Just downloaded ProffieOS from github and set it up. Everything compiles correctly, and the Teensy Loader comes up. This is on IDE 1.8.16 and Teensyduino 1.55, so the most recent software. Wasn’t there changes made to other files specifically for the amplifier and such though? Just wanted to make sure I this current download of ProffieOS has everything except the MiCom specific config files.
It should have everything. It has an example micom config file too.
Pulled the MiCom 3,5, and 10 bank config files from our previous ProffieOS master and put them in the config folder on the most recent version I just got from github. Also, checked the amplifier file and it looks like it’s set to the 0.7 you guys had mentioned above. Ran a sketch compile through Proffieboard and Teensy 4.0 and both compile, so I believe all should be good to go!
I believe we just needed to keep this value at .7 in the amplifier.h
Yep, it looks like that change has been made and saved. I wasn’t sure if there were any other “behind the scenes” changes that were made and not updated, but it looks like besides just not having the specific config files everything is ready to rock.
Please review the rules for this forum.
Screenshots are NOT ALLOWED if cut-n-paste will work.
Please update the post, or I will delete it.
PS: In this case, posting a link to that line in github would be sufficient I think:
I didn’t want to wait, so I edit the post myself.
Thank you @profezzorn
I’m having troubles compiling on OS 7.8 for the Teensy 4.0.
Here is my error message:
Arduino: 1.8.19 (Windows 10), TD: 1.58, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:46,
from C:\Users\tomti\AppData\Local\Temp\arduino_build_700459/pch/Arduino.h:6,
from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:162:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:164:17: error: expected unqualified-id before '{' token
164 | #define abs(x) ({ \
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:164:17: error: expected ')' before '{' token
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:167:2: error: expected unqualified-id before ')' token
167 | })
167 | })
In file included from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\filter.h:3,
from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\dac.h:4,
from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\sound.h:12,
from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:432:
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'std::complex<_Tp> std::__complex_log(const std::complex<_Tp>&)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:805:26: error: expected primary-expression before '(' token
805 | { return complex<_Tp>(log(std::abs(__z)), std::arg(__z)); }
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:164:16: error: expected unqualified-id before '(' token
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:165:3: error: expected primary-expression before 'typeof'
165 | typeof(x) _x = (x); \
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:165:3: error: expected '}' before 'typeof'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:164:17: note: to match this '{'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:165:3: error: expected ')' before 'typeof'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:164:16: note: to match this '('
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:166:4: error: '_x' was not declared in this scope
166 | (_x > 0) ? _x : -_x; \
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: At global scope:
167 | })
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:823:12: error: 'complex' does not name a type
823 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:828:12: error: 'complex' does not name a type
828 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:834:12: error: 'complex' does not name a type
834 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:858:12: error: 'complex' does not name a type
858 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:864:12: error: 'complex' does not name a type
864 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:888:12: error: 'complex' does not name a type
888 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:895:5: error: 'complex' does not name a type
895 | complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:932:12: error: 'complex' does not name a type
932 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:939:12: error: 'complex' does not name a type
939 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:959:12: error: 'complex' does not name a type
959 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:967:12: error: 'complex' does not name a type
967 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:987:12: error: 'complex' does not name a type
987 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:996:5: error: 'complex' does not name a type
996 | complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1018:12: error: 'complex' does not name a type
1018 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1027:5: error: 'complex' does not name a type
1027 | complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1042:12: error: 'complex' does not name a type
1042 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1066:12: error: 'complex' does not name a type
1066 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1072:12: error: 'complex' does not name a type
1072 | inline complex<_Tp>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1083:11: error: 'complex' is not a class template
1083 | class complex<float>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1084:5: error: explicit specialization of non-template 'complex'
1084 | {
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1101:49: error: 'complex' is not a template
1101 | explicit _GLIBCXX_CONSTEXPR complex(const complex<double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1102:49: error: 'complex' is not a template
1102 | explicit _GLIBCXX_CONSTEXPR complex(const complex<long double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1102:35: error: 'constexpr complex::complex(const complex&)' cannot be overloaded with 'constexpr complex::complex(const complex&)'
