I just fixed it and there’s still an error
I suggest cutting every preset into a separate file and try copying back step by step.
At the end for example you seem to be missing lots of the information for preset 7. You are closing “}” prematurely often.
As I said the “mace” one looks the most correct.
I figured using the example config would help just changing the blade numbers since I have one blade and one button. I put all my fonts and blade styles I dont get why it wont work.
Arduino: 1.8.19 (Windows 10), Board: "Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\ProffieOS.ino:564:
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:215:1: error: expected unqualified-id before string constant
215 | "preset 5"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:216:1: error: expected declaration before '}' token
216 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:216:2: error: expected unqualified-id before ',' token
216 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:218:1: error: expected unqualified-id before '{' token
218 | { "F1_Racer;common", "F1_Racer/tracks/racer1.wav",
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:240: error: expected unqualified-id before ',' token
240 | StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Stripes<5000,-1500,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>>,Stripes<6000,-3000,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>>>,TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,14,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrRandom<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<000>>,Scale<WavLen<>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,14,0>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<200>,Int<16384>>,IgnitionTime<200>>>,TrWipeX<IgnitionTime<200>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<200>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<500>,Mult<RetractionTime<500>,Int<16384>>>>,TrWipeInX<RetractionTime<500>>>,Black>,TransitionEffectL<TrConcat<TrExtend<2000,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_NEWFONT>>>()},
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:242:1: error: expected unqualified-id before string constant
242 | "preset 6"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:243:1: error: expected declaration before '}' token
243 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:243:2: error: expected unqualified-id before ',' token
243 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:246:1: error: expected unqualified-id before string constant
246 | "preset 7"
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:247:1: error: expected declaration before '}' token
247 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:247:2: error: expected unqualified-id before ',' token
247 | },
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:249:1: error: expected unqualified-id before '}' token
249 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:249:1: error: expected declaration before '}' token
that pastebin link doesn’t work for me
Last pastebin link is a 404, my input is to the one before:
For a lot of your presets you close the preset right after the
Style PTR<...>()} //"}" Closes preset
When in fact there should still be a string in between:
Style PTR<...>(),
"Preset X"
Further down the code you even have just “preset 5” and “preset 7” there without much more to it. That has to go.
Mace now looks good.
Line 70, 97, 124 and 151 need sth between “()” and “}”.
E.g.
"texthere"
Also remove “}” from line 208 and 240.
Delete lines with “preset 5” + following as well as line with “preset 7” and following.
In general you can also count opening and closing brackets/parentheses.
Every “(”, “{”, “<” and “[” need their
“)”, “}”, “>” and “]” respectively.
If they are not equal, sth is off.
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:234:2: error: expected '}' before ';' token
234 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:181:1: note: to match this '{'
181 | { "ROTS_Obicommon", "ROTS_Obi/tracks/Anakin vs Obi.wav",
234 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:153:1: note: to match this '{'
153 | { "Mace;common", "Mace/tracks/Order66.wav",
234 | };
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:43:20: note: to match this '{'
43 | Preset presets[] = {
C:\Users\andre\OneDrive\Desktop\ProffieOS-v6.5\ProffieOS\config\graflex_config.h:234:2: error: cannot convert '<brace-enclosed initializer list>' to 'const char*' in initialization
234 | };
something is just wrong something small that continues the errors
No, now you deleted the text for your “mace” style and lost the closing “}” there.
Sry, need to sleep. But you are missing sor deleting things at the wrong spot.
Im done with this im just trying to use this thing and be happy I guess Ill ask questions tomorrow. I know its annoying im just trying to learn…
Try adding “}” in line 178 between () and ,
Seems like that text is not mandatory.
Same goes for the 2 following presets.
Don’t worry, I am pretty sure that happens by accident. When you try fixing one thing, you are accidentally creating an issue somewhere else.
yea its aggravating
You are at least missing the closing “}” for the last 3 presets (Mace and onwards)
the closing for the end of the blade style right?
Preset. That contains the name, the track path and the style(s).
Just compare to the others before.
