Here is the style code: (idk how to do the text box thing, haha)
OS7.15 v3.215p
Multi Phase (Special Abilities*) Transition: Wipe, Time: 500
Default: Hyper Responsive Rotoscope (Sequels) [BaseColorArg]
1: Audio Rotoscope - Single Color (Original Trilogy) [AltColorArg]
2: Hyper Responsive Rotoscope (Prequels) [AltColor2Arg]
3: Sabine Wren [AltColor3Arg]
Multi Phase Control: use Special Abilities controls to change Phase. Requires Alt Font.
*This style REQUIRES Alt Fonts alt000/ to alt003/ to be set up. Uses altchng.wav on change.
Lockup Effect:
0: mainLockMulti0Shape - Begin: Full Blade Flash - Style: Intensity AudioFlicker - End: Full Blade Absorb
1: Responsive Localized - Begin: Full Blade Flash - Style: Intensity Flame - End: Full Blade Absorb
2: Responsive Localized - Begin: Full Blade Flash - Style: Intensity AudioFlicker - End: Full Blade Absorb
3: Responsive Localized - Begin: Full Blade Flash - Style: Intensity AudioFlicker - End: Full Blade Absorb
[Color: LockupColorArg]
Lightning Block Effect:
0: mainLBMulti0Shape - Begin: Full Blade Flash - Style: Strobing AudioFlicker - End: Full Blade Absorb
1: Responsive Lightning Block - Begin: Full Blade Flash - Style: Strobing AudioFlicker - End: Full Blade Absorb
2: Responsive Lightning Block - Begin: Full Blade Flash - Style: Strobing AudioFlicker - End: Full Blade Absorb
3: Responsive Lightning Block - Begin: Full Blade Flash - Style: Strobing AudioFlicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect:
0: mainDragMulti0Shape - Begin: Wipe In - Style: Intensity Fire Drag - End: Wipe Out
1: Responsive Drag - Begin: Wipe In - Style: Intensity Fire Drag - End: Wipe Out
2: Responsive Drag - Begin: Wipe In - Style: Intensity Fire Drag - End: Wipe Out
3: Responsive Drag - Begin: Wipe In - Style: Intensity Fire Drag - End: Wipe Out
[Color: DragColorArg]
Melt Effect:
1: Responsive Melt - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
2: Responsive Melt - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
3: Responsive Melt - Begin: Wipe In - Style: Intensity Melt - End: Wipe Out
[Color: StabColorArg]
Stab Effect: Normal Stab [Color: StabColorArg]
Blast Effect: Blast Wave (Large) [Color: BlastColorArg]
Clash Effect: Responsive Clash with Wave [Color: ClashColorArg]
Swing Effect: Force Rage Lightning [Color: SwingColorArg]
Display Volume: Blade Location [Color: BaseColorArg]
Special Ability 1: Change Phase (Corruption: Rotoscope - Time: 10000 ms) Uses tr00.wav or or tr/000/000.wav (blade corruption sound)
Special Ability 2: Next Phase
Special Ability 3: Toggle Cortosis Clash V2 mode, if blade Clashes within 3000 ms, blade will be shorted out and sparking and will not be able to reignite when pressing the Power Button for 10000 ms. (Spark Size: 3300).
Saber will automatically re-ignite with a partial 'flame up' followed by a full ignition after shorted out period completes.
Uses tr01.wav or tr/001/000.wav for toggle, tr02.wav or tr/002/000.wav for cortosis (metallic sound on clash), tr03.wav or tr/003/000.wav for shorted out / disabled period (sparking sound)(10000 ms) and tr04.wav or tr/004/000.wav for partial 'flame' ignition
Special Ability 5: Ignite + Change Phase (Corruption: Rotoscope - Delay: 1000 ms - Time: 10000 ms) Uses tr05.wav or or tr/005/000.wav (blade corruption sound)
StylePtr<Layers<Black,ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,AudioFlicker<Stripes<10000,-2600,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,Mix<Int<19276>,Black,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>>,AudioFlicker<Stripes<23000,-1300,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,Mix<Int<11565>,Black,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>,TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrConcat<TrJoin<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<200>,Int<700>>>,TrWipe<200>>,RandomPerLEDFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,TrWipe<200>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrExtend<12000,TrDoEffectAlwaysX<TrDelay<10>,EFFECT_TRANSITION_SOUND,Int<0>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<4>>,Int<-1>>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<4>>,Int<-1>>,EFFECT_USER2>,TransitionPulseL<TrConcat<TrExtend<300,TrDoEffectX<TrInstant,EFFECT_TRANSITION_SOUND,Int<2>>>,TrDoEffect<TrWipeIn<100>,EFFECT_FAST_OFF>,TrDelay<1000>>,Mult<EffectPulseF<EFFECT_CLASH>,HoldPeakF<EffectPulseF<EFFECT_USER3>,Int<3000>,Int<32768>>>>,TransitionEffectL<TrDoEffectX<TrInstant,EFFECT_TRANSITION_SOUND,Int<1>>,EFFECT_USER3>,TransitionPulseL<TrConcat<TrExtend<500,TrFade<100>>,TrFade<500>>,ThresholdPulseF<Mult<Sum<EffectPulseF<EFFECT_RETRACTION>,EffectPulseF<EFFECT_CLASH>>,HoldPeakF<EffectPulseF<EFFECT_FAST_OFF>,Int<13000>,Int<32768>>>>>,TransitionEffectL<TrConcat<TrDelay<1000>,TrExtendX<Int<10000>,TrDoEffectAlwaysX<TrInstant,EFFECT_TRANSITION_SOUND,Int<3>>>,TrExtend<500,TrDoEffectAlwaysX<TrWipe<300>,EFFECT_TRANSITION_SOUND,Int<4>>>,TrDoEffectAlways<TrFade<300>,EFFECT_FAST_ON>>,EFFECT_FAST_OFF>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,16000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<0,132,255>>,Int<200>,Int<100>,Int<400>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,87>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>>,EFFECT_CLASH>,ColorSelect<AltF,TrInstant,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<20000>,Int<28000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<20000>,Int<28000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<20000>,Int<24000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,LockupTrL<TransitionEffect<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>>,Stripes<3600,-1600,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Scale<SlowNoise<Int<1600>>,Int<4000>,Int<20000>>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>,Mix