I am looking at the wiring for the Neopixels and for this chassis it uses 2x SCW V3 Hilt side NPXL’s and 1x SCW Blade side PCB’s. This is just for the hilt, not counting the blades PCB’s. Looking at the SCW NPXL manual, would install the first Hilt Side NPXL in the V1 configuration, since its inside the hilt, and the second hilt side NPXL in the V2 configuration since its in the emitter of the hilt?
Second question: It appears the proffieboard v2.2 has a built in resistor for the neopixel data wire D1 so I would need to remove the resistors from the SCW hilt and blade side NPXL PCB’s is that correct? Both the hilt side NPXL’s come with some installed, I was planning on using D1 pad.
@Bobby_Susenbach is this how you did yours?
Thanks for any feedback!
