trying to use workbench and i know it said your browser type will dictate the details given. my preset blade styles are just built in 0,1-9,1 and i saw someone else it had fire rainbow etc.
how would i change their label? or what browser is best?
also im coming from xenopixels and i like that they can change ignitions and bladestyles on the saber itself no plugging in anything, is that possible on proffie since the presets seem to define each font? somehow most of my fonts are flame and like their features aside from the blade style
If you build Edit Mode enabled styles for OS6 you can edit considerably more in workbench.
If you want to edit on the saber then you can enable Edit Mode.
If you need help updating your Proffieboard to add editable styles reger to this page.
ok ty for the links. i have one of your prop files included from the vendor. was using the bc props befor. i used the config helper tool. A little confused on the using part and presets. i used styles that i made from before idk if they are missing the edit enable
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:75: error: expected ';' before '}' token
75 | Layers<Mix<Scale<IsLessThan<SlowNoise<Int<2000>>,Int<18000>>,Int<0>,Int<32768>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Stripes<12000,-800,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30000>,TrFade<300>>,Pulsing<RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,3000>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,97,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,0,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrColorCycleX<RetractionTime<500>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,Int<400>>,Bump<Scale<Trigger<EFFECT_PREON,Int<800>,Int<2000>,Int<500>>,Int<0>,Int<16384>>,Int<8000>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<18432>>>,Mix<Bump<Int<16384>,Int<8000>>,Black,RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>>,TrCenterWipeX<Mult<WavLen<EFFECT_PREON>,Int<4096>>,Int<16384>>,Mix<Bump<Int<16384>,Int<8000>>,Black,PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,Int<300>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<10240>>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrCenterWipeX<Int<200>>,AlphaL<AudioFlicker<RotateColorsX<Int<200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,Bump<Int<16384>,Scale<NoisySoundLevel,Int<14000>,Int<20000>>>>,TrJoin<TrDelayX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<16384>>>,TrCenterWipeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8000>>>>,Layers<AlphaL<AudioFlicker<RotateColorsX<Int<200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,Bump<Int<16384>,Scale<NoisySoundLevel,Int<14000>,Int<20000>>>>,AlphaL<Black,LinearSectionF<Int<16384>,Scale<NoisySoundLevel,Int<4000>,Int<8000>>>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10000>>>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>},;
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:75: error: expected declaration before '}' token
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:75: error: expected unqualified-id before ',' token
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:75: error: expected unqualified-id before ';' token
In file included from C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\ProffieOS.ino:614:
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:50: error: expected primary-expression before ',' token
50 | StylePtr<Layers<Mix<Scale<IsLessThan<SlowNoise<Int<2000>>,Int<18000>>,Int<0>,Int<32768>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Stripes<12000,-800,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30000>,TrFade<300>>,Pulsing<RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,3000>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,97,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,0,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,0>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrColorCycleX<RetractionTime<500>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,Int<400>>,Bump<Scale<Trigger<EFFECT_PREON,Int<800>,Int<2000>,Int<500>>,Int<0>,Int<16384>>,Int<8000>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<18432>>>,Mix<Bump<Int<16384>,Int<8000>>,Black,RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>>,TrCenterWipeX<Mult<WavLen<EFFECT_PREON>,Int<4096>>,Int<16384>>,Mix<Bump<Int<16384>,Int<8000>>,Black,PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,Int<300>>>,TrDelayX<Mult<WavLen<EFFECT_PREON>,Int<10240>>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrCenterWipeX<Int<200>>,AlphaL<AudioFlicker<RotateColorsX<Int<200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,Bump<Int<16384>,Scale<NoisySoundLevel,Int<14000>,Int<20000>>>>,TrJoin<TrDelayX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<16384>>>,TrCenterWipeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8000>>>>,Layers<AlphaL<AudioFlicker<RotateColorsX<Int<200>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<600>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,Bump<Int<16384>,Scale<NoisySoundLevel,Int<14000>,Int<20000>>>>,AlphaL<Black,LinearSectionF<Int<16384>,Scale<NoisySoundLevel,Int<4000>,Int<8000>>>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10000>>>>,EFFECT_POSTOFF>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>()},,
