ProffieOS7 Style Library Phase 4 (Early Access) - Q & A
Do you reckon there will be a 7.15 or is it just gonna jump strait to 8
Waiting to see, hopefully we can get 7.15, it’s pretty small fix but it’s profezzorn’s decision.
Fingers crossed then, I like the idea of the idle sound, lots of fun to be had
idle sound?
We just worked on and added that for OS8.
This is a controllable Special Ability, it can be used for many different things- Idle sound is just one use :wink:
That sounds cool I see there’s a lot of hard work goin on behind the scenes, i am exited for 8 and all the new features, pretty sad to hear that pstofff might be getting the chop though will this be gone forever or is it being replaced with something new
Where did you hear that?
I read it in that link that you shared
profezzorn commented last week
I feel like we should link postoff to idle (if postoff exists)
If postoff doesn’t exist, we should link out directly to idle.
No that’s just meaning ā€œif the font contains that soundā€.
Not all fonts come with pstoff files, in which case, the ā€œoutā€ sound would directly be followed by the ā€œidleā€ sound.
Aww ok, sorry I misinterpreted it, I need to stop asking questions :rofl: especially when the answers come back so obvious
I’ve moved over to OS8.1 since it now support the FETT263 prop, and spin mode isn’t activating when I hold power and swing while off. I get a normal swing on. Is there a conflict in my config? Maybe spin mode got lost in the shuffle? Wasn’t sujre if this was an OS Beta test question of specific enough to your prop to place here. Thanks!
Probably better in OS8 beta thread, not really a library thing. :wink:
I didn’t make any changes to my prop for OS8 that should impact any existing features, so no idea how it would be impacted.
What does this mean? You are looking to turn on by spinning and have spin sounds play?
You don’t have #define ENABLE_SPINS in your config.
If you add that, does it do what you want?
Oh, no it’s a different feature. From the FETT263 prop:
NEW! Toggle Spin Mode* = Hold PWR + Swing
    Disables Clash, Stab and Lockup effects to allow for spinning and flourishes
    Will play bmbegin.wav or force.wav when toggled ON/OFF
It’s for us show -offs who like to twirl things around and not give away when we hit ourselves in the legs :sweat_smile:
My next project is a pair of nunchaku, so it’s mostly for this :slight_smile:
I would assume that’s a button / gesture action that you do while the saber is on, not off.
Yeah, I thought that too at first but zooming out:
Standard Controls While Blade is OFF
  Turn On / Ignite Saber* = Click PWR
    *If FETT263_MOTION_WAKE_POWER_BUTTON defined first Click will Wake up motion detection and boot sound will play
  Turn On / Ignite Saber (Muted) = Double Click PWR
  Change Preset (one at a time*) = Click AUX
    *if pointing down will go to previous
  NEW! Scroll Presets (using twist menu) = Long Click AUX
    Turn Right (Stepped) = Next Preset
      Increment by 5 = Hold PWR + Turn Right
    Turn Left (Stepped) = Previous Preset
      Increment by 5 = Hold PWR + Turn Left
    Click PWR = Select Preset
    NEW! Hold PWR = Select and Ignite Preset
    Click AUX = go to First Preset
  Play Track = Long Click PWR pointing up
  NEW! Track Player* = Long Click PWR parallel
  *requires tracks in either font/tracks/ or common/tracks/
  *if no tracks in font or common will "Loop" default track
    Turn Right (Stepped) = Next Track
    Turn Left (Stepped) = Previous Track
    Click PWR = Play Current Track Once
    Click AUX = Random (will play current track and then randomly select next tracks)
    Hold PWR + Turn Right = Rotate (will play current track and then next sequential tracks)
    Hold PWR + Turn Left = Loop Current Track
    Long Click PWR = Stop Track Player
  NEW! Force/Quote Player = Hold PWR
    If quotes exist in current font pointing straight down will toggle between Force/Quote and play
    *Quotes play sequentially 1,2,3...
    If parallel will do Force/Quote based on current mode
  NEW! Toggle Gesture Sleep* = Hold PWR + Clash
    *toggles gesture controls on/off
    *gestures sleep automatically if Blade Detect is enabled and blade is missing
    *requires FETT263_SPIN_MODE define
I think this came to be in os 6? Lost track :slight_smile:
Well then it sounds like you’re either not holding power the whole time while doing the swing, or ENABLE_SPINS is required, or both. :person_shrugging:
Agreed. I’m gonna check that all, do some other tests, and circle back. Thank you!!!’
No, it’s done when blade is off.
New Special Ability - Toggle Idle / Off Sound Effect - ProffieOS7.15 Early Access Library Update
I have added a new Special Ability to my Early Access Style Library - ā€œToggle Idle/Off Soundā€.
This Special Ability allows you to toggle an idle sound on or off (Special Abilities 5 ~ 8). The Idle/Off sound is a sound that can play while your saber is not ignited. This sound can be anything you want, for the demo I used a hum from a different font and lowered the volume in Audacity.
When toggled on the Idle sound will play anytime your saber is retracted and will stop when you ignite the saber. If you want to stop the sound you just do the same Special Ability to toggle off. This Special Ability will require OS7.15 (released a little while ago). There was a bug in previous versions that didn’t allow this type of Special Ability to run properly.
In addition to the Idle/Off Sound, there are several other new styles and effects added to the Early Access library that I haven’t had a chance to video yet. I’ve been working on development and testing for OS8 but still have more coming to the OS7 Library as I get time, so keep an eye out.
In the meantime, check out the new Special Ability and other additions in my Early Access Library, enjoy!