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1101:35: note: previous declaration 'constexpr complex::complex(const complex&)'
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1179:25: error: 'complex' is not a template
1179 | operator=(const complex<_Tp>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1188:26: error: 'complex' is not a template
1188 | operator+=(const complex<_Tp>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1196:26: error: 'complex' is not a template
1196 | operator-=(const complex<_Tp>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1204:26: error: 'complex' is not a template
1204 | operator*=(const complex<_Tp>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1213:26: error: 'complex' is not a template
1213 | operator/=(const complex<_Tp>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1229:11: error: 'complex' is not a class template
1229 | class complex<double>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1229:25: error: 'complex' is not a template
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1083:11: note: previous declaration here
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1375:11: error: 'complex' is not a class template
1375 | class complex<long double>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1375:30: error: 'complex' is not a template
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1523:3: error: 'complex' is not a template
1523 | complex<float>::complex(const complex<double>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1523:33: error: 'complex' is not a template
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1523:53: error: 'complex complex(const complex&)' should have been declared inside '::'
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr complex complex(const complex&)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1524:5: error: only constructors take member initializers
1524 | : _M_value(__z.__rep()) { }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1524:29: error: no return statement in 'constexpr' function returning non-void
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1527:3: error: 'complex' does not name a type
1527 | complex<float>::complex(const complex<long double>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1531:3: error: 'complex' does not name a type
1531 | complex<double>::complex(const complex<long double>& __z)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1538:19: error: 'istream' is not a template function
1538 | extern template istream& operator>>(istream&, complex<float>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1538:26: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1539:19: error: 'ostream' is not a template function
1539 | extern template ostream& operator<<(ostream&, const complex<float>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1539:26: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1540:19: error: 'istream' is not a template function
1540 | extern template istream& operator>>(istream&, complex<double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1540:26: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1541:19: error: 'ostream' is not a template function
1541 | extern template ostream& operator<<(ostream&, const complex<double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1541:26: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1542:19: error: 'istream' is not a template function
1542 | extern template istream& operator>>(istream&, complex<long double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1542:26: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1543:19: error: 'ostream' is not a template function
1543 | extern template ostream& operator<<(ostream&, const complex<long double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1543:26: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1546:19: error: 'wistream' is not a template function
1546 | extern template wistream& operator>>(wistream&, complex<float>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1546:27: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1547:19: error: 'wostream' is not a template function
1547 | extern template wostream& operator<<(wostream&, const complex<float>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1547:27: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1548:19: error: 'wistream' is not a template function
1548 | extern template wistream& operator>>(wistream&, complex<double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1548:27: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1549:19: error: 'wostream' is not a template function
1549 | extern template wostream& operator<<(wostream&, const complex<double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1549:27: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1550:19: error: 'wistream' is not a template function
1550 | extern template wistream& operator>>(wistream&, complex<long double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1550:27: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1551:19: error: 'wostream' is not a template function
1551 | extern template wostream& operator<<(wostream&, const complex<long double>&);
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1551:27: error: expected ';' before '&' token
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1558:1: error: expected declaration before '}' token
1558 | } // namespace
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function '_Tp std::fabs(const std::complex<_Tp>&)':
167 | })
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1930:10: error: 'complex' does not name a type
1930 | inline complex<float>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1939:10: error: 'complex' does not name a type
1939 | inline complex<double>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1948:10: error: 'complex' does not name a type
1948 | inline complex<long double>
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'std::complex<typename __gnu_cxx::__promote<_Tp>::__type> proj(_Tp)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1969:19: error: 'proj' is not a member of 'std'; did you mean 'proj'?
