Arduino: 1.8.19 (Windows 10), Board: "Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\ProffieOS.ino:564:
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\Aniflex_config.h:275:2: error: expected '}' before ';' token
275 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\Aniflex_config.h:43:20: note: to match this '{'
43 | Preset presets[] = {
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\Aniflex_config.h:275:2: error: too many initializers for 'Preset'
275 | };
got this error
You need to post the config too, but likely an error with a bracket or comma missing.
The config file you pasted doesn’t match the error message.
The error message you posted says there are unbalanced brackets, but there isn’t in the config file you posted.
Also, the error message says line 275 is: };, but in the config file you posted, that is on a different line.
https://pastebin.com/rKJuwC1U
this is the one it has to be.
Your “ANH_Training” preset is missing a } at the end between the style ending () and the ,
I did a new config and still got an issue.
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:351:1: error: too many initializers for 'Preset'
351 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:355:74: error: cannot convert 'BladeBase*' to 'Preset*' in initialization
355 | WS281XBladePtr<6, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >()
| BladeBase*
In file included from C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\ProffieOS.ino:538:
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:356:17: error: invalid conversion from 'Preset*' to 'size_t' {aka 'unsigned int'} [-fpermissive]
356 | , CONFIGARRAY(presets) },
| Preset*
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\common\preset.h:6:24: note: in definition of macro 'CONFIGARRAY'
6 | #define CONFIGARRAY(X) X, NELEM(X)
ProffieOS:300:28: error: invalid conversion from 'unsigned int' to 'const char*' [-fpermissive]
300 | #define NELEM(X) (sizeof(X)/sizeof((X)[0]))
| unsigned int
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\common\preset.h:6:27: note: in expansion of macro 'NELEM'
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:356:5: note: in expansion of macro 'CONFIGARRAY'
https://pastebin.com/8MU0WDSe
At the top you define only 1 blade:
But at the bottom you declare 2:
{ 0,
WS281XBladePtr<125, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), // that is your first blade
WS281XBladePtr<6, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >() , // that is your second blade
You can set NUM_BLADES to 2 or delete that second blade.
Because of the ways your presets are defined, I would think deleting the second blade is the right move.
Also your Preset 7 is your last in the presets but you still end that “}” with a “,” (line 349)
Not sure if this breaks anything, but the “,” is only needed between 2 presets.
Same is true in line 356 for the blade configs.
Cheers
also, he only has 1 style in his first preset with 2 in the rest.
I have just one blade and one button
You are correct. I just checked the first and based my recommendation on that.
A little hard to see with those comments.
Then I change my recommendation to:
Set number of blades to 2 and add a second style to preset 1.
“Blade” is a more general term here for anything with LEDs in it.
In your case something with 125 Pixels and 1 with 6 Pixels.
Does this match to your settings somewhere?
Accent Light maybe?
Edit: Maybe a 5 Pixel Pogo Pin Connector PCB and a crystal chassis pixel?
https://pastebin.com/T8k5dySa
same errors I dont understand why
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:152:1: error: expected unqualified-id before '{' token
152 | { "Mace;common", "Mace/tracks/Order66.wav",
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:177: error: expected unqualified-id before ',' token
177 | StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,RgbArg<ALT_COLOR_ARG,Rgb<165,65,255>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<165,65,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>,AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,RgbArg<ALT_COLOR_ARG,Rgb<165,65,255>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<165,65,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<115,15,240>>>>,TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,14,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<200>,Int<16384>>,IgnitionTime<200>>>,TrWipeX<IgnitionTime<200>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<200>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<500>,Mult<RetractionTime<500>,Int<16384>>>>,TrWipeInX<RetractionTime<500>>>,Black>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>()},
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:179:1: error: expected unqualified-id before string constant
179 | "preset 3"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:180:1: error: expected declaration before '}' token
180 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:180:2: error: expected unqualified-id before ',' token
180 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:182:1: error: expected unqualified-id before '{' token
182 | { "ROTS_Obicommon", "ROTS_Obi/tracks/Anakin vs Obi.wav",
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:207: error: expected unqualified-id before ',' token
207 | StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<50,50,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<50,50,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,AudioFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<50,50,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<50,50,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,14,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<200>,Int<16384>>,IgnitionTime<200>>>,TrWipeX<IgnitionTime<200>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<200>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<500>,Mult<RetractionTime<500>,Int<16384>>>>,TrWipeInX<RetractionTime<500>>>,Black>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>()},
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:209:1: error: expected unqualified-id before string constant
209 | "preset 4"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:210:1: error: expected declaration before '}' token
210 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:210:2: error: expected unqualified-id before ',' token
210 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:214:1: error: expected unqualified-id before string constant
214 | "preset 5"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:215:1: error: expected declaration before '}' token
215 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:215:2: error: expected unqualified-id before ',' token
215 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:217:1: error: expected unqualified-id before '{' token
217 | { "F1_Racer;common", "F1_Racer/tracks/racer1.wav",
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:239: error: expected unqualified-id before ',' token
239 | StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Stripes<5000,-1500,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>>,Stripes<6000,-3000,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>>>,TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,14,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<200>,Int<16384>>,IgnitionTime<200>>>,TrWipeX<IgnitionTime<200>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<200>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<500>,Mult<RetractionTime<500>,Int<16384>>>>,TrWipeInX<RetractionTime<500>>>,Black>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>()},
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:241:1: error: expected unqualified-id before string constant
241 | "preset 6"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:242:1: error: expected declaration before '}' token
242 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:242:2: error: expected unqualified-id before ',' token
242 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:245:1: error: expected unqualified-id before string constant
245 | "preset 7"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:246:1: error: expected declaration before '}' token
246 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:246:2: error: expected unqualified-id before ',' token
246 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:248:1: error: expected unqualified-id before '}' token
248 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:248:1: error: expected declaration before '}' token
You don’t need to use ``` when you’re posting a URL.
You’re missing a { on line 126.
I get confused on finding the line numbers
The line numbers are pretty clear on pastebin, but whatever you’re using to edit the file should also show the line numbers.
You made a bit more of a mess,
Line 153 to 181 looks the correctest of them, but without “}” in line 178.
One preset should look like this
"Name", "track path",
StyleStuffHere<>(),
"String e.g. preset1"
