Okay, so I was playing with the configurator and then copied the stuff over from there and added what you were saying, so… hoping this is right, I have:
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
#ifdef CONFIG_STYLES
class BlackPower {
public:
LayerRunResult run(BladeBase* base) {
return LayerRunResult::UNKNOWN;
SimpleColor getColor(int led) {
return SimpleColor(Color16(0,0,0));
{ "Charging",
ChargingStylePtr<BlackPower>()},
StyleStrobePtr<WHITE, Rainbow, 15, 300, 800>(), "strobe"}
{ 0, , CONFIGARRAY(presets) },
And Profezzorn, I did selected blade plug in the options which is when it gave me the cut trace on the board. Screenshot attached:
I just adapted my wiring to the one that TCSS sells that I was planning to get obviously, unless that is incorrect for the configurator for this setup?
Edit: I think I read your thing wrong as far as where to put the charging code… I’m assuming it needs to be moved down to the BladeConfig section and be { 0, , ChargingStlePtr<BlackPower>() } instead of where I have it?
Also, being you said 65ohm for the switch LED, would it still be 65ohm 1/8w or would that requirement change as well?
