Proffieboard 2.2 repeating garbled static when plugged in (only audible part being sd card function after it finishes garbling
alright im back due to the chat limiter and my account being made recently its not charging at all anymore it works normally when both proffie and charging ports are plugged in but its not charging even plugging the wire into the charging port doesnt do anything but light up the power/charging indicator
Please use ponctuation. English is not my first language, and your last message is really hard to read.
At the moment, you are level0 (new/newbie account)
If you want to get get rid of that limitation and become level1:
  • click on the 3 bars on the top right corner,
  • click on ā€œMy Postsā€
  • click on ā€œMessagesā€
  • click on ā€œNew Messageā€
    • to: @discobot
    • text: start new user tutorial
    • follow the tutoral (5 minutes or less)
If you want to become level2:
Same as above except:
  • text: @discobot start advanced tutorial (5 to 10 minutes)
For your problem:
  • your charge port is broken
    or
  • you have a loose or broken wire somewhere between charge port and battery
Solution:
  • open your core
  • find and fix your broken wire
    or
  • as @Fett263 said:
or
  • get an external battery charger to fully charge your battery.
sorry about the punctuation i will reach out to my installer because i don’t have the necessary tools for soldering wires.
I should point out that there are also some requirements to read and write messages on the board to level up. The requirements for level 1 are very low, so it takes very little time, level 2 takes a little longer.
