PHASE 3 is now Live for my Early Access Patrons.
Any questions or issues please post here. If you get an error please provide the full code generated by the Library -or- if there’s an error message in the library please provide. If you cannot generate Style Code please list the selections you’re making so I can recreate.
https://www.fett263.com/os7-library.html
Demos:
This is a demo of a brand new capability coming to Phase 3 of my Style Library for my Early Access Patrons.
Base Style Reaction Effects are a new capability that allows your base style to react to various effects to simulate how your blade’s energy is affected when it absorbs external energy from a blast or other blade or how your blade becomes unstable with extended use.  There’s a ton of customization and options available (see second half of the video for the Library demo of options).
This demo is set up to react to combinations of Blasts or Clashes (you can also choose Lockups, Lightning Block, etc.).  As you have multiple blasts or clashes hit your blade the blade takes on a reaction style that simulates additional energy being applied, in this case the base animation and color change as you build up consecutive effects.
In addition, using Alt Font, we can also have the actual sound of your saber also react to the energy build up.  Once you’ve hit the maximum number of consecutive effects (in this case 5) the sound of the saber (hums and swings but can be anything you want) will switch to align with the new animation.  Then after a period of time your blade will stabilize back to it’s original state for the visual effects and sounds.
Be sure to stick around for the second half of the video as I demonstrate the new library interfaces to set this capability up! This is just one new capability coming to Phase 3, I have many more I need to finish and demo.
Up until now we’ve only just dipped our toe in the water of what OS7 can do, Phase 3 is going to a “Canonball” into the deep end of what OS7 offers! Much, much more to come, stay tuned…
Here’s another sneak peek at a brand new feature coming in Phase 3 of my Style Library for my Early Access Patrons.
Accent Overlays are enhancement animations you can add to your base layer to further customize the way your blades looks and reacts.  In addition, using Transition Sounds we can further enhance the realism by adding a unique sound that will synchronize perfectly with the animation.  This allows you to have surges, bolts, pulses, electric currents, sparks , waves, etc. that run over your blade with their own independent sound.
These effects are fully customizable, you can create 1000s of unique animations and set them up with completely unique sounds.  In addtion, using Style Option 3, you can build out an option style and enable different options in each preset for completely unique blade effects.
There’s virtually unlimited possibilities with customization of the animations, colors, direction.  You can choose from a timed effect, a random effect, an idle effect or a swing effect and each can have unique sounds tied to them.
I’ve also added new “Boomerang” effects that feature an animation that runs out from the hilt but always returns after a time (customizable) and you can set unique sounds for the two animations, with one sound for the animation running out and another for it returning even further adding to the realism.
There’s a ton of options and customization in the initial launch of Phase 3, with many more in development that will be added over time.  Be sure to check out the second half of the video for a demo of the new Library options and how to set up these new effects in Phase 3.
This feature and many more is coming in Phase 3 of my Early Access library for my Early Access Patreon members, more information available here: https://www.fett263.com/os7-library.html
