Managed to finally get round to playing with this properly and now have a working prototype!
OS loaded on the Teensy board with zero errors and sounds etc are working as expected!! ![]()
Hoping someone may have some thoughts or solution on this.
My friend has been testing a unit and every now and then he says the audio kinda skips like a cd with a scratch in it.
He managed to get it on video which Iāve linked to below.
The audio is mono, 16bit, 41000.
**update - I recalled some audio config changes earlier in this thread that I just revisited.
Iām guessing this slipping (or clipping?) is related to it?
Is this a proffieboard or a Teensy-based unit?
Either way, this is pretty weird, because itās not a type of glitch that I recognize.
My guess is that this is a bad SD card block, and replacing the SD card might fix it, but it could be something completely differentā¦
Itās a teensey unit.
Ah interesting I didnāt think about the SD card.
Iāll look into that. Thankyou.
Is there any restrictions on what SD card should be used?
Or a recommended speed etc?
Unfortunately, what matters is the minimum speed, while SD card manufacturers only lists maximum speed.
Almost any new SD card should work, but there is always a chance you get a bad one. Personally I usually buy āsandisk industrialā cards, but thatās based more on faith than science or specifications. The idea is that āindustrialā cards might be optimized for long life, and that may also translate into reasonable minimum speeds. (Because usually, the thing that hurts speed is when some checksum doesnāt come out right and the card has to do complicated computations to correct it.)
Just following this up, I have some SanDisk cards arriving soon.
But I managed to catch the skipping in the serial monitor:
Do you know what the audio underflows is refering to?
unit = 1 vol = 0.50, Playing bank1/t7clk1.wav
Audio underflows: 116
Audio underflows: 202
Audio underflows: 200
Audio underflows: 43
Playing bank1/t5hldl.wav
~1000 per second, the sound playing interrupt wakes up and reads 44 samples from each active wav player. If any of the active wav players fail to produce 44 samples, the underflow counter is increased.
Each sound player has a 512-sample buffer, and any time there is any space in that buffer, a software interrupt is scheduled to fill it up. This buffer only lasts 11.6ms.
With a slow SD card, or very large directory structures, reading data from the SD card can take more than 11.5ms, in which case underflows will definitely occur, and if more sounds are playing at the same time, the tolerances get smaller.
Now, when you see hundreds of underflows, then the SD card is either completely stuck, or itās consistently too slow to be able to play sounds.
I recommend trying a different SD card.
Perfect, thankyou!
Itās kinda what I was thinking.
Appreciate the help!
So my SanDisk SD cards arrived just now so I did some testing via the serial monitor.
Old Card:
Time to open files: Average time: 12329.25 us
Time to read blocks: Average speed: 1626.42 kb/s, 18.44 simultaneous audio streams.
New Card:
Time to open files: Average time: 3249.41 us
Time to read blocks: Average speed: 1286.68 kb/s, 14.59 simultaneous audio streams.
Thatās kind of weird.
This is terrible, and will definitely cause audio glitches.
This is fine, and in fact better than the other card.
It could be that the problem is in the file structure of the card. Formatting it and putting the files back might fix it. Either that or there is a bad block somewhere in a directory listing slowing things down.
Ok. Thanks.
Think Iāll
Just ditch the old ones. Haha
Hey, all! New MiCom developer here!
Running the following on MacOS 14.6.1 (Sonoma):
- ProffieOS 7.14
- Proffieboard manager 3.6
- Teensy board manager 1.59.0
Here is my config file, similar to the other posted in this thread:
3bank_test_config.h (973 Bytes)
And Iām getting a handful of null pointer errors
errors.h (5.2 KB)
Thoughts?
Thanks in advance for any help!
All of these are warnings that can be ignored.
(I should fix these at some point. Last I checked the fix was rather ugly though.)
Thanks!
I uploaded the code to a Teensy 4.0 with audio shield, but still not getting any output.
Confirmed the memory card directory structure and sound files work properly as Iām just switching the memory card from an older MiCom that works fine, but the newer one isnāt playing the boot-up sound or anythingā¦
Any thoughts or additional information I could provide to help diagnose?
Well the obvious thing to test would be to the new code to the old hardware and see if it works or not. If it works, then the problem must be in the hardware somewhere, but if it doesnāt it must be in the code.
Unfortunately Iām not aware of a way to back up the programming on a teensy, so if the old one stops working, it would not work until the bugs are fixed I would think.
Yeah, I had the same thought but donāt want to risk bricking my working unit.
Iāll keep diggingā¦
I tested ProffieOS 7.14 with teensyduino 1.59.0 on my micom prototype, and it seems to work just fine. The font I have doesnāt have a boot sound, so it doesnāt do anything when you boot it, but pressing buttons work and so does the ābeepā command in the serial monitor.
Thanks! Which config file were you using?
This one:
