Hello, I was wondering how I would use the light “rub pixel blade connector LED board” on the lightsaber proffieboard 3.9? As this came with the kit from 123 electronics and I can’t figure out what it is as there is no documentation on the 123 website.
I think we just talked about that one.
I’m looking at this
It is not an LED star, like a tri-cree (if that’s what you mean).
You can still use the V2.2 configurator as a guide. Where the strip is reprsented there are 3 wires:
The red wire goes to the + pads on the connector, closest to the edge.
The black wire goes t othe - pads on the connector, closer to the center.
The pink wire goes to the D2 pad.
I see two resitors on the connector, but only one D pad. This suggests that the LEDs on the surface of the connectore are wired in parallel with the blade data. One blade style should be enough for each preset.
The configuration tool will help.
https://fredrik.hubbe.net/lightsaber/v5/
Okay, thank you! Also thank you for helping my classmate out (he said you were the one who helped him earlier in the week)
