ProffieOS7 Style Library (Phase 2 Public Access) Q & A Thread
You’re welcome, appreciate it.
@Fett263 Last quick question. When I use your library, the power button stop working for ignite. It does however work for the rest (phase change, power off and track play). Have you ever come across that behaviour by any chance?
Depends on what effects you added, read the top section of the style code provided by the library for proper set up and controls based on the options you selected.
Hi Fett.
There seems to be something funky going on with the style7 blade editor for Hyper Responsive Rotoscope (Original Trilogy)
If I choose to add rain and thunder as a special feature then later decide to change it and removing it from the special abilities drop box. It still however shows up in the blade when you press the special button… it seems to hold onto the code somehow.
With this deleted and the sound files and folders it still shows up when installed in my saber.
Below is my current code… It seems to be the only way to clear the rain effect is to refresh the style page and then you loose all your progress? Thanks heaps.
Julian
// ProffieOS7 Config File
#define NUM_BLADES 3
const unsigned int maxLedsPerStrip = 264;
#define VOLUME 1500
#define CLASH_THRESHOLD_G 1
#define PROFFIEOS_DONT_USE_GYRO_FOR_CLASH
#define KILL_OLD_PLAYERS
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
{ "luke_cave;common",  "luke_cave/tracks/jabba_scene.wav",
https://fett263library.com/early-access/#Rotoscope
OS7.14 v3.4
Base Color: BaseColorArg (0)
Retraction Effect: SparkTip Retraction [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Interactive Blast: Random Blasts - Default Level (Uses Style Option 2 for Editing): 1000 ms
Interactive Blast control requires blast.wav files in font. When Blast is triggered blast.wav will play, to deflect blast (blst.wav and visual effect) swing within 1000ms of blaster sound ending. Random number of blasts from 1 to multiple possible. Only one style per preset can contain.
Clash Effect: Real Clash V3 [Color: ClashColorArg]
Special Ability 5: Play Sound - Ignite Uses quote00.wav or quote/000/000.wav
Special Ability 6: Play Sound - Ignite Uses quote01.wav or quote/001/000.wav
Special Ability 7: Play Sound - Ignite Uses quote02.wav or quote/002/000.wav
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,ColorSelect<EffectIncrementF<EFFECT_USER4,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,SparkleF<300,800>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,TransitionEffectL<TrConcat<TrDelay<100>,AlphaL<White,Int<0>>,TrDoEffect<TrInstant,EFFECT_GAME_CHOICE>>,EFFECT_INTERACTIVE_BLAST>,TransitionEffectL<TrConcat<TrExtendX<Sum<WavLen<EFFECT_INTERACTIVE_BLAST>,IntArg<STYLE_OPTION2_ARG,1000>>,TrInstant>,TransitionPulseL<TrDoEffect<TrInstant,EFFECT_BLAST>,ThresholdPulseF<SwingSpeed<300>,Int<16000>>>,TrConcat<TrDelay<150>,TrRandom<TrDoEffect<TrInstant,EFFECT_INTERACTIVE_BLAST>,TrInstant,TrDoEffect<TrInstant,EFFECT_INTERACTIVE_BLAST>,TrDoEffect<TrInstant,EFFECT_INTERACTIVE_BLAST>>>>,EFFECT_GAME_CHOICE>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_USER5>,EffectPulseF<EFFECT_USER6>,EffectPulseF<EFFECT_USER7>>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrInstant>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrDelayX<Int<7085>>,AlphaL<White,Int<0>>,TrConcat<TrJoin<TrDelayX<Int<600>>,TrInstant>,AlphaL<Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<500>>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrExtendX<Int<7085>,TrInstant>,Black,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<300>>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrExtendX<Int<2397>,TrInstant>,Black,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<300>>>,EFFECT_USER6>,TransitionEffectL<TrConcat<TrExtendX<Int<2790>,TrInstant>,Black,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Int<300>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrDoEffectAlwaysX<TrExtendX<Int<7085>,TrInstant>,EFFECT_QUOTE,Int<0>,Int<-1>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrDoEffectAlwaysX<TrExtendX<Int<2397>,TrInstant>,EFFECT_QUOTE,Int<1>,Int<-1>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>>,EFFECT_USER6>,TransitionEffectL<TrConcat<TrDoEffectAlwaysX<TrExtendX<Int<2790>,TrInstant>,EFFECT_QUOTE,Int<2>,Int<-1>>,AlphaL<White,Int<0>>,TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>>,EFFECT_USER7>>>(),
// control box GREEN
StylePtr<InOutHelper<Blinking<Green,Blinking<Green, Black, 300, 500>,3000,500>,1,1,Sequence<GREEN, BLACK, 100, 80, 0b1010101010101010,0b0000000000000000,0b0000000000000001,0b1010101010101010,0b0101000000000000>>>(),
// control box RED
StylePtr<InOutHelper<Blinking<Red, Black, 2000, 200>,1,1,Sequence<RED, BLACK, 100, 80, 0b0000000000000000,0b1010101010101010,0b1010101000000000,0b0000000000000000,0b1010101010101010>>>(),
"preset0"
 { 0,
    WS281XBladePtr<264, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    // control box Red - 1LED
    SubBlade(0, 0, WS281XBladePtr<2, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()),
    // control box Green - 1LED
    SubBlade(1, 1, NULL),
  CONFIGARRAY(presets)
Yup, looks like a bug in the library. I’ll have a look as soon as I get a chance.
This has been fixed, along with another related bug that was missed. You’ll need to refresh the page to get new scripts, bottom corner of the site should say “OS7.14 v2.25p” for latest version.
I just pushed a pretty large update with a ton of new options for BladeBuilder, Ignition Effects, Retraction Effects and Special Abilities (too many to list). Since this was a fairly large update if you encounter any issues or errors please just post the selections you were making so I can have a look.
