Hi @profezzorn,
Thought it would be cleaner to keep all bugs/adjustments needed in one thread vs making several posts. With the latest update I am having an issue with the Question (Directory function). If I hit a question I can get responses to play after, however (this only applies to a trigger 1 response “tnclka1” it will keep repeating, the directory doesn’t clear unless I hit “cancel” trigger 8.
Example:
- I hit trigger 5 “t5clk1” for a question
- I then hit trigger 1 “t5clka1” for a response to that question
- If I hit trigger 1 again, I am wanting t1clkn but instead I get the question response “t5clka1” until I hit cancel
I will be emailing you our new Vader template so you can demo/play with the fun set up.
Cheers,
Mike
