It’s already planned, in some form, for Phase 2 or 3 when I get time.
Hey Fett, getting a compile error with the Thunder and Lightning style:
/* copyright Fett263 ThunderStorm (Primary Blade) OS6 Style
https://fett263.s3.us-east-2.amazonaws.com/fett263-proffieOS6-style-library.html#ThunderStorm
OS6.5 v1.018
Base Style: Thunder and Lightning
Ignition Effect: Lightning Strike
PowerUp Effect: Power Flash
Retraction Effect: Fade Out
PostOff Effect: Emitter Spark (Emitter Size)
Lockup Effect: Intensity Lockup V1
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
StylePtr<Layers<Layers<TransitionLoop<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,TrConcat<TrBoing<500,3>,Layers<Stripes<10000,100,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,AlphaL<Stripes<8000,-200,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrExtendX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>,TrWipe<200>>>>>,TransitionEffectL<TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,MultiTransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWipeInX<Mult<IgnitionTime<300>,Int<6553>>>,RandomBlink<30000,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Black>,TrExtendX<Mult<IgnitionTime<300>,Int<19660>>,TrWipeInX<Mult<IgnitionTime<230>,Int<6553>>>>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,IntArg<EMITTER_SIZE_ARG,1000>,Sum<Int<5000>,IntArg<EMITTER_SIZE_ARG,1000>>>,Int<-3000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<19660>>>>,,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_RETRACTION>>>(),
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from C:\Users\Zach\Documents\Arduino\ProffieOS\ProffieOS.ino:563:
C:\Users\Zach\Documents\Arduino\ProffieOS\config\testSaberV1.h:615: error: template argument 2 is invalid
615 | StylePtr<Layers<Layers<TransitionLoop<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,TrConcat<TrBoing<500,3>,Layers<Stripes<10000,100,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<3855>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<25700>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,AlphaL<Stripes<8000,-200,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,Int<16384>>>,TrDelayX<Scale<SlowNoise<Int<3000>>,Int<100>,Int<2000>>>>>,TransitionLoopL<TrConcat<TrWipe<200>,RandomBlinkL<Int<30000>,White>,TrExtendX<Scale<SlowNoise<Int<3000>>,Int<300>,Int<3000>>,TrWipe<200>>>>>,TransitionEffectL<TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,MultiTransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrWipeInX<Mult<IgnitionTime<300>,Int<6553>>>,RandomBlink<30000,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Black>,TrExtendX<Mult<IgnitionTime<300>,Int<19660>>,TrWipeInX<Mult<IgnitionTime<230>,Int<6553>>>>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,IntArg<EMITTER_SIZE_ARG,1000>,Sum<Int<5000>,IntArg<EMITTER_SIZE_ARG,1000>>>,Int<-3000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<19660>>>>,,Black>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<EMITTER_SIZE_ARG,2000>,Sum<IntArg<EMITTER_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_RETRACTION>>>(),
C:\Users\Zach\Documents\Arduino\ProffieOS\config\testSaberV1.h:615: error: template argument 9 is invalid
C:\Users\Zach\Documents\Arduino\ProffieOS\config\testSaberV1.h:615: error: no matching function for call to 'StylePtr<<expression error> >()'
In file included from C:\Users\Zach\Documents\Arduino\ProffieOS\styles\fire.h:4,
from C:\Users\Zach\Documents\Arduino\ProffieOS\ProffieOS.ino:426:
C:\Users\Zach\Documents\Arduino\ProffieOS\styles\style_ptr.h:93:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr()'
93 | StyleAllocator StylePtr() {
C:\Users\Zach\Documents\Arduino\ProffieOS\styles\style_ptr.h:93:16: note: template argument deduction/substitution failed:
C:\Users\Zach\Documents\Arduino\ProffieOS\config\testSaberV1.h:615: error: template argument 1 is invalid
Thanks again for all of your hard work on this stuff, so awesome!
It’s the “Fade Out” retraction, I’ll get it fixed later today. There’s a bug in that option.
“Fade Out” has been fixed, refresh page for update.
Not a bug but a request.
Any chance you can include on the main style comment the primary colour selected in your library:
On this line:
Just add the base color to the end of the line
Makes searching easier in a big config file since the colours are using RGB values now more than the names even for pure colours.
Many Thanks
Possibly, the reason I don’t is because the as soon as you edit a color this becomes obsolete and possibly confusing, since ALL effects are individually editable the config color no longer really matters, it’s just a start point, you’ll actually find if you just use the exact same colors for every preset and then edit you’ll actually save some additional memory. All my styles in my config are Red with White effects, then I just edit them to the desired color in each preset. It let’s me fit an extra style or two versus setting styles with different default colors.
