common”,
OS6.7 v4.017
–Effects Included–
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(), “lukeep6”}
That’s not a style error, it’s an error in your preset. You most likely have mismatch for NUM_BLADES and number of styles in your preset.
Hi mate
It’s not … i added the same style to a totally clean and previously compiling ok config
Still gives same error buddy
E:\Saber Stuff\Proffie6.5\ProffieOS\config\battle_config.h:60: error: cannot convert ‘StyleFactory*’ to ‘const char*’ in initialization
I won’t be near a computer until tomorrow, I’ll check when I get a chance.
It’s not config issue — i added that style in an empty config that compiles except for that 1 style
The problem is that you don’t have a track argument in the preset.
Of course!!!
Looking so hard at the style totally missed spotting the obvious
Thanks!
I tested the style and there’s no error, as noted above that error message means there’s something wrong in your preset. As NoSloppy pointed out you’re missing the track in this instance.
All presets need the correct syntax:
{ "font;common", "font/tracks/track/wav",
StylePtr<...>(),
"name"
if you don’t want a track you still need to include just use empty quotes:
{ "font;common", "",
StylePtr<...>(),
"name"
I’m loving the list of ForceEffect options available now. Thanks!
