Iv encountered another issue sorry i feel like im spamming with it.
The rain effect works a treat but when i deativate the rain mode the trloop continues to play even when i turn blade off only shuts off when i change font
Post your style.
Is this a Fett263 library thing, or did you make the style yourself?
lts from the new os7 phase 2
Fett263
October 16, 2023, 11:27pm
4
Post in the library Q & A thread, it keeps everything in front of me. Anything generated in the new library belongs in this thread or it may get missed.
PHASE 2 IS NOW LIVE!
Please watch the videos at the top of the library, there is a lot of new stuff in the library and a lot to learn.
Please post any questions or issues. This phase was considerably larger than the previous with a lot of new interfaces and code so I’m expecting a few bug to pop up. If something in the library isn’t working or the page freezes let me know what style you were using and what Enhancements you were trying to enable/select. The more information you provide in the steps you took the easier to find and fix issues.
If the library generates style code and you get a compile error I just need the FULL style code generated and I can track down the issue.
If the style code compiles and uploads and something doesn’t work as expected post the style code and describe the issue as best you but please make sure you read the top section of the code and did ALL of the required set ups for sounds, etc. Many of the new features require the font to support and require my prop with the correct defines. If you’re missing any of the required pieces the style cannot work properly.
Also, be mindful of Control Layer code, you can only have a single Control Layer style in each preset. If you have multiple blades and need multiple styles simply uncheck the Control Layer and the library will generate the appropriate version.
There is a ton of new features, styles, effects and options with even more on the way. Here’s just a short list for teasers, be sure to explore all of the styles and options, I have only had time to actually demo a very tiny fraction of what’s been added.
PHASE 2 Highlights
Interactive Preon Effects - several available at launch, more on the way…
Interactive Blast Effects - two versions at launch, more on the way…
Expanded Multi-Phase - set Multi-Phase Lockup, Lightning Block, Drag and Melt
New Special Ability - Rain Mode
New styles for Ahsoka Series characters
New Customization Options for Lockup, Lightning Block, Drag and Melt
New Recipes including JuanSith Duality and Tano’s Lesson and Ahsoka Characters with more on the way…
There’s also more updates and additions that I’ll be adding to Phase 2 as I complete, the list of effects was so long I had to put some things on the back burner to get launch completed. As I get time I will be finishing and adding.
There’s still a ton more to come in future phases as well, OS7 has so many new capabilities it’s going to take a while to get everything …
