#define NUM_BLADES 2
#define VOLUME 1750
#define CLASH_THRESHOLD_G 4.0
#define IDLE_OFF_TIME 60*2*1000
#define MOTION_TIMEOUT 60*10*1000
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN 17
#define SAVE_PRESET
#define FETT263_TWIST_ON
#include"../props/saber_sabertrio_buttons.h"
Preset blade[] = {
{ "1-SABERTRIO;common", "tracks/track_1.wav",
/* copyright Fett263 Simple (Primary Blade) OS6 Style
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), DodgerBlue, Animated(Moccasin)
Base Color: Rgb<2,72,255> (0)
Melt Effect: Responsive Melt
Blast Effect: Responsive Blast Fade (Large)
Clash Effect: Flash on Clash (Full Blade)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,199,119>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,199,119>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,199,119>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,199,119>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
StylePtr<WHITE>(), "Sabertrio"},
{ "2-DARK_EDITION;common", "tracks/track_2.wav",
OS6.7 v4.021
Base Style: HumpFlicker Large (Single Color (80%)), Red, Animated (Moccasin)
Base Color: Rgb<255,0,0> (0)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,120>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,
LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,
StylePtr<WHITE>(), "Dark Edition"},
{ "3-THE_LIGHT;common","tracks/track_3.wav",
OS6.7 v4.021
Base Style: Fallen Order Cal Kestis
Base Color: Rgb<0,255,255> (0)
Retraction Effect: SparkTip Retraction
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<200>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
StylePtr<WHITE>(), "The Light"},
{ "4-THE_DARK;common","tracks/track_5.wav",
StylePtr<Layers<
Mix<SmoothStep<Scale<SwingSpeed<400>,Int<6000>,Int<24000>>,Int<10000>>,Mix<Sin<Int<30>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>,RotateColorsX<Variation,Rgb<30,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>>,HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<125,0,0>>,40>>,
//Swing responsive humpflicker/rotating red/orange unstable base, unstable takes over the blade the harder you swing
//HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,
//Alternate plain humpflicker
AlphaL<AlphaL<AudioFlickerL<RotateColorsX<Variation,Rgb16<65535,8729,0>>>,SwingSpeed<350>>,SmoothStep<Scale<SwingSpeed<450>,Int<29000>,Int<9500>>,Int<16000>>>,
//Responsive edge audioflicker swing - starts at the tip and takes over the blade the harder you swing
LockupTrL<Layers<
AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<500>>,TrConcat<TrInstant,White,TrFade<600>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<65535,8729,0>>,TrFade<525>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<50>,RotateColorsX<Variation,Rgb16<35913,7294,0>>,TrFade<250>,StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,25,0>>,RotateColorsX<Variation,Rgb<60,15,0>>>,300>,RotateColorsX<Variation,Rgb<30,2,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TrFade<100>,RotateColorsX<Variation,Rgb16<20393,1818,0>>,TrBoing<950,3>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup with unstable cooldown
//AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrJoinR<TrWipe<100>,TrWipeIn<100>>,White,TrFade<3000>>,SaberBase::LOCKUP_NORMAL>,
//Alternate normal endlock effect
//Responsive lightning block
ResponsiveStabL<RotateColorsX<Variation,Orange>>,
//Responsive stab
//ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
//Alternate responsive blast
ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Responsive Clash
//ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
//Alternate white clash
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Orange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<70,25,5>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<75,20,5>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<65,15,0>>>>,TrFade<2500>,Stripes<3000,-2250,RotateColorsX<Variation,DarkOrange>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,15,0>>,RotateColorsX<Variation,Rgb<50,15,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<85,15,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<155,25,0>>,RotateColorsX<Variation,Rgb<95,15,0>>>>,TrFade<1000>,Stripes<3000,-1500,RotateColorsX<Variation,Rgb16<65535,8729,0>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<195,10,0>>,RotateColorsX<Variation,Rgb<55,5,0>>>,BrownNoiseFlicker<RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Rgb<185,10,0>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<255,13,0>>,RotateColorsX<Variation,Rgb<105,3,0>>>>,TrFade<2500>>,EFFECT_IGNITION>,
