i could use major help with my lightsaber i updated the os to 7 my proffie board is v2.2 i formatted
my sd i have 3 fonts i want to incorporate into my saber vader, ani, obi.
Start here, just read through everything and follow step-by-step, it covers updating your config for new presets/fonts/styles, etc.
okay it says font directory not found
can anyone coach me on discord i would very much appreciate it.
For me, there is a reason I hang out here rather than on discord.
If you found help there already, great, if not, Iâm happy to help you here.
Some questions:
- Post your config file so we can take a look at it.
- Does the font names in your config file match the ones on the SD card?
- Do you use the Fett263 prop?
- Do you have
;common
in your font paths? - Do you have a voice pack in the common directory on your SD card?
no i use this one if this is the file
i think i have like 4 different configs i things its for the interchangeable blades.
#define NUM_BUTTONS 1
#define VOLUME 1550
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define BC_THRUST_ON
#define BC_TWIST_ON
#define BC_TWIST_OFF
#define BC_FORCE_PUSH
#define FEMALE_TALKIE_VOICE
#define VOLUME_MENU_CYCLE
#define SPEAK_BLADE_ID
#include "../props/saber_BC_buttons.h"
{ "Bank01;common", "tracks/TFA_Battle.wav",
StylePtr<InOutHelper<Blast<LocalizedClash<Lockup<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<TransitionEffect<Mix<SwingSpeed<600>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,300>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,StyleFire<BrownNoiseFlicker<Red,Rgb<25,0,0>,300>,Rgb<128,0,0>,0,8,FireConfig<10,1200,1>,FireConfig<0,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>>,StyleFire<Red,Rgb<150,150,150>,0,6>,TrInstant,TrSmoothFade<800>,EFFECT_IGNITION>,Mix<Bump<Int<32768>,Int<16000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<OrangeRed,White>>,TrConcat<TrWipeIn<600>,Mix<Bump<Int<32768>,Int<16000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,RandomPerLEDFlicker<Orange,White>>,TrWipe<600>>,TrInstant,EFFECT_STAB>,BrownNoiseFlicker<White,Red,400>,TrInstant,TrSmoothFade<200>,EFFECT_LOCKUP_BEGIN>,Mix<Bump<Int<32768>,Int<10000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,White>,TrInstant,TrFade<200>,EFFECT_DRAG_BEGIN>,Mix<Bump<Int<32768>,Int<10000>>,StyleFire<BrownNoiseFlicker<Red,RandomPerLEDFlicker<Rgb<25,0,0>,Rgb<60,0,0>>,200>,Rgb<80,0,0>,0,6,FireConfig<10,1000,2>,FireConfig<4000,0,0>,FireConfig<2,1000,5>,FireConfig<100,0,5>>,White>,TrInstant,TrFade<300>,EFFECT_DRAG_END>,Black,TrConcat<TrInstant,HumpFlicker<White,BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,40>,TrColorCycle<600>>,TrInstant,EFFECT_RETRACTION>,Mix<Bump<Int<0>,Int<44000>>,Mix<Bump<Int<32768>,Int<44000>>,TransitionEffect<Red,White,TrInstant,TrFade<300>,EFFECT_LOCKUP_END>,Stripes<1000,-1500,Red,BrownNoiseFlicker<White,Red,300>>>,Stripes<1000,1500,Red,BrownNoiseFlicker<White,Red,300>>>,TrInstant,TrSmoothFade<800>,EFFECT_LOCKUP_END>,Pulsing<Gradient<BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,BrownNoiseFlicker<White,Strobe<Blue,White,50,1>,100>>,Gradient<BrownNoiseFlicker<White,Strobe<Blue,White,50,1>,100>,BrownNoiseFlicker<Red,Rgb<25,0,0>,400>>,3500>,RandomPerLEDFlicker<BrownNoiseFlicker<Red,Rgb<25,0,0>,400>,White>,Bump<Int<16000>,Int<16000>>,Bump<Int<32768>,Int<10000>>>,White>,White>,150,300,Black>>()},
{ "Bank02;common", "tracks/vader.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variationred,Rgb16<65535,0,0>>>,RotateColorsX<Variation,Rgb<90,65,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<500>,TrWipeIn<800>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<50>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<35>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<30>>,EFFECT_PREON>>>()},
{ "Bank03;common", "tracks/LvsV.wav",
StylePtr<Layers<AudioFlicker<BrownNoiseFlicker<Mix<SwingSpeed<400>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,Stripes<5000,-300,RotateColorsX<Variation,White>,RotateColorsX<Variation,Snow>,RotateColorsX<Variation,White>,RotateColorsX<Variation,White>>,300>,RotateColorsX<Variation,Black>>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<800>>,EFFECT_LOCKUP_END>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveBlastWaveL<Rgb<50,50,75>,Int<300>,Int<100>,Int<300>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RotateColorsX<Variation,Rgb<175,175,225>>>,TrFade<1200>>,EFFECT_IGNITION>,ResponsiveStabL<Red>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipeX<Scale<BladeAngle<>,Int<500>,Int<200>>>,TrWipeInSparkTip<White,500>>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank04;common", "tracks/Ascension.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank05;common", "tracks/DOF.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrFade<400>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrDelay<30000>,Mix<SwingSpeed<400>,AudioFlickerL<Rgb<150,0,0>>,Red>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank06;common", "tracks/Traveler.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank07;common", "tracks/General.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank08;common", "tracks/DarkSide.wav",