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:55:1: error: expected unqualified-id before '{' token
55 | { "rotoscope;common", "tracks/Prism.wav",
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:56: error: expected unqualified-id before ',' token
56 | StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30000>,TrFade<300>>,Pulsing<RgbArg<SWING_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<180,130,0>>>,3000>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,0,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,14,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,14,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,0,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrJoinR<TrCenterWipeInX<IgnitionTime<400>,Int<16384>>,TrSmoothFadeX<IgnitionTime<400>>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,EFFECT_POSTOFF>>>()},,
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:58:1: error: expected unqualified-id before string constant
58 | "rotoscope"
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:59:1: error: expected declaration before '}' token
59 | },
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:59:2: error: expected unqualified-id before ',' token
59 | },
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:61:1: error: expected unqualified-id before '}' token
61 | };
C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\config\lgt1buttonfett.h:61:1: error: expected declaration before '}' token
Compilation error: expected ';' before '}' token
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define VOLUME 1650
#define BOOT_VOLUME 70
#define CLASH_THRESHOLD_G 3.5
#define KILL_OLD_PLAYERS
#define SAVE_PRESET
#define FETT263_MULTI_PHASE
#define FETT263_QUICK_SELECT_ON_BOOT
#define FETT263_THRUST_ON_PREON
#define FETT263_FORCE_PUSH
{ "roto;common", "tracks/cantina.wav",
"roto"
"rotoscope"
#ifdef CONFIG_STYLES
/*--------------------------------- inquisitor---------------------------------*/
using inquisitor =
add to preset as StylePtr<inquisitor>()
/* Generated with Fett263 Config Helper v2.0 */
The browser doesn’t matter as long as the workbench works.
It depends on which prop file you use when you configure board.
The fett263 prop definitely has the most options when it comes to on-the-fly editing.
These are builtin styles which will be available unless you have DISABLE_BASIC_PARSER_STYLES in your config file. (If you have good styles in your config file, you don’t need the basic ones.)
Two commas in a row are not allowed.
Not sure where that came from, but you need to fix that.
got rid of the 2nd commas but its still got errors.
In file included from C:\Users\mitch\AppData\Local\Programs\Arduino IDE\ProffieOS\ProffieOS.ino:610:
58 | "rotoscope"
59 | },
59 | },
61 | };
the }; on line 61 is red ?
is it the 2nd name? they are different from fonts that worked where they ended with >>>(),“infinity”}, but also all my presets that worked on previous prop dont work. so maybe i have to make new presets
or maybe my prop file isnt up to date?
The first error is on line 75.
You seem to have a },; at the end of line 75, which is wrong, it should just be ;.
end is now EFFECT_BATTERY_LEVEL>>;
58 | "rotoscope"
59 | },
59 | },
61 | };
Compilation error: expected unqualified-id before '{' token
although getting rid of all the presets still has other errors.
Next problem seem to be that you are ending your presets twice.
It looks something like this:
StylepPtr<lots of stuff>()},,
"roto"
As you can see the { and } are unbalanced, it should look like this:
StylepPtr<lots of stuff>(),
"roto"
I think both of your presets have this problem.
yes that worked. ok final question how do i use the using____ preset? In arduino or on the webusb?
it got rid of the StylePtr and i looked through fetts website and youtube didnt see one on how to use them
It’s not a preset, it’s a style, and you would use it in a preset like:
StylePtr<inquisitor>(),
"inquisitor" },
In the config tool or in general? In the config tool you just enable Using Functions in preset area and then add, they will be selectable in the dropdown for each blade. The video at the top of the tool shows.
For Uding functions in general there is more info here:
