LED Behavior Odd on 2 strips out of 4
(Moved to Proffieboard category, had dropped this in off topic)
When I first ignited my zig zig quad blade, the LEDs lit as they should on two sides and then only 4 LEDS were it on side 3 and none on side 4. I pressed down on the strip on the last lit LED, and the whole blade acted normally until I cut power. This was repeatable.
After I reflowed the power lines and swapped the data lines entirely I got new behaviors:
strip 1,2,4 fine and strip 3 was red (should be a blue)
strip 1,2 fine, strip 3 lit partially with seeming random color, strip 4 off
strip 1,2,4 fine Strip 3 fine near the hilt, random colors for 10 pixels or so, then fine again
So I reflashed the board, and those first two strips are still good but 3/4 are still wonky.
And here’s my config which has #define SHARED_POWER_PINS and a blade array you fine folks have already helped with. I used the config helper initially. The first style is profezzorn and not in fett263’s library but the rest are generated from therel.
// ProffieOS7 Config File - Steampunk Cane
#define NUM_BLADES 4
const unsigned int maxLedsPerStrip = 439;
#define VOLUME 1500
#define CLASH_THRESHOLD_G 3
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define SAVE_PRESET
#define FETT263_DISABLE_MULTI_BLAST_TOGGLE
#define FETT263_DISABLE_QUOTE_PLAYER
#define FETT263_STAB_ON
#define FETT263_STAB_ON_NO_BM
{ "HallowBeam;common", "common/tracks/earlymansionmusic.wav",
//Profezzorn's Fireflies
StylePtr<Layers<
  InOutTr<Rgb16<1982,1,9304>,TrFade<3000>,TrFade<3000>>,
  TransitionLoop<AlphaL<Black,Int<0>>,TrDoEffect<TrDelay<500>,EFFECT_USER1>>,
  MultiTransitionEffectL<TrConcat<TrFade<3000>,AlphaL<Yellow,Bump<EffectPosition<>,Int<1000>>>,TrFade<3000>>,EFFECT_USER1,24>>>(),
StylePtr<Layers<
StylePtr<Layers<
StylePtr<Layers<
"PurpleFireflies"},
{ "StarTrekTNG;common", "common/tracks/StarTrekTNG.wav",
/* copyright Fett263 SmokeBlade (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#SmokeBlade
OS7.14 v2.242p
Base Style: Smoke Blade
Base Color: BaseColorArg (0)
Preon Effect: Overload [Color: PreonColorArg]
Ignition Effect: Twin Suns Out [Color: IgnitionColorArg]
Retraction Effect: Multi-Point In [Color: RetractionColorArg]
Lockup Effect: NoneLightning Block Effect:
0: mainLBMulti0Shape - Begin: Center Impact - Style: Strobing AudioFlicker - End: Dissipate Up
[Color: Rgb<96,71,41>]
Drag Effect: NoneMelt Effect: NoneBlast Effect: Blast Fade (Sound Based) [Color: BlastColorArg]
Clash Effect: Flash on Clash (Full Blade) [Color: ClashColorArg]
Emitter Effect: Random Pulse [Color: EmitterColorArg]
StylePtr<Layers<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,1200>,Mix<SwingSpeed<200>,Mix<Int<16000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Black>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Pulsing<Mix<Int<6425>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,2000>,Pulsing<Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<642>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,3000>>,AlphaL<StaticFire<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<256>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,0,1,10,2000,2>,Int<10000>>>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,0,0>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<255,0,0>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,14,0>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,14,0>>>>,TrFade<300>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<78,64,29>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AlphaL<Strobe<Rgb<96,71,41>,AudioFlicker<Rgb<96,71,41>,Blue>,50,1>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrExtend<200,TrInstant>,AlphaL<Rgb<96,71,41>,Bump<Int<16000>