StylePtr<Layers<StyleFire<Red,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Yellow,OrangeRed,Yellow,Red,Tomato>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rainbow>,Stripes<1500,-2500,White,Rainbow>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,White>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb<60,60,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,60>>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeInSparkTip<White,500>>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank09;common", "tracks/Duke.wav",
{ "Bank10;common", "tracks/TheBoldOne.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank11;common", "tracks/LvsV.wav",
{ "Bank12;common", "tracks/JFO5.wav",
StylePtr<Layers<Mix<Scale<BladeAngle<>,Int<32768>,Int<0>>,StyleFire<Gradient<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,OrangeRed>,RotateColorsX<Variation,Red>>,RotateColorsX<Variation,Rgb<60,0,0>>,0,4,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,1500,5>,FireConfig<0,0,0>>,StyleFire<Gradient<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>,RotateColorsX<Variation,Red>>,Black,0,2,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,1600,30>,FireConfig<0,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,AlphaL<Black,SmoothStep<Scale<BladeAngle<0,16000>,Scale<SwingSpeed<400>,Int<10000>,Int<38000>>,Int<38000>>,Int<20000>>>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank13;common", "tracks/TheBoldOne.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Cyan>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Cyan,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Aquamarine,70>,DeepSkyBlue>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,Rgb<0,0,128>>,Rgb<0,0,80>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Magenta,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank14;common", "tracks/JFO1.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Coral>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Blue,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Rgb<25,25,255>,70>,OrangeRed>,Red,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<White,Black,20>,Rgb<0,0,10>,BrownNoiseFlicker<Black,Red,70>,OrangeRed>,Red,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,DeepSkyBlue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Yellow>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Yellow>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank15;common", "tracks/LvsV.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,TransitionEffectL<TrConcat<TrFade<400>,RotateColorsX<Variation,Rgb<90,180,255>>,TrDelay<1500>,RotateColorsX<Variation,Rgb<90,180,255>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Bank16;common", "tracks/RevanSongYT.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Rgb16<40112,395,57353>>,RotateColorsX<Variation,Magenta>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<White,Magenta,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Magenta,70>,Rgb16<40112,395,57353>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<White,TrInstant,TrFade<400>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>>>>()},
{ "Bank17;common", "tracks/DarkSide.wav",
{ "Bank18;common", "tracks/Ashoka.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,GhostWhite>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rgb<100,100,150>>,Stripes<1500,-2500,White,Rgb<100,100,150>>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<Red,BrownNoiseFlicker<Red,OrangeRed,300>,50,1>,TrConcat<TrInstant,Red,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<Magenta,AudioFlicker<White,DeepSkyBlue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red>,ResponsiveBlastWaveL<DeepPink,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<Red,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeIn<500>>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,White>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Bank19;common", "tracks/Lycan.wav",
StylePtr<Layers<HumpFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<128,34,0>>,50>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,AudioFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<30000>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,20>,AudioFlicker<RotateColorsX<Variation,Rgb<60,0,0>>,RotateColorsX<Variation,Rgb<10,0,0>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,RotateColorsX<Variation,Rgb<128,0,0>>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,225,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<20000>>>,TrFade<400>>,TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,DarkOrange>,Stripes<1500,-2500,White,DarkOrange>>,Int<18000>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastWaveL<TransitionEffect<White,Yellow,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<1000>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<250>,TrWipeInSparkTip<White,300>,Black>>>()},