1969 | return std::proj(std::complex<__type>(__x));
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1966:5: note: 'proj' declared here
1966 | proj(_Tp __x)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1990:33: error: return type 'class std::complex<float>' is incomplete
1990 | operator""if(long double __num)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""if(long double)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1991:63: error: too many initializers for 'std::complex<float>'
1991 | { return std::complex<float>{0.0F, static_cast<float>(__num)}; }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1994:40: error: return type 'class std::complex<float>' is incomplete
1994 | operator""if(unsigned long long __num)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""if(long long unsigned int)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1995:63: error: too many initializers for 'std::complex<float>'
1995 | { return std::complex<float>{0.0F, static_cast<float>(__num)}; }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1998:32: error: return type 'class std::complex<double>' is incomplete
1998 | operator""i(long double __num)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""i(long double)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:1999:64: error: too many initializers for 'std::complex<double>'
1999 | { return std::complex<double>{0.0, static_cast<double>(__num)}; }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2002:39: error: return type 'class std::complex<double>' is incomplete
2002 | operator""i(unsigned long long __num)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""i(long long unsigned int)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2003:64: error: too many initializers for 'std::complex<double>'
2003 | { return std::complex<double>{0.0, static_cast<double>(__num)}; }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2006:33: error: return type 'class std::complex<long double>' is incomplete
2006 | operator""il(long double __num)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""il(long double)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2007:49: error: too many initializers for 'std::complex<long double>'
2007 | { return std::complex<long double>{0.0L, __num}; }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2010:40: error: return type 'class std::complex<long double>' is incomplete
2010 | operator""il(unsigned long long __num)
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""il(long long unsigned int)':
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2011:75: error: too many initializers for 'std::complex<long double>'
2011 | { return std::complex<long double>{0.0L, static_cast<long double>(__num)}; }
c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\11.3.1\complex:2020:1: error: expected declaration before '}' token
2020 | } // namespace
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\filter.h:25:20: note: in expansion of macro 'abs'
25 | constexpr double abs() const { return sqrt(len2()); }
167 | })
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\filter.h: In static member function 'static constexpr double Filter::BLT<T>::gain_from_pole(size_t)':
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\filter.h:77:32: note: in expansion of macro 'abs'
77 | return (C(2) - T::pole(k)).abs();
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:165:11: error: expected primary-expression before ')' token
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\filter.h: In static member function 'static constexpr double Filter::BLT<T>::gain_from_zero(size_t)':
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\sound\filter.h:80:32: note: in expansion of macro 'abs'
80 | return (C(2) - T::zero(k)).abs();
In file included from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\styles\transition_pulse.h:4,
from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:498:
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\transitions\concat.h: At global scope:
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\transitions\concat.h:157:64: warning: 'this' pointer is null [-Wnonnull]
157 | static_assert(std::is_same<decltype(((Black*)nullptr)->getColor(0).c.r), uint16_t>::value, "getcolor has changed...");
In file included from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:462:
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\styles\rgb.h:33:15: note: in a call to non-static member function 'SimpleColor Rgb<R, G, B>::getColor(int) [with int R = 0; int G = 0; int B = 0]'
33 | SimpleColor getColor(int led) {
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\transitions\wave.h: In member function 'decltype (MixColors(a, ((TrWaveX<COLOR, FADEOUT_MS, WAVE_SIZE, WAVE_MS, WAVE_CENTER>*)this)->TrWaveX<COLOR, FADEOUT_MS, WAVE_SIZE, WAVE_MS, WAVE_CENTER>::color_.getColor(led), 1, 1)) TrWaveX<COLOR, FADEOUT_MS, WAVE_SIZE, WAVE_MS, WAVE_CENTER>::getColor(const A&, const B&, int)':
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\transitions\wave.h:49:21: note: in expansion of macro 'abs'
49 | int dist = std::abs(center_ - led * 32768 / num_leds_);
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\transitions\wave.h: In member function 'decltype (MixColors(a, ((TrSparkX<COLOR, SPARK_SIZE, SPARK_MS, SPARK_CENTER>*)this)->TrSparkX<COLOR, SPARK_SIZE, SPARK_MS, SPARK_CENTER>::color_.getColor(led), 1, 1)) TrSparkX<COLOR, SPARK_SIZE, SPARK_MS, SPARK_CENTER>::getColor(const A&, const B&, int)':
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\transitions\wave.h:100:21: note: in expansion of macro 'abs'
100 | int dist = std::abs(center_ - led * 32768 / num_leds_);
In file included from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:239:
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\stdout.h: In instantiation of 'struct PrintHelper<Vec3, void>':
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\stdout.h:63:24: required from 'ConsoleHelper& ConsoleHelper::operator<<(T) [with T = Vec3]'
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\fuse.h:74:5: required from here
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\stdout.h:40:69: warning: 'this' pointer is null [-Wnonnull]
40 | template<typename T> struct PrintHelper<T, decltype(((T*)0)->printTo(*(Print*)0))> {
In file included from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:346:
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\vec3.h:121:8: note: in a call to non-static member function 'void Vec3::printTo(Print&)'
121 | void printTo(Print& p) {
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\stdout.h: In instantiation of 'struct PrintHelper<Quat, void>':
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\stdout.h:63:24: required from 'ConsoleHelper& ConsoleHelper::operator<<(T) [with T = Quat]'
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\fuse.h:134:5: required from here
In file included from C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\ProffieOS.ino:347:
C:\Users\tomti\OneDrive\Desktop\7.8\ProffieOS\common\quat.h:116:8: note: in a call to non-static member function 'void Quat::printTo(Print&)'
116 | void printTo(Print& p) {
Multiple libraries were found for "SD.h"
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Error compiling for board Teensy 4.0.
