Hello everyone! I am having trouble with my sound fonts/Arduino not changing my config file after uploading. When I switch presets via Fett263 1 button config, going from preset 1-33/Battery indicator works fine for a good amount of them (some donβt play sound from the font.wav in that specific preset). But going backwards Battery/Preset 33-1 a good amount of them donβt play the selected font sound. My config presets looks correct based on all the hours of videos I watched for example: { Kylo;common", βcommon/tracks/TFA_Battle.wavβ,
I did everything for Arduino as well.
- Iβm on OS 7.8
- Preferences link
- Proffieboard by Fredrik 3.6 for Boardsmanager
- Under tools I am using Board: Proffieboard v2
- My port says COM3 (Butterfly-L433CC, Proffieboard, ProffieBoard V2, Proffieboard V3)
- USB: Serial+Mass Storage+WebUSB
- Programmer: STM32 BOOTLOADER
- My COM3 Serial Driver is: C:\WINDOWS\system32\DRIVERS\usbser.sys
All of fett263s blade styles/colors and effects work perfectly (your work is amazing!)
This config file is under ProffieOS > config > jonsaber_config.h
I donβt get a countdown error because I have the proffie drivers
Everything uploads too 100% without errors however when I click upload, at the bottom right while my board is connected via micro usb (I bought the one Lando Sabers uses in his description) , but when ProffieOS finishes sketching the upload, the bottom right Proffieboard V2 on COM3 disconnects right when the upload begins. I hear the windows disconnect beep, and it goes to Proffieboard V2 [not connected] before 1% of the upload. Like I said it uploads to 100% under Arduino but I dont think my config is changing.
Also even when I heard the windows disconnect sound when upload sketch finishes and it begins the upload from 0%-100%, Proffieboard doesnβt get removed in devices and printers in the control panel.
Thank you so much!