{ "Bank20;common", "tracks/WhiteTrackwav",
{ "Bank21;common", "tracks/CrimsonMenace.wav",
{ "Bank22;common", "tracks/mars.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<180,130,0>>,RotateColorsX<Variation,Rgb<90,65,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveMeltL<Mix<TwistAngle<>,Red,Orange>,TrWipeIn<600>,TrSmoothFade<600>>,InOutTrL<TrWipe<500>,TrWipeIn<800>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<50>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<Green,Bump<Int<0>,Int<1>>>,TrDelay<35>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<25>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1>>>,TrDelay<30>>,EFFECT_PREON>>>()},
{ "Bank23;common", "tracks/Darkness.wav",
{ "Bank24;common", "tracks/mercury.wav",
{ "Bank25;common", "tracks/uranus.wav",
{ "Bank26;common", "tracks/venus.wav",
{ "Bank27;common", "tracks/deadlink.wav",
{ "Bank28;common", "tracks/JFO2.wav",
{ "Bank29;common", "tracks/MSV.wav",
{ "Bank30;common", "tracks/Ascension.wav",
{ "Bank31;common", "tracks/TFA_Duel.wav",
{ "Bank32;common", "tracks/Prism.wav",
StylePtr<Layers<StyleFire<Gradient<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Orange>,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Green>,RotateColorsX<Variation,Cyan>,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Magenta>>,Red,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,AlphaL<AlphaL<Azure,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<28000>,Int<14000>>,Int<16000>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Sin<Int<10>,Int<10000>,Int<20000>>>>,AlphaL<White,Bump<Sin<Int<10>,Int<10000>,Int<20000>>>>>,TrConcat<TrInstant,TransitionEffect<Azure,White,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<TransitionEffect<White,Azure,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,Int<300>,Int<100>,Int<400>,Sin<Int<10>,Int<10000>,Int<20000>>>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,MultiTransitionEffectL<TrConcat<TrDelay<300>,AlphaL<RandomPerLEDFlickerL<White>,SmoothStep<Int<6000>,Int<-4000>>>,TrDelay<15000>,AlphaL<RandomPerLEDFlickerL<White>,SmoothStep<Int<6000>,Int<-4000>>>,TrFade<500>>,EFFECT_STAB>, AlphaL<Mix<IsLessThan<BladeAngle<>,Int<26000>>,MultiTransitionEffectL<TrConcat<TrWipeIn<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipeIn<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrConcat<TrWipe<200>,BrownNoiseFlickerL<White,Int<200>>,TrWipe<200>>,EFFECT_STAB>>,Int<32768>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,Layers<ResponsiveBlastFadeL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Scale<SwingSpeed<200>,Int<10000>,Int<18000>>>,ResponsiveBlastFadeL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Scale<SwingSpeed<200>,Int<4000>,Int<10000>>>,ResponsiveBlastWaveL<TransitionEffect<Azure,White,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,BlastL<TransitionEffect<Azure,White,TrInstant,TrFade<50>,EFFECT_BLAST>>,ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<50>,EFFECT_BLAST>>>>,LocalizedClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,White>,40>,TrFade<1200>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<300>,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Rainbow>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,Int<1000>,Int<4000>>,Int<-4000>>>,TrDelay<2000>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrFade<2000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rainbow>,10>,Bump<Int<0>,Int<4000>>>,TrFade<2950>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rainbow>,15>,Bump<Int<0>,Int<5000>>>,TrFade<3000>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rainbow>,20>,Bump<Int<0>,Int<6000>>>,TrBoing<1000,3>>,EFFECT_PREON>>>()},
{ "Rainbow;common", "tracks/cantina.wav",
StylePtr<Layers<StyleFire<StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Red,Orange,Yellow,Green,Blue,Magenta>,StripesX<Int<3000>,Scale<TwistAngle<>,Int<-500>,Int<0>>,Tomato,OrangeRed,Orange,Yellow,SteelBlue,DeepPink>,0,3,FireConfig<0,2000,5>,FireConfig<0,2000,5>,FireConfig<0,2000,5>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<SmoothStep<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<1000>>,Stripes<1500,2000,White,Rainbow>,Stripes<1500,-2500,White,Rainbow>>,Int<16384>>,TrFade<800>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<16000>>>,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastWaveL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,White>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,White>,RotateColorsX<Variation,Rgb<60,60,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,60>>>>,TrFade<1200>>,EFFECT_IGNITION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Int<200>,Int<800>>>,TrWipeInSparkTip<White,500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_NEWFONT>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<7500>>>>>()},
{ "Batt00;common", "tracks/cantina.wav",
and none of them match i have 3 sound fonts in my saber for ani, obi, vader,
So this is where your fonts are controlled in each preset.
