ProffieOS7 Style Library Phase 4 (Early Access) - Q & A
New Special Ability - Toggle Idle / Off Sound Effect - ProffieOS7.15 Early Access Library Update
I have added a new Special Ability to my Early Access Style Library - “Toggle Idle/Off Sound”.
This Special Ability allows you to toggle an idle sound on or off (Special Abilities 5 ~ 8). The Idle/Off sound is a sound that can play while your saber is not ignited. This sound can be anything you want, for the demo I used a hum from a different font and lowered the volume in Audacity.
When toggled on the Idle sound will play anytime your saber is retracted and will stop when you ignite the saber. If you want to stop the sound you just do the same Special Ability to toggle off. This Special Ability will require OS7.15 (released a little while ago). There was a bug in previous versions that didn’t allow this type of Special Ability to run properly.
In addition to the Idle/Off Sound, there are several other new styles and effects added to the Early Access library that I haven’t had a chance to video yet. I’ve been working on development and testing for OS8 but still have more coming to the OS7 Library as I get time, so keep an eye out.
In the meantime, check out the new Special Ability and other additions in my Early Access Library, enjoy!
