Tried 2 different v3.9 boards (both from Tritium and both work on 6.9). Ran both Arduino 2.1.3 as well as 1.8.13. Running the same test config on 6.9 works fine on Serial Monitor and WebUSB. Everything else works fine (so far that I’ve seen). But on 7.7, there is basically nothing happening on the serial monitor (just blank). WebUSB also does not load.
That sounds like some sort of buffer overflow somewhere.
I will try it and see if I get the same issue.
Can you tell me the exact settings you are using in Arduino → Tools?
Also, I assume you’re version 3.6.0 of the arduino-proffieboard plugin?
I just tested with a Tritium v3.9 board.
ProffieOS 6.7 serial monitor is good.
ProffieOS 7.7 serial monitor is blank.
ProffieOS 7.x master, serial monitor is good.
So far no luck.
It just works for me.
I did notice you have KEEP_SAVEFILES_WHEN_PROGRAMMING in your config file, which could potentially be causing problems. ProffieOS 6.9 would probably ignore the savefiles from ProffieOS 7.x though, since they don’t really look like save files.
I also looked through the differences between 7.7 and the github master, and there isn’t a whole lot, and none of them seem like they should affect the serial monitor.
My theory is that there is a bug somewhere which touches memory out of bounds, maybe in the serial code itself. But of course it could be something completely different.
So when the serial monitor doesn’t work, does anything else work? Does the LED pulse or blink?
Didn’t have any ini or tmp files on the SD cards tested. Removed the line from my config file but still the same issues. Also tried no SD card like Brian. Same results.
LED’s pulse in a sawtooth wave on 6.9. On 7.7, it pulses until you enter serial monitor or when Windows loads up the SD card’s content, at which point it just turns straight solid.
Neither “serial+webUSB” nor “Serial + WebUSB + Mass Storage” worked for serial monitor. With Mass Storage, Windows doesn’t even load up the SD card’s content.
Tried it in windows, but I still haven’t found anything that resembles this problem.
I do see problems when mass storage is on, and there is no SD card in the board.
Other than that it seems fine.
In fact, it seems weirdly too fine.
Somehow I can access the SD card from the serial monitor with the dir command AND also browse the content of the sd card from windows, which seems weird. Normally I would think I would have to eject the drive before I can list the contents from inside the serial monitor…
Just to try things out, I tried on my Mac and no dice there. WebUSB won’t load, Serial monitor is blank, and solid LED light. USPS finally found where they shipped my black v3 so I can test it on that though I doubt the results will be different.
