Hi, My new proffie isn’t making any swing or clash sounds. All other sounds that are triggered work (blaster, the force etc), and the hum works.
I uploaded a new config prior to actually installing the proffie into the chassis so unsure if this problem was there before and if I remember correctly the basis of that config was an ECO saber config (LGT saber are they called?) as I liked a few of the blade effects.
I’ve tried to google the issue and it looks like this is a common problem with those Eco Sabers, so hoping I’ve not caused an irreversible issue here?
I was asked to check out Serial Monitor but it’s like The Matrix and just spams this. I’m not sure what I’m seeing:
ACCEL: {-4.00, 4.00, 4.00} diff={0.22, 2.63, -1.19} v=2.90 fgl=0.02 accel_={-4.00, 4.00, 4.00} clear=0 millis=30948 swing_speed=4.18 mss={2.13, 25.80, -11.67} stab=0
Sounds like you’ve tried the things you’re supposed to try.
I think that means that you have a broken motion chip.
Contact the seller and ask for a replacement.
Hey Adam go check out my post as the solution came in the form of updating a command file to a newer version rather than the OS itself as that wasn’t the issue. If you still have issues figuring this out let me know and I’ll walk you through what I did to get my saber’s motion functions working again!
