ProffieOS7 Style Library (Phase 2 Public Access) Q & A Thread
Phase 2 has moved to Public Access, this thread is for any questions or issues.
Please be sure to watch the recommended videos at the top of the library, the new features are explained there.
If you get errors please post the style code generated by the library or any error messages. If you are unable to generate style code please list the selections you made so I can recreate.
https://www.fett263.com/fett263-proffieOS7-style-library.html
On Sabine Wren if you switch the drag selection to AudioFlicker the StyleEditor shuts the blade down and you cannot reignite unless you select other than AudioFlicker drag. Similar happens if selecting UnstableFlicker. *Note this also happens with Ezra Bridger and Baylan Skoll.
AudioFlicker
/* copyright Fett263 Ahsoka (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#Ahsoka
OS7.14 v2.24p
Base Style: Sabine Wren
Base Color: BaseColorArg (0)
Ignition Effect: Glitch On [Color: IgnitionColorArg]
Retraction Effect: Glitch Off [Color: RetractionColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
0: mainDragMulti0Shape - Begin: Wipe In - Style: AudioFlicker - End: Wipe Out
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Clash Effect: Responsive Clash with Wave [Color: ClashColorArg]
StylePtr<Layers<AudioFlicker<Stripes<23000,-1300,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<300>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Black>>>(),
UnstableFlicker
OS7.14 v2.24p
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
0: mainDragMulti0Shape - Begin: Wipe In - Style: Unstable Flicker - End: Wipe Out
Melt Effect:
This has been fixed. You’ll need to refresh the page to get update.
Much appreciated.
Hi Fett, I just updated one of my config files to try out the toggle rain and lightning modes, but got this lengthy error message. I literally copied/pasted the blade style onto my config file, which can be found here: Oracle - Pastebin.com
The error message is too long for me to post on this forum or Pastebin. What’s wrong with the config?
@Fett263 This seems to be the offending style from @aikichick 's config (removing it from the config, it then compiles fine):
/* copyright Fett263 ThunderStorm (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#ThunderStorm
OS7.14 v2.241p
Base Style: Thunderstorm
PowerUp Effect: Power Burst Forward [Color: IgnitionColorArg]
Retraction Effect: Cycle Down [Color: RetractionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Stab Effect: Normal Stab [Color: StabColorArg]
Swing Effect: Unstable Swing (Scaled Full Blade) [Color: AltColorArg]
Special Ability 1: Toggle Rain Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped)
Special Ability 2: Toggle Lightning Mode Uses tr00.wav or or tr/000/000.wav (thunder or lightning strike)
Special Ability 3: Toggle Rain and Lightning Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped) and tr00.wav or tr/000/000.wav (thunder or lightning strike)
StylePtr<Layers<Black,TransitionLoop<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,TrConcat<TrBoing<500,3>,Layers<Stripes<10000,100,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,AlphaL<Stripes<8000,-200,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrFade<100>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER2,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,ColorSelect<EffectIncrementF<EFFECT_USER3,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,SparkleF<300,800>>>,ColorSelect<EffectIncrementF<EFFECT_USER3,Int<2>>,TrFade<100>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<100>>,Int<1000>,Int<4500>>>,AlphaL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSelect<EffectIncrementF<EFFECT_USER3,Int<2>>,TrInstant,TrConcat<TrDoEffect<TrInstant,EFFECT_TRANSITION_SOUND,0>,BrownNoiseFlickerL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,TrRandom<TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,2>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,3>,TrBoingX<WavLen<EFFECT_TRANSITION_SOUND>,4>>>>>>>,AlphaL<Stripes<2000,-3000,RgbArg<ALT_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<RgbArg<ALT_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<8192>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,0,255>>>>,RandomPerLEDFlicker<Mix<Int<3932>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<ALT_COLOR_ARG,Rgb<0,0,255>>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER3>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrColorCycleX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>()
And the error produced is ultimately:
error: ambiguous overload for 'operator<<' (operand types are 'SimpleColor' and 'SimpleColor')
TransitionLoop is not a transparent layer, so on top of another solid “Black” it’s not happy.
Remove the Black base layer, all will be well.
This has been fixed, you’ll need to refresh the page to get the update.
So does that mean that only the base layer in Layers<> can be opaque, and all the rest must be transparent?
EDIT: I guess that makes sense, lol, thanks BC
That’s correct.
To clarify further, the base layer needs to be solid. You can’t have all transparent layers. You’ll see an error about " ‘RGBA_nod operator - (const RGBA_um_nod&, const RGBA_um_nod&)’"
Yeah, that much I was aware of, I realize now I used “can” instead when I shouldn’t have…
Heh, as an aside, it took me a while reading through the code to figure out why on earth it was called “nod”… (didn’t get to its definition file since I was just kinda going through stuff)
Just redid the bladestyle and it works perfectly. Thanks, Fett!
Okay…I actually have one other question. I downloaded three different thunder wav files for the sound font and named them tr00, tr01, tr02 in the tr folder. However, only tr00 is being played when I turn on the Special Ability to toggle lightning mode. Did I name the files correctly?
What does the style information section say? It will tell you which sounds are set up for the effect based on the options you selected. Post the top section of the style code if you’re unsure.
The bladestyle says this:
I only have one rain sound which I named trloop00; it runs fine. Since I have 3 different thunder sounds, I put them in a separate folder named tr and followed the same naming convention as the tr folder for Party Mode.
If you have multiple sounds then set them up for sub-sub sounds in tr/000/
See here:
Okay, just renamed the thunder wav files in tr/01 as 000, 001, 002 - and all three thunder sounds are now working. Thank you! :+1:
You’re welcome, glad to hear.
For clarity, Force Boost Bright Swing Full Blade (scaled) needs to have ForceEffect pushed before the swing effect will show up and work on the blade while swinging, correct?
/* copyright Fett263 JediSurvivor (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#JediSurvivor
OS7.14 v2.241p
Base Style: Cal Kestis Survivor Green
Lockup Effect:
0: mainLockMulti0Shape - Begin: Full Blade Flash - Style: Intensity AudioFlicker - End: Full Blade Absorb
0: mainLBMulti0Shape - Begin: Full Blade Flash - Style: Strobing AudioFlicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect:
Melt Effect:
0: mainMeltMulti0Shape - Begin: Wipe In - Style: Intensity Fire Melt - End: Wipe Out
Blast Effect: Blast Wave (Sound Based) [Color: BlastColorArg]
Swing Effect: Force Boost Bright Swing (Scaled Full Blade) [Color: SwingColorArg]
StylePtr<Layers<StripesX<Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<3000>,Int<3000>>,Int<4000>,Int<1800>>,Scale<HoldPeakF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_ALT_SOUND>>,Int<2000>,Int<4000>>,Int<-2800>,Int<-4000>>,Mix<Int<16000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Sin<Int<20>,Int<22000>,Int<32768>>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,Mix<Int<8000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30000>,TrFade<300>>,AlphaL<Mix<NoisySoundLevel,RotateColorsX<Int<4096>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<AudioFlicker<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<8164>,Black,RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Layers<Stripes<2000,4000,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<50>>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<4096>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,TransitionPulseL<TrConcat<TrExtend<4000,TrInstant>,Stripes<2000,3000,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,Mix<Sin<Int<30>>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,Mix<Int<8192>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,TrFade<4000>>,LockupPulseF<SaberBase::LOCKUP_MELT>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<300>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,TrConcat<TrJoin<TrDelayX<Mult<RetractionTime<0>,Int<16384>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeInX<Mult<RetractionTime<0>,Int<16384>>>>,Black>>>(),