here is my config file:
#include "teensy_audio_board_rev_d.h"
#define NUM_BLADES 0
#define NUM_BUTTONS 8
#define VOLUME 2500
#define CLASH_THRESHOLD_G 2.0
#define ENABLE_DEVELOPER_COMMANDS
#include "../props/micom.h"
{ "bank1", "", ""},
{ "bank2", "", ""},
{ "bank3", "", ""},
BladeConfig blades[] = { { 0, CONFIGARRAY(presets) }, };
Button Bt1(BUTTON_TRIGGER_ONE, trigger1Pin, "b1");
Button Bt2(BUTTON_TRIGGER_TWO, trigger2Pin, "b2");
Button Bt3(BUTTON_TRIGGER_THREE, trigger3Pin, "b3");
Button Bt4(BUTTON_TRIGGER_FOUR, trigger4Pin, "b4");
Button Bt5(BUTTON_TRIGGER_FIVE, trigger5Pin, "b5");
Button Bt6(BUTTON_TRIGGER_SIX, trigger6Pin, "b6");
Button Bt7(BUTTON_TRIGGER_SEVEN, trigger7Pin, "b7");
Button Bt8(BUTTON_TRIGGER_EIGHT, trigger8Pin, "b8");
Updated to Arduino 2.1.1 and latest Teensyduino, same errors basically. Restarted my computer. Ugggh.
Looks like the teensy library has a bad abs() implementation.
Let me see if I can fix it…
I’m wondering if maybe some older teensyduino installation is lingering on your computer. It looks like the abs() issue was fixed in teensyduino 10 months ago.
Also, teensyduino doesn’t install in this directory anymore:
Instead it installs in the arduino15 directory, just like the arduino-proffieboard plugin.
possibly, I’ll try and figure out how to get rid of old teensyduino stuff. Delete all in that folder you think?
Try uninstalling first, if that doesn’t work, go zap it.
Total fresh install, wiped the app data/local/arduino15/packages folder out after uninstall of arduino.
Re-installed arduino 2.1.1 and Teensyduino plugin, as well as proffieboard plugin 3.6:
Errors:
In file included from C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/WProgram.h:46,
from C:\Users\tomti\AppData\Local\Temp\arduino\sketches\03C5F54233942A19B63CF23D5171F82B/pch/Arduino.h:6,
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:164:17: error: expected unqualified-id before '{' token
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:164:17: error: expected ')' before '{' token
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:167:2: error: expected unqualified-id before ')' token
167 | })
167 | })
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'std::complex<_Tp> std::__complex_log(const std::complex<_Tp>&)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:805:26: error: expected primary-expression before '(' token
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:164:16: error: expected unqualified-id before '(' token
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:165:3: error: expected primary-expression before 'typeof'
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:165:3: error: expected '}' before 'typeof'
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:164:17: note: to match this '{'
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:165:3: error: expected ')' before 'typeof'
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:164:16: note: to match this '('
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:166:4: error: '_x' was not declared in this scope
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: At global scope:
167 | })
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:823:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:828:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:834:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:858:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:864:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:888:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:895:5: error: 'complex' does not name a type
895 | complex<_Tp>
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:932:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:939:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:959:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:967:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:987:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:996:5: error: 'complex' does not name a type
996 | complex<_Tp>
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1018:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1027:5: error: 'complex' does not name a type
1027 | complex<_Tp>
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1042:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1066:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1072:12: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1083:11: error: 'complex' is not a class template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1084:5: error: explicit specialization of non-template 'complex'
1084 | {
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1101:49: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1102:49: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1102:35: error: 'constexpr complex::complex(const complex&)' cannot be overloaded with 'constexpr complex::complex(const complex&)'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1101:35: note: previous declaration 'constexpr complex::complex(const complex&)'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1179:25: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1188:26: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1196:26: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1204:26: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1213:26: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1229:11: error: 'complex' is not a class template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1229:25: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1083:11: note: previous declaration here
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1375:11: error: 'complex' is not a class template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1375:30: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1523:3: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1523:33: error: 'complex' is not a template
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1523:53: error: 'complex complex(const complex&)' should have been declared inside '::'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr complex complex(const complex&)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1524:5: error: only constructors take member initializers
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1524:29: error: no return statement in 'constexpr' function returning non-void
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1527:3: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1531:3: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1538:19: error: 'istream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1538:26: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1539:19: error: 'ostream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1539:26: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1540:19: error: 'istream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1540:26: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1541:19: error: 'ostream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1541:26: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1542:19: error: 'istream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1542:26: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1543:19: error: 'ostream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1543:26: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1546:19: error: 'wistream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1546:27: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1547:19: error: 'wostream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1547:27: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1548:19: error: 'wistream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1548:27: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1549:19: error: 'wostream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1549:27: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1550:19: error: 'wistream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1550:27: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1551:19: error: 'wostream' is not a template function
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1551:27: error: expected ';' before '&' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1558:1: error: expected declaration before '}' token
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function '_Tp std::fabs(const std::complex<_Tp>&)':
167 | })
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1930:10: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1939:10: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1948:10: error: 'complex' does not name a type
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'std::complex<typename __gnu_cxx::__promote<_Tp>::__type> proj(_Tp)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1969:19: error: 'proj' is not a member of 'std'; did you mean 'proj'?
