I’ve spent some of my spare time over the last few months building a graphical configurator for Proffieboard, and I’d love to get some beta testers to take it for a spin.
Hiltwright aims to give you everything a Proffie config can do without editing config files, figuring out drivers, or setting up Arduino. It covers the whole path: wiring, presets, fonts and the SD card, then building and installing the firmware over USB. There’s a style builder, and a demo room that simulates styles LED by LED using ProffieOS’s own math, with your sound fonts playing.
What you should know:
Windows only for now. Proffieboard V2.2 and V3, ProffieOS 8.x.
The installer isn’t signed, so Windows will warn you, and Smart App Control in Windows 11 has to be off. The install guide on the site covers it.
Every firmware install backs up your saber’s firmware first, and you can restore with a single click.
It’s free and open source (GPL-3.0), if you want to contribute please feel free to submit PRs and issues on GitHub.
I’ve tested a lot with the hardware I have on hand, plus a large automated test suite, but there will always be setups and edge cases I’ve missed. I’m especially interested in wiring I don’t own: multiple blades, crystal chambers, accents, different props.
THIS IS A BETA!
If you pick this up, please expect things to break. Report problems on GitHub, and attach the file from “Save diagnostics” in the app. I won’t be able to walk everyone through it, so this is really for power users, installers and tinkerers. There’s a built-in tour to get you started.
Holy shit I had no idea that this existed, I went through a few iterations on UI design and opted for this one independently but I can see one of two things happened
My Claude agent came up with the same UI because we provided similar prompts
My Claude agent found this project and used it for reference because it matched the prompting I gave it
In either case I’m going to do a full overhaul of this UI and differentiate it and I appreciate you letting me know.
This is deeply frustrating as someone who takes pride in their work and works very hard even when utilizing agentic tools and LLMs for their code.
@Sam_SaberBenchDev I did some digging and want to be clear here, I had this UI in my git repo 2 months ago. Prior to your first announcement and given that your project is closed source there’s no way my agent could have copied your project as far as I’m aware.
Are you certain your agent didn’t find my project? I had originally even called my project saber bench for a couple days before renaming to hiltwright.
In either case if you want to keep your UI I can just rebuild mine I don’t care either way.
Also exceptionally weird coincidence that my name is also Sam
Well, FWIW, at least your “Claude agent” definitely knew ProffieConfig existed (and has for a long while now), which certainly doesn’t put the greatest taste in my mouth.
Certainly not the first LLM-driven app of the sort though, and certainly won’t be the last
I knew ProffieConfig existed but the scope of your app didn’t encompass what I envisioned for an all in one app that I wanted.
For full transparency I considered referencing your code for work since it is open source but we never did clone or read anything beyond the surface level details of your repo for our development. It was simply acknowledged as a competitor in my docs, and none of your work is carried into Hiltwright.
Ported the style library, editor, and demo room to the website for Hiltwright if anyone wants to give it a go! It’s identical to what’s in the app and should be a nearly identical simulation to a real hilt in the demo room.
