i have followeed all the steps in this video, How to Upload Bladestyles to LGT Proffie Lightsabers - YouTube ecept that zadig wont find the SM32Bootoader. my pc somewhat recognises the proffieboard as it shows up in connnected devices. on arduino it also finds it as a port. when i try to compile my proffieos.ini i get the following error,
Arduino: 1.8.16 (Windows 10), Board: “Proffieboard V2, Serial + Mass Storage + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code”
c:/users/melvi/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 24 bytes
c:/users/melvi/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:\Users\melvi\AppData\Local\Temp\arduino_build_829331/ProffieOS.ino.elf section .text' will not fit in region
FLASH’
c:/users/melvi/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: region `FLASH’ overflowed by 10832 bytes
what does this mean and how can i fix this?