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1966:5: note: 'proj' declared here
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1990:33: error: return type 'class std::complex<float>' is incomplete
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""if(long double)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1991:63: error: too many initializers for 'std::complex<float>'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1994:40: error: return type 'class std::complex<float>' is incomplete
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""if(long long unsigned int)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1995:63: error: too many initializers for 'std::complex<float>'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1998:32: error: return type 'class std::complex<double>' is incomplete
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""i(long double)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:1999:64: error: too many initializers for 'std::complex<double>'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2002:39: error: return type 'class std::complex<double>' is incomplete
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""i(long long unsigned int)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2003:64: error: too many initializers for 'std::complex<double>'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2006:33: error: return type 'class std::complex<long double>' is incomplete
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""il(long double)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2007:49: error: too many initializers for 'std::complex<long double>'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2010:40: error: return type 'class std::complex<long double>' is incomplete
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex: In function 'constexpr void literals::complex_literals::operator""il(long long unsigned int)':
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2011:75: error: too many initializers for 'std::complex<long double>'
c:\users\tomti\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\complex:2020:1: error: expected declaration before '}' token
167 | })
C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\cores\teensy4/wiring.h:165:11: error: expected primary-expression before ')' token
Used: C:\Users\tomti\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.58.1\libraries\SD
Not used: C:\Users\tomti\AppData\Local\Arduino15\libraries\SD
Ok, let me upgrade mine and see if I get the same thing…
Ok, I have two fixes on github master:
and:
You can download github master, or apply these fixes to your ProffieOS and it should hopefully work better.
thank you Fredrik! MiCom is not dead yet, TrooperCom is possibly going to resurrect it!
Still popping something from motion folder:
In file included from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\styles\transition_pulse.h:4,
from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\ProffieOS.ino:514:
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\transitions\concat.h:157:64: warning: 'this' pointer is null [-Wnonnull]
In file included from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\ProffieOS.ino:478:
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\styles\rgb.h:33:15: note: in a call to non-static member function 'SimpleColor Rgb<R, G, B>::getColor(int) [with int R = 0; int G = 0; int B = 0]'
In file included from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\ProffieOS.ino:1431:
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\motion\lsm6ds3h.h: In member function 'virtual void LSM6DS3H::Loop()':
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\motion\lsm6ds3h.h:177:11: error: 'motionSensorInterruptPin' was not declared in this scope
177 | if (motionSensorInterruptPin != -1) {
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\motion\lsm6ds3h.h:206:13: error: 'motionSensorInterruptPin' was not declared in this scope
206 | if (motionSensorInterruptPin == -1) {
In file included from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\ProffieOS.ino:255:
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\stdout.h: In instantiation of 'struct PrintHelper<Vec3, void>':
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\stdout.h:63:24: required from 'ConsoleHelper& ConsoleHelper::operator<<(T) [with T = Vec3]'
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\fuse.h:74:5: required from here
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\stdout.h:40:69: warning: 'this' pointer is null [-Wnonnull]
In file included from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\ProffieOS.ino:362:
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\vec3.h:121:8: note: in a call to non-static member function 'void Vec3::printTo(Print&)'
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\stdout.h: In instantiation of 'struct PrintHelper<Quat, void>':
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\stdout.h:63:24: required from 'ConsoleHelper& ConsoleHelper::operator<<(T) [with T = Quat]'
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\fuse.h:134:5: required from here
In file included from C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\ProffieOS.ino:363:
C:\Users\tomti\OneDrive\Desktop\7.8x\ProffieOS\common\quat.h:116:8: note: in a call to non-static member function 'void Quat::printTo(Print&)'
Compilation error: 'motionSensorInterruptPin' was not declared in this scope