<Scale<SlowNoise<Int<2000>>,Int<16000>,Int<2000>>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<32000>,Int<40000>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>>,Stripes<4200,-1200,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Scale<SlowNoise<Int<1600>>,Int<4000>,Int<20000>>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>,Mix<Scale<SlowNoise<Int<2000>>,Int<16000>,Int<2000>>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<32000>,Int<40000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<23000>,Int<31000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<23000>,Int<31000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<23000>,Int<27000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<26000>,Int<34000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<26000>,Int<34000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16440>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<26000>,Int<30000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,97,0>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>>,ColorSelect<AltF,TrInstant,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<400>>,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<400>>,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<400>>,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<0,255,255>>,TrFade<400>>,Int<1>>>,ColorSelect<AltF,TrInstant,LockupTrL<AlphaL<TransitionEffect<Stripes<2000,4000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<50>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<4096>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<TransitionEffect<Stripes<2000,4000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<50>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<4096>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<TransitionEffect<Stripes<2000,4000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<50>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<4096>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<TransitionEffect<Stripes<2000,4000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<50>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<4096>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,Stripes<2000,3000,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<30>>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<8192>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,68,0>>>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>>,ColorSelect<AltF,TrInstant,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,16000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>>,SyncAltToVarianceL,TransitionEffectL<TrConcat<TrDelay<10>,Black,TrExtendX<Int<1000>,TrWipeX<Int<300>>>,AlphaL<White,Int<0>>,TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<Subtract<TimeSinceEffect<EFFECT_USER5>,Sum<Int<300>,Int<1000>>>,327>,Int<0>,Int<28000>>,Scale<Percentage<Subtract<TimeSinceEffect<EFFECT_USER5>,Sum<Int<300>,Int<1000>,Int<10>>>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>,TrFade<1000>>,EFFECT_USER5>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtend<8500,TrInstant>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<0>,Int<28000>>,Scale<Percentage<TimeSinceEffect<EFFECT_USER1>,327>,Int<2000>,Int<31000>>>,Int<-2000>>>,TrExtend<2500,TrWipe<1000>>,AlphaL<RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,SmoothStep<Scale<SlowNoise<Int<3000>>,Int<27000>,Int<31000>>,Int<-2000>>>,TrInstant,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,ColorSelect<AltF,TrInstant,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,TrExtend<1000,TrInstant>,RandomFlicker<Stripes<24000,-1400,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Mix<Int<11565>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Mix<Int<16448>,Black,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>>,ColorSelect<AltF,TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>>,TrFade<1000>>,EFFECT_USER1>,TransitionPulseL<TrConcat<TrExtend<300,TrInstant>,BrownNoiseFlicker<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Black,300>,TrWipeIn<100>,Mix<SmoothStep<Int<3300>,Int<-500>>,Black,BrownNoiseFlickerL<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Int<300>>>,TrDelay<1000>>,Mult<EffectPulseF<EFFECT_CLASH>,HoldPeakF<EffectPulseF<EFFECT_USER3>,Int<3000>,Int<32768>>>>,TransitionPulseL<TrConcat<TrExtend<500,TrFade<100>>,RandomPerLEDFlickerL<Black>,TrFade<500>>,ThresholdPulseF<Mult<Sum<EffectPulseF<EFFECT_RETRACTION>,EffectPulseF<EFFECT_CLASH>>,HoldPeakF<EffectPulseF<EFFECT_FAST_OFF>,Int<13000>,Int<32768>>>>>,TransitionEffectL<TrConcat<TrDelay<1000>,AlphaL<BrownNoiseFlickerL<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Int<300>>,SmoothStep<Int<3300>,Int<-500>>>,TrExtendX<Int<10000>,TrInstant>,AlphaL<RandomFlicker<Black,BrownNoiseFlickerL<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,Int<300>>>,SmoothStep<Int<3300>,Int<-500>>>,TrExtend<500,TrWipe<300>>,Layers<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrWipeX<Int<500>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR2_ARG,Rgb<255,149,0>>,RgbArg<ALT_COLOR3_ARG,Rgb<0,255,0>>>,AlphaL<Gradient<AlphaL<White,Int<0>>,RandomPerLEDFlickerL<Black>,Black,Black>,SmoothStep<Scale<SlowNoise<Int<4000>>,Int<8000>,Int<16000>>,Scale<SlowNoise<Int<2000>>,Int<10000>,Int<4000>>>>>,TrFade<300>>,EFFECT_FAST_OFF>,TransitionEffectL<TrConcat<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,AlphaL<White,Int<0>>,TrDelayX<Sum<Int<300>,Int<1000>>>,AlphaL<White,Int<0>>,TrExtend<12000,TrDoEffectAlwaysX<TrInstant,EFFECT_TRANSITION_SOUND,Int<5>>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<4>>,Int<-1>>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrExtend<2000,TrFade<100>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Bump<VolumeLevel,Int<8000>>>,TrFade<300>>,EFFECT_VOLUME_LEVEL>>>(),
