I agree, Adafruit is well worth supporting.
They aren’t always cheap though, and there is a limit to how much extra I’m willing to pay just because I like the seller.
I need one and I will check it out.
yeah, i’m still needing to build those sabers.
So the soldering station is hakko and the hot air rework station is atten st-862D cool. Wife promised me if i complete my Red hat certification she’ll get me these.
Can anyone suggest a good desoldering gun? The sucker ones are just too finicky for me.
Now if you want to save a few bucks, I would probably recommend buying the japanese version of the desoldering gun from ebay, and you can get third-party soldering stations that accepts the same tips as the soldering station I use. The tips are the important part IMHO, so saving some money on the soldering station is probably fine.
Finally, if you really want to up your soldering game, consider a microscope:
This won’t work, 240V here in Australia.
ATTEN ST-862D Follow-up:
Still using it ![]()
Still like it ![]()
Stamp of approval ![]()
A video on smd soldering would be AMAZEBALLS
There is thousands of those on youtube.
Yeah but none of them are proffieboard specific and none of them are you with hints and tips you can provide.
Most of them are probably better than me.
I can do it, but I don’t do enough of it to be an expert at it.
my hints and tips:
- Use magnification of some sort
- get some tweezers
- don’t turn the heat up too much
- use the lowest air flow setting you can
- consider using kapton tape to cover up other parts so they don’t move around. (Although I’m usually too lazy to do that.)
I think that this youtube has some great tips. Do you think pcb way might be able to make a stainless steel stencil as seen in this video?
Stencils are really only useful when your board doesn’t have any components on it.
I usually use oshstencils when I need stencils.
Sounds great.
the atten is actually hard to come by in some markets it’s discontinued (e.g. Australia) so here’s a place you can still get it.
any thoughts on this?
That looks like a standard blower-in-handle station. I’m not sure if all blower-in-handle stations are the same, but they sure seem to use exactly the same design for the handle. I would expect it to perform the same as my Smartxchoices 898D+ which I wrote a paragraph about earlier in this thread.