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,AlphaL<Rgb<96,71,41>,Int<0>>,TrWaveX<Rgb<96,71,41>,Int<300>,Int<100>,Int<400>,Int<0>>>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<0>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<16384>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<32768>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>>>,TrDelayX<IgnitionTime<300>>>,TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<6144>,Scale<Trigger<EFFECT_RETRACTION,RetractionTime<0>,RetractionTime<0>,Int<0>>,Int<0>,Int<12288>>>,LinearSectionF<Int<16384>,Scale<Trigger<EFFECT_RETRACTION,RetractionTime<0>,RetractionTime<0>,Int<0>>,Int<0>,Int<12288>>>,LinearSectionF<Int<26624>,Scale<Trigger<EFFECT_RETRACTION,RetractionTime<0>,RetractionTime<0>,Int<0>>,Int<0>,Int<12288>>>>>,TrDelayX<RetractionTime<0>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,14,0>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,14,0>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,14,0>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>>>(),
OS7.14 v2.242p
OS7.14 v2.242p
OS7.14 v2.242p
"BoldlyGone"},
{ "thingy;common",  "common/tracks/Addams.wav",
OS7.14 v2.242p
Split Blade (25/75)
Default: Fire Blade Slow (Normal) [BaseColorArg]
1: Live Action Darksaber (Hyper-Responsive) [AltColorArg]
Preon Effect: Power Absorb [Color: AltColorArg]
Ignition Effect: Wipe In [Color: IgnitionColorArg]
Retraction Effect: Run Up [Color: RetractionColorArg]
[Color: BaseColorArg]
Drag Effect: NoneMelt Effect: NoneStab Effect: Normal Stab [Color: BaseColorArg]
Blast Effect: Blast Wave (Random) [Color: BaseColorArg]
Clash Effect: Random Clash with Wave [Color: BaseColorArg]
StylePtr<Layers<Mix<SmoothStep<Int<8192>,Int<16384>>,Remap<InvertF<RampF>,StaticFire<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>>,0,1,0,2000,2>>,Remap<InvertF<RampF>,Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<2000>,Int<4000>>,Int<8000>>,HumpFlicker<RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>,Stripes<35000,-200,Mix<Int<14000>,Black,RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<24000>,Black,RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<28000>,Black,RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>>>,100>,RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrWaveX<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<ClashImpactF<>,Int<28000>,Int<8000>>>,EFFECT_CLASH>,ResponsiveLightningBlockL<Strobe<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,TrFade<400>>,Int<1>>,InOutTrL<TrWipeInX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<AudioFlickerL<RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrLoopN<8,TrSparkX<RgbArg<ALT_COLOR_ARG,Rgb<100,100,150>>,Int<200>,Divide<WavLen<EFFECT_PREON>,Int<8>>,Int<32768>>>>,EFFECT_PREON>>>(),
OS7.14 v2.242p
Split Blade (25/75)
OS7.14 v2.242p
Split Blade (25/75)
OS7.14 v2.242p
Split Blade (25/75)
"Addams"},
{"Fire;common", "common/tracks/SMTunnel.wav",
/* copyright Fett263 FireBlade (Primary Blade) OS7 Style
https://www.fett263.com/fett263-proffieOS7-style-library.html#FireBlade
OS7.14 v2.242p
Base Style: Fire Blade Slow (Normal)
Base Color: BaseColorArg (Rolling Rainbow Up) Style Mod: Invert
Ignition Effect: Fade Up [Color: IgnitionColorArg]
Retraction Effect: Fade Out [Color: RetractionColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect: NoneStab Effect: Normal Stab [Color: BlastColorArg]
Clash Effect: Real Clash V1 [Color: BlastColorArg]
Swing Effect: Interactive Fireball (Force Recharge) [Color: AltColor3Arg]
Special Ability 1: Toggle Rain Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped)
Swing Option 0- Interactive Fireball (Force Recharge) Interactive Control: Force to recharge, Swing to throw Fireball, recharge after use.
