no help shorting BATT+ and 5V.
L1 is non-polar, yes?
Swapped that too. still no good
Keep in mind these are donor board parts so far, so no promise parts replaced are good. Just looking to see if I missed a culprit.
L1 is a pretty simple component, and if itās broken it usually measures as not connected. And yes, it doesnāt have a +/- side.
Maybe there is a short in/under the amp? That could make the 5v not work, and it would also make there be no sound at all I think.
Swapped L1 coil. No change
Swapped U1 amp, no change. Still no sound, no 5V.
Replaced U1 amp with Brand New Partā¦Still nothing
Not sure what else to try.
Good question, thatās a weird one.
Board #8 - Proffieboard v2.2 Black, no branding.
Symptom(s):
Inspection:
Fix:
Replace U60 3.3v regulator.
holy snikees batman, thats a poop show
Board #9 - Proffieboard v2.2 Black, KR Sabers.
Symptom(s):
Inspection:
Fix:
Replace Q7 dual FET.
Stumped. Any pointers @profezzorn?
Well, it seems the CPU isnāt happy. Maybe that gets swapped at a later date.
So, sd_vdd doesnāt get turned on until the CPU boots.
If the CPU had a completely botched programming, or no programming at all, it could potentially leave sd_vdd off. Of course that would also happen if the CPU is dead. Another possibility would be a short under the pull-up resistor that keeps sd_vdd off by default. Have you measured the voltage on the sd_vdd gate?
Thanks. Yeah, no forced upload to bootloader working. I donāt think itās booting.
RN5 tests clean, if thatās the resistor you mean.
Iām measuring 0V at pin 6 on Q7, here.
Iām saying you should also measure sd_power_en (Q7 pin 2) to see if itās trying to turn the power on or not. If itās trying to turn it on, but itās not working, then the problem is on the Q7 side. If itās not trying to turn it on, then the problem is on the RN5/CPU side.
Also, measuring sd_vdd can be misleading, because it becomes nearly floating when off, and when itās floating it could essentially measure as any voltage. Same thing happens to the LED pads when they are off. Adding a resistor between the two measuring probes can give you more predictable results when when youāre measuring something that might be floating.
Ah. Yes I measured 3.27V on pin 2. Plus itās a brand new Q7, so it seems like it should be working.
3.3V on SD power is a symptom. The board still isnāt booting. Could it boot without Q7 feeding out 3.3V on sd_vdd, or is it dependent on it?
Itās a pFET, so it conducts when the gate is low.
3.27v on pin 2 means that the cpu isnāt pulling the sd_power_en low.
The CPU should boot just fine without sd_vdd.
Ah. ok thank you.
And here I am thinking Iām the worst.
Board #10 - Proffieboard v2.2 Black, no branding.
Symptom(s):
Inspection:
Try boot from USB, then remove USB and leave only battery power.
Board runs until battery power removed. Then needs USB again to boot.
Suspect D61 bad.
Fix: Replace D61
All working well
Board #11 - Proffieboard v2.2 Black, no branding. Broken reset btn.
Symptom(s):
Inspection:
only 1.8V on 3.3v pad.
Suspect U60 regulator bad.
Fix: Replace U60 with donor
Replace with brand new U60.
Now LESS . 0V out of U60.
Only 1.2v on backside of D62 D63 D61, regardless of USB or BATT power.
Learned to test diodes properly with multimeter diode mode. Bad D63 and D61.
Replace with donor board diodes that test good.
All working well !
Ah, yes. Keep talking repairs to us, baby.
4 posts were merged into an existing topic: Test rig assembly and use
Board #12 - Proffieboard v2.2 Black, KR Sabers.
Symptom(s):
Inspection:
Fix: None without CPU swap I believe. Useable enough with just one less button pad.