//Unstable ignition
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<255,75,0>>,40>,TrFade<500>>,EFFECT_RETRACTION>,
//Humpflicker retraction
//Drag
//Responsive melt
InOutTrL<TrWipeSparkTip<White,175,250>,TrColorCycle<500>>,
//Spark tip ignition, cycle down retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<White,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<500>,Int<5500>>,Int<-4000>>>,TrFade<1100>>,EFFECT_RETRACTION>,
//White flicker retraction effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<1600>,AlphaL<RotateColorsX<Variation,Orange>,Bump<Int<0>,Int<8000>>>,TrFade<1400>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrFade<1000>>,EFFECT_RETRACTION>,
//Emitter cool off retraction effect
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<2000>,Int<1000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb16<14386,0,0>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Red>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Red>>>,DarkOrange,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-1000>,Int<25000>>,Int<-4000>>>,TrDelay<6500>>,EFFECT_PREON>,
//Noise responsive preon
TransitionEffectL<TrConcat<TrDelay<3000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<115>,Int<400>,Int<250>,Int<0>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<215>,Int<300>,Int<395>,Int<0>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Red>,Int<345>,Int<200>,Int<500>,Int<0>>>,TrDelay<1500>,AlphaL<RotateColorsX<Variation,Red>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>,
//Charge up, wave out preon
TransitionEffectL<TrConcat<TrFade<1500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Red>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Orange>,15>,Bump<Int<0>,Int<5000>>>,TrFade<2500>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<500,2>>,EFFECT_PREON>
//Emitter heat up preon
StylePtr<WHITE>(), "The Dark"},
{ "8-MENACE;common", "tracks/track_9.wav",
OS6.7 v4.021
Base Style: HumpFlicker Small (Single Color (80%)), Red, Prequel (NavajoWhite)
StylePtr<Layers<
HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<26214>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,60>,
TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,187,108>>>,SmoothStep<IntArg<MELT_SIZE_ARG,30000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Int<14000>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,187,108>>>>,TrFade<300>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,187,108>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,187,108>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,187,108>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,187,108>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
StylePtr<WHITE>(), "Menace"},
{ "9-TEMPLE_GUARDIAN;common", "tracks/track_10.wav",
StylePtr<Layers<
StripesX<Sin<Int<4>,Int<3000>,Int<6000>>,Scale<TwistAngle<>,Int<-50>,Int<-100>>,StripesX<Sin<Int<3>,Int<1000>,Int<3000>>,Scale<TwistAngle<>,Int<25>,Int<80>>,Pulsing<RotateColorsX<Variation,Rgb<130,40,230>>,RotateColorsX<Variation,Rgb<75,0,165>>,3000>,Mix<Sin<Int<2>>,RotateColorsX<Variation,Rgb<75,0,165>>,RotateColorsX<Variation,Rgb<4,0,8>>>>,RotateColorsX<Variation,Rgb<22,0,49>>,Pulsing<RotateColorsX<Variation,Rgb<19,0,41>>,StripesX<Sin<Int<2>,Int<2000>,Int<4000>>,Sin<Int<2>,Int<25>,Int<75>>,Mix<Sin<Int<4>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<130,40,230>>>,RotateColorsX<Variation,Rgb<36,0,79>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<48,0,105>>,RotateColorsX<Variation,Rgb<19,0,41>>,3000>>,
AlphaL<StripesX<Sin<Int<8>,Int<3000>,Int<6000>>,Scale<TwistAngle<>,Int<60>,Int<140>>,StripesX<Sin<Int<6>,Int<1000>,Int<3000>>,Scale<TwistAngle<>,Int<-25>,Int<-80>>,Pulsing<Mix<Sin<Int<4>>,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Yellow>>,RotateColorsX<Variation,Rgb<7,0,16>>,4000>,Mix<Sin<Int<2>>,RotateColorsX<Variation,Rgb<130,40,230>>,Black>>,RotateColorsX<Variation,Rgb<22,0,49>>,Pulsing<RotateColorsX<Variation,Rgb<19,0,41>>,StripesX<Sin<Int<2>,Int<2000>,Int<4000>>,Sin<Int<2>,Int<-25>,Int<-75>>,Mix<Sin<Int<4>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<130,40,230>>>,RotateColorsX<Variation,Rgb<36,0,79>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<48,0,105>>,RotateColorsX<Variation,Rgb<19,0,41>>,3000>>,Int<10000>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