âBank01â should be a folder in the root SD card, it needs to be spelled exactly the same. If you want a different font for the preset you would just put the font folder in the root of your SD and then put the name of that font folder in place of âBank01â in the corresponding preset.
The âcommonâ folder is for Voice Prompts, this is required with my prop, more info here. You need to have a folder named âcommonâ in the root of your SD.
If youâre looking to update your config I have a config helper tool that can help, just watch the videos and read the instructions and it will make setting up your config easier. Then refer to the Updating your Proffieboard page I linked above.
Heâs not actually using your prop though.
Then you should fix that.
Ah, missed that. I didnât think âcommonâ was used in any other props so when I see it in the presets I typically associate with my prop.
In OS7 my prop can be set up with controls from BC and allows implementation of the new features so Iâd typically recommend switching if moving to OS7, my library requires a lot of features in my prop to enable OS7 capabilities.
Remove the screenshot and post your config using pastebin.com.
Short answer would be to use my config helper, it will let you set up just 3 presets easily.
blade pins i have 7
what if it i dont see a track folder?
If you donât have or want tracks leave it blank using empty quotation marks like so.
{ "font;common", "",
StylePtr<...>(),
"name"
i used your config helper
You can leave the tracks field empty and the tool will handle then. The tool handles the syntax if you input the correct BladeConfig section from your original config and follow the instructions.
// ProffieOS7 Config File
#define VOLUME 1000
#define SHARED_POWER_PINS
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin2,bladePowerPin3>
#define POV_INCLUDE_FILE "e;"e
#define SAVE_PRESET
#define BLADE_DETECT_PIN 8
#define FETT263_MAX_CLASH 16
#define FETT263_POWER_LOCK
#define FETT263_SPIN_MODE
#define FETT263_USE_BC_MELT_STAB
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_STAB_ON
{ "ANI;common", "ANI/track.wav",
StylePtr<ANI><InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<DodgerBlue,Blue>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1> ,100>,AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>>,Gradient<AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker <DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>>,3500>,AudioFlicker<White,DodgerBlue>>,White,40>,180,500,Black>>(),
"OBI"
{ "OBI;common", "OBI//track.wav",
StylePtr<OBI>StylePtr<OBI><InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<DodgerBlue,Blue>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1> ,100>,AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>>,Gradient<AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker <DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>>,3500>,AudioFlicker<White,DodgerBlue>>,White,40>,180,500,Black>>(),
"preset1"
{ "VADER;common", "VADER/track.wav",
StylePtr<VADER><InOutHelper<OnSpark<LocalizedClash<Lockup<Blast<AudioFlicker<Red,Rgb<120,0,0>>,DeepSkyBlue,200,100,400>,Pulsing<Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,3500>,AudioFlicker<Red,White>>,White,80,50>,HumpFlicker<Pink,Red,60>,1600>,800,500,Black>>(),
"VADER"
#ifdef CONFIG_STYLES
/*--------------------------------- ANI---------------------------------*/
using ANI =
InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<DodgerBlue,Blue>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1> ,100>,AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>>,Gradient<AudioFlicker<DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker <DodgerBlue,Blue>,AudioFlicker<DodgerBlue,Blue>>,3500>,AudioFlicker<White,DodgerBlue>>,White,40>,180,500,Black>;
add to preset as StylePtr<ANI>()
/*--------------------------------- VADER---------------------------------*/
using VADER =
InOutHelper<OnSpark<LocalizedClash<Lockup<Blast<AudioFlicker<Red,Rgb<120,0,0>>,DeepSkyBlue,200,100,400>,Pulsing<Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,3500>,AudioFlicker<Red,White>>,White,80,50>,HumpFlicker<Pink,Red,60>,1600>,800,500,Black>;
add to preset as StylePtr<VADER>()
/*--------------------------------- OBI---------------------------------*/
using OBI =
add to preset as StylePtr<OBI>()
/* Generated with Fett263 Config Helper v3.05 */
Looks reasonable although you have some âexoticâ defines, were these in your previous config, these arenât typical for most sabers. And your config isnât using POV style so that define isnât really needed from what I can see.
You may also want to disable some of the âon the flyâ editing features in my prop if youâre new to it. Newer users have a tougher time with these:
Change Font
Change Style
Copy Preset