StylePtr<Layers<Remap<InvertF<RampF>,StaticFire<RotateColorsX<Saw<Int<15>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<10280>,Black,RotateColorsX<Saw<Int<15>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>>>,0,1,0,2000,2>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<85,85,200>>,SparkleF<300,800>>>,AlphaL<AlphaMixL<SmoothStep<IncrementWithReset<Scale<IsGreaterThan<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<18000>>,Int<0>,ThresholdPulseF<StrobeF<Scale<HoldPeakF<Ifon<SwingAcceleration<>,Int<0>>,Int<150>,Int<32000>>,Int<40>,Int<400>>,Int<1>>,Int<32000>>>,EffectPulseF<EFFECT_FORCE>,Int<42000>,Int<1500>>,Scale<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<3000>,Int<10000>>>,HumpFlicker<RotateColorsX<Int<1400>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<3200>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,20>,HumpFlicker<RotateColorsX<Int<1000>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<400>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,60>,RandomFlicker<Mix<Int<16384>,Black,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>>,LinearSectionF<IncrementWithReset<Scale<IsGreaterThan<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<18000>>,Int<0>,ThresholdPulseF<StrobeF<Scale<HoldPeakF<Ifon<SwingAcceleration<>,Int<0>>,Int<150>,Int<32000>>,Int<40>,Int<400>>,Int<1>>,Int<32000>>>,ThresholdPulseF<IsLessThan<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<8000>>,Int<32000>>,Int<42000>,Int<1500>>,Scale<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<3000>,Int<10000>>>>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaL<Strobe<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,AudioFlicker<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Blue>,50,1>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,TrFade<400>>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.14 v2.242p
Drag Effect:
StylePtr<Layers<Remap<InvertF<RampF>,StaticFire<RotateColorsX<Saw<Int<15>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<10280>,Black,RotateColorsX<Saw<Int<15>>,Gradient<RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<-4000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<-8000>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>>>>,0,1,0,2000,2>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<85,85,200>>,SparkleF<300,800>>>,AlphaL<AlphaMixL<SmoothStep<IncrementWithReset<Scale<IsGreaterThan<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<18000>>,Int<0>,ThresholdPulseF<StrobeF<Scale<HoldPeakF<Ifon<SwingAcceleration<>,Int<0>>,Int<150>,Int<32000>>,Int<40>,Int<400>>,Int<1>>,Int<32000>>>,EffectPulseF<EFFECT_FORCE>,Int<42000>,Int<1500>>,Scale<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<3000>,Int<10000>>>,HumpFlicker<RotateColorsX<Int<1400>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<3200>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,20>,HumpFlicker<RotateColorsX<Int<1000>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,RotateColorsX<Int<400>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,60>,RandomFlicker<Mix<Int<16384>,Black,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>,RgbArg<ALT_COLOR3_ARG,Rgb<255,0,0>>>>,LinearSectionF<IncrementWithReset<Scale<IsGreaterThan<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<18000>>,Int<0>,ThresholdPulseF<StrobeF<Scale<HoldPeakF<Ifon<SwingAcceleration<>,Int<0>>,Int<150>,Int<32000>>,Int<40>,Int<400>>,Int<1>>,Int<32000>>>,ThresholdPulseF<IsLessThan<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<8000>>,Int<32000>>,Int<42000>,Int<1500>>,Scale<HoldPeakF<Ifon<SwingSpeed<400>,Int<0>>,Int<150>,Int<32000>>,Int<3000>,Int<10000>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,26000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaL<Strobe<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,AudioFlicker<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Blue>,50,1>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,255>>,TrFade<400>>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.14 v2.242p
Drag Effect:
OS7.14 v2.242p
Drag Effect:
"Flamer"},
{ "Nightsister;common",  "common/tracks/duelfate.wav",
https://fett263.com/fett263-proffieOS7-style-library.html#Rotoscope
OS7.13 v1.018-p
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.13 v1.018-p
OS7.13 v1.018-p
OS7.13 v1.018-p
"BasicRotoscope"
{ 0,
//110 LEDs
  SubBlade(0, 109, WS281XBladePtr<439, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
//109 LEDs
  SubBladeReverse(110, 218, NULL),
//110 LEDs
  SubBlade(219, 328, NULL),
//110 LEDs
  SubBladeReverse(329, 438, NULL),
//439 LEDs total
  CONFIGARRAY(presets) },
 /* Generated with Fett263 Config Helper v3.08 */
I would be grateful for thoughts on next steps, or diagnosis. Maybe trim an LED off of the base of blade 3?
This sounds like a power problem to me.
Have you measured the voltage at the end of the strip?
Do you have power injection when the strip goes back to the base?
Yes. I think of this as a basic requirement :slight_smile: I didn’t break out the multimeter but you convinced me to rework my joints, rather than just the base of the strips. All of the strips worked but there were some oddly behaving pixels.
The main date line to strip 1 remains a 28 awg PTFE wire for spacing, but I replaced the interlacing data lines with 24 awg silicon.
Solved!