SparkleL<Green,40,400>,
ResponsiveStabL<Red>,
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
InOutTrL<TrJoinR<TrWipe<500>,TrWipeIn<500>>,TrJoinR<TrWipe<500>,TrWipeIn<500>>>,
TransitionEffectL<TrConcat<TrFade<800>,Layers<
Black,
AlphaL<HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Magenta>,30>,LayerFunctions<SmoothStep<Int<14384>,Int<-400>>,SmoothStep<Int<14384>,Int<1000>>>>,
AlphaL<Black,LayerFunctions<SmoothStep<Int<12000>,Int<-2000>>,SmoothStep<Int<20768>,Int<2000>>>>>,TrFade<2000>,Layers<
Black,
AlphaL<HumpFlicker<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<100,30,0>>,30>,LayerFunctions<SmoothStep<Int<15000>,Int<-400>>,SmoothStep<Int<15000>,Int<400>>>>,
AlphaL<Black,LayerFunctions<SmoothStep<Int<12000>,Int<-2000>>,SmoothStep<Int<20768>,Int<2000>>>>>,TrFade<2400>>,EFFECT_RETRACTION>,
TransitionEffectL<TrConcat<TrInstant,Layers<
AlphaL<TransitionLoopL<TrConcat<TrWaveX<Magenta,Int<300>,Int<90>,Int<600>,Int<500>>,Black,TrDelay<450>>>,SmoothStep<Int<16384>,Int<-100>>>,
AlphaL<TransitionLoopL<TrConcat<TrWaveX<Green,Int<275>,Int<200>,Int<600>,Int<300>>,Black,TrDelay<600>>>,SmoothStep<Int<384>,Int<3000>>>,
AlphaL<TransitionLoopL<TrConcat<TrWaveX<Green,Int<275>,Int<200>,Int<600>,Int<300>>,Black,TrDelay<600>>>,SmoothStep<Int<384>,Int<3000>>>>,TrDelay<2500>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<400>,AlphaL<Rgb<50,50,75>,Bump<Int<16384>,Int<4000>>>,TrFade<2000>,AlphaL<AudioFlickerL<Magenta>,Bump<Int<16384>,Int<16000>>>,TrDelay<200>>,EFFECT_PREON>>>()
StylePtr<WHITE>(), "Temple Guardian"},
{ "12-TEENSY_SF;common", "tracks/track_13.wav",
StylePtr<Layers<
StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,RotateColorsX<Variation,Rgb<10,0,0>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,RotateColorsX<Variation,Rgb<80,0,0>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,
LockupTrL<Layers<
ResponsiveStabL<Orange>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_RETRACTION>,
InOutTrL<TrWipeSparkTip<White,500>,TrWipeInSparkTip<White,550>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<3000>,AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<3000>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<2000>>,EFFECT_RETRACTION>,
TransitionEffectL<TrConcat<TrWipe<500>,AlphaL<HumpFlickerL<Red,10>,Bump<Int<0>,Int<50000>>>,TrWipeIn<500>,AlphaL<HumpFlickerL<Orange,15>,Bump<Int<0>,Int<40000>>>,TrFade<400>,AlphaL<HumpFlickerL<White,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>(),
StylePtr<WHITE>(), "TeensySF"},
{ "13-SMOOTH_JEDI;common", "tracks/track_14.wav",
StylePtr<Layers<Stripes<3500,-3000,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,Mix<Int<6425>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,White>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<200>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
StylePtr<WHITE>(), "Smooth Jedi"},
{ "14-SMOOTH_GREY;common", "tracks/track_15.wav",
OS6.7 v4.021
Base Style: Audio Rotoscope - Single Color (Sequels)
StylePtr<Layers<AudioFlicker<Stripes<14000,-4000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
StylePtr<WHITE>(), "Smooth Grey"},
{ "15-SMOOTH_FUZZ;common", "tracks/track_16.wav",
StylePtr<Layers<
Mix<SmoothStep<Int<16384>,Int<4000>>,Stripes<10000,500,Rgb<0,30,80>,Rgb<0,60,180>>,Stripes<10000,-500,Rgb<0,30,80>,Rgb<0,60,180>>>,
// Dim Blade 50% "Power Save" button combo
// Clash - 3 stage fading impact spot
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Moccasin,TrInstant,TrFade<300>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Int<18000>>>,TrFade<600>>,EFFECT_CLASH>,
// Stab
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<300>,AlphaL<Stripes<5000,1000,DarkOrange,Rgb<80,60,0>,Orange,Rgb<60,30,0>,Black,DarkOrange,Orange>,SmoothStep<Int<20000>,Int<2000>>>,TrJoin<TrSmoothFade<900>,TrWipe<700>>>,EFFECT_STAB>,
// Blast
MultiTransitionEffectL<TrConcat<TrDelay<700>,AlphaL<Black,Int<0>>,TrFade<800>,LocalizedClashL<HumpFlicker<DarkOrange,Red,50>,2000,50,EFFECT_BLAST>,TrFade<600>>,EFFECT_BLAST>,
LocalizedClashL<Blinking<White,Black,130,800>,1560,50,EFFECT_BLAST>,
LocalizedClashL<Blinking<Red,Black,130,500>,1560,15,EFFECT_BLAST>,
// Lockup
LockupTrL<Layers<
AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,
AlphaL<BrownNoiseFlicker<Yellow,Black,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,
TrConcat<TrInstant,
AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<100>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
// Non-Responsive Drag
LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>,
// Lightning Block
ResponsiveLightningBlockL<RandomFlicker<Strobe<White,Rgb16<21301,0,65535>,50,10>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>>,
//Begin Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>,TrFade<100>>,
//End Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>> >>,
// Melt
LockupTrL<
//Mely Colors
AlphaL<Mix<TwistAngle<>,Yellow,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,
// Melt Shape
SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,
//Melt Begin and End transitions
TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_MELT>,
// Ignition Powerup
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<DeepSkyBlue,White,100>,TrFade<800>>,EFFECT_IGNITION>,
// In/out using Trigger for instantaneous Center-out wipes
InOutTrL<TrConcat<TrInstant,Layers<
AlphaL<Black,SmoothStep<Scale<Trigger<EFFECT_IGNITION,Int<300>,Int<1000>,Int<500>>,Int<16385>,Int<0>>,Int<-1>>>,
AlphaL<Black,SmoothStep<Scale<Trigger<EFFECT_IGNITION,Int<300>,Int<1000>,Int<500>>,Int<16384>,Int<32768>>,Int<0>>>>,TrDelay<1000>>,TrJoin<TrWipe<700>,TrWipeIn<700>>>,
TransitionEffectL<TrConcat<TrInstant,Cyan,TrDelay<50>>,EFFECT_IGNITION>,
// Asteroid impacts after detonation - timed sequence
TrDelay<1500>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Red,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<3000>,Int<6000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<400>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Orange,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<6000>,Int<10000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<200>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Black,White,100>,Bump<ChangeSlowly<SlowNoise<Int<30000>>,Int<60000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<300>,AlphaL<Red,Int<0>>,
TrDelay<200>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Yellow,Red,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<10000>,Int<28000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<200>,AlphaL<Red,Int<0>>,
TrDelay<500>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Orange,White,100>,Bump<ChangeSlowly<SlowNoise<Int<30000>>,Int<60000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<200>,AlphaL<Red,Int<0>>,
TrDelay<100>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Red,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<5000>,Int<13000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<500>,GreenYellow,TrDelay<25>>,EFFECT_IGNITION>,
// Seismic Charge preon effect. use with linked preon sound
TransitionEffectL<TrConcat<TrDelay<2125>,Cyan,TrFade<100>,Black,TrDelay<10>,Cyan,TrFade<150> >,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<2125>,AlphaL<White,Bump<Int<16384>,Int<32768>>>,TrFade<100>, Black,TrDelay<10>,AlphaL<White,Bump<Int<16384>,Int<32768>>>,TrFade<150> >,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<2100>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<3000>>>,TrDelay<100>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<4000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<5000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<10000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,
TrSmoothFade<175>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<30000>>>,
TrSmoothFade<125>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<35000>>>,
TrSmoothFade<150>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<30000>>>,
TrSmoothFade<75>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<8000>>>,
TrSmoothFade<25>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<3000>>>,TrFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,TrDelay<25>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Scale<Trigger<EFFECT_PREON,Int<2000>,Int<1000>,Int<500>>,Int<-1000>,Int<16500>>,Int<1500>>>,TrDelay<2000>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<1100>,AlphaL<Red,Int<0>>,TrSmoothFade<700>,Black,TrDelay<100>,AlphaL<White,Bump<Int<16384>,Int<3000>>>,TrDelay<100>>,EFFECT_PREON>
StylePtr<WHITE>(), "Smooth Fuzz"},
{ "16-ROGUE_COMMANDER;common", "tracks/track_17.wav",
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
StylePtr<WHITE>(), "Rogue Commander"},
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>(),
CONFIGARRAY(blade)
