First of all, that is all never going to fit. Greyscale blade styles are notorious for taking up a lot of memory, and you have like evey one made in there.""Your Binary Dark style got messed up somehow in the copy/paste/cleanup.
You are missing an InOutTrL so there’s no ignition or retraction.
Which only got noticed one removing the extra closing bracket > at the end of layer for EFFECT_BLAST.
I think this is what you want the preset to look like:
{ "Binary_Dark;common", "common/tracks/mars.wav",
StylePtr<Layers<
HumpFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>,50>,
AlphaL<AudioFlickerL<Stripes<1000,-1500,RandomPerLEDFlicker<RotateColorsX<Variation,DarkOrange>,Black>,Black,RotateColorsX<Variation,Red>,Black>>,SwingSpeed<350>>,
AlphaL<AlphaL<Stripes<2000,-2250,RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<60,30,0>>,Pulsing<RotateColorsX<Variation,Rgb<30,15,0>>,Black,800>>,HoldPeakF<Scale<IsLessThan<SwingSpeed<850>,Int<13600>>,Scale<SwingSpeed<850>,Int<-19300>,Int<32768>>,Int<0>>,Int<550>,Scale<SwingAcceleration<100>,Int<20000>,Int<10000>>>>,SmoothStep<Scale<Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>,Int<15000>,Int<5000>>,Int<16000>>>,
TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-1550,White,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<White,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<3000>>,EFFECT_IGNITION>,
TransitionEffectL<TrConcat<TrInstant,White,TrFade<150>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1000>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<1000>,AlphaL<StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<RotateColorsX<Variation,Magenta>,Black,20>,RotateColorsX<Variation,Rgb<10,0,10>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,255>>,70>,RotateColorsX<Variation,Rgb<128,0,128>>>,RotateColorsX<Variation,Rgb<80,0,80>>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,Bump<Int<3500>,Int<23384>>>,TrFade<600>>,EFFECT_FORCE>,
LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,TrFade<350>>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrInstant,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,TrDelay<500>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrInstant,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,TrFade<500>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>>>,TrFade<350>>,EFFECT_BLAST>,
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<300>,Int<200>,Int<940>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,TrFade<350>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrWaveX<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,AlphaL<HumpFlicker<White,Rgb<40,60,60>,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>,TrFade<350>>,EFFECT_CLASH>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RotateColorsX<Variation,Red>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<1500>>,Int<2000>,Int<4500>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_RETRACTION>>,Black,TrDelay<897>,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,Bump<Int<10500>,Int<11500>>>,TrDelay<150>>,EFFECT_RETRACTION>,
//Spark tip ignition and cycle down retraction
InOutTrL<TrWipeSparkTip<White,1500>,TrColorCycleX<Int<500>,500>>,
TransitionEffectL<TrConcat<TrDelayX<WavLen<EFFECT_RETRACTION>>,AlphaL<BrownNoiseFlicker<Black,RotateColorsX<Variation,Red>,125>,SmoothStep<Scale<NoisySoundLevel,Int<2500>,Int<15000>>,Int<-4000>>>,TrFadeX<WavLen<EFFECT_POSTOFF>>>,EFFECT_RETRACTION>,
TransitionEffectL<TrConcat<TrDelay<500>,Black,TrWaveX<RotateColorsX<Variation,Red>,Int<750>,Int<175>,Int<1575>,Int<-3000>>,Black,TrInstant,AlphaL<RandomPerLEDFlicker<RotateColorsX<Variation,Red>,Black>,Bump<Int<12000>,Int<11500>>>,TrDelay<150>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<White,SmoothStep<Scale<NoisySoundLevel,Int<150>,Int<10000>>,Int<-4000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>
>>(), "binary dark"},
Then, I could only load up to CODA.
CODA and the rest needed to be comment out to make it fit.