I noticed a difference just now in how the line code is written since about a week ago for the Fallen Order Cal Kestis. Can you put the base blade with the pulsing and flickering back in as an option? *If this has become a different bladestyle to keep to screen accuracy what is the bladestyle listing it falls under now? I just like how it behaves and didn’t see it work now even when I chose Second or Ninth Sister. **Changelog: 1/18/22 Swapped the RGB 255 value from red to the blue for a blue base blade and fixed the missing stab line.
Base Blade Before.
ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,StripesX<Int<6000>,Scale<SlowNoise<Int<2000>>,Int<-1600>,Int<-3200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,BrownNoiseFlicker<Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,300>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Black,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,ColorSelect<IntArg<SWING_OPTION_ARG,0>,TrInstant,AlphaL<Black,Int<0>>,
Versus now:
ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Blue>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>,800>,RgbArg<BASE_COLOR_ARG,Blue>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>>>,
Original Code.
fett263-proffieOS6-style-library.html#FallenOrder
OS6.5 v1.0
This Style Contains 648 Unique Combinations
Style Options:
Default (0): Fallen Order Cal Kestis
Fallen Order Second Sister
Preon Effect Options: Default (0): Disable, 1: Overload (PreOn Color), 2: Sparking (PreOn Color)
Ignition Effect Options: Default (0): Standard Ignition, 1: SparkTip Ignition, 2: Dual Mode Wipe (Up = Fast)
PowerUp Effect Options: Default (0): Disable, 1: Unstable Power Up Forward, 2: Power Burst Forward
Retraction Effect Options: Default (0): Standard Retraction, 1: Dual Mode Wipe In (Up = Fast)
CoolDown Effect Options: Default (0): Disable, 1: Unstable Cool Down Reverse, 2: Power Burst Reverse
Blast Effect (Randomly Selected): Blast Wave (Random), Blast Ripple Fade, Blast Wave (Sound Based), Blast Ripple, Blast Fade (Sound Based)
Swing Effect Options: Default (0): Disable, 1: Force Slow
StylePtr<
Layers<
ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,StripesX<Int<6000>,Scale<SlowNoise<Int<2000>>,Int<-1600>,Int<-3200>>,RgbArg<BASE_COLOR_ARG,Blue>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Blue>>>,BrownNoiseFlicker<Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,300>,RgbArg<BASE_COLOR_ARG,Blue>,RandomPerLEDFlicker<Black,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Blue>>>,RgbArg<BASE_COLOR_ARG,Blue>>,StripesX<Int<1500>,Scale<SlowNoise<Int<2500>>,Int<-3000>,Int<-5000>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<2570>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>>>,
ColorSelect<IntArg<SWING_OPTION_ARG,0>,TrInstant,AlphaL<Black,Int<0>>,TransitionEffectL<TrConcat<TrExtend<30000,TrFade<300>>,Pulsing<RgbArg<SWING_COLOR_ARG,White>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,White>>,3000>,TrFade<300>>,EFFECT_FORCE>>,
TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrExtendX<IgnitionTime<>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,White>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,White>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,White>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,White>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,White>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,White>>>>,TrFade<800>>,TrConcat<TrExtendX<IgnitionTime<>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,White>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,White>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,White>>>,TrFade<800>>>,EFFECT_IGNITION>,
TransitionEffectL<TrSelect<IntArg<RETRACTION_COOL_DOWN_ARG,0>,TrInstant,TrConcat<TrExtendX<RetractionTime<>,TrInstant>,Stripes<3000,3500,RgbArg<RETRACTION_COLOR_ARG,White>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,White>>,Black>,BrownNoiseFlicker<RgbArg<RETRACTION_COLOR_ARG,White>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,White>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<RETRACTION_COLOR_ARG,White>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,White>>>>,TrFade<800>>,TrConcat<TrExtendX<RetractionTime<>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,White>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,White>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,White>>>,TrFade<800>>>,EFFECT_RETRACTION>,
MultiTransitionEffectL<TrRandom<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,White>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,White>,Int<0>>,TrWaveX<Remap<CenterDistF<EffectPosition<>>,Stripes<1500,-2000,RgbArg<BLAST_COLOR_ARG,White>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,White>>>>,Int<160>,Int<100>,Int<300>,EffectPosition<>>>,TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,White>,Bump<Int<16384>,Int<6000>>>,TrFade<50>,AlphaL<RgbArg<BLAST_COLOR_ARG,White>,Int<0>>,TrSparkX<Remap<CenterDistF<EffectPosition<>>,Stripes<2000,-2000,RgbArg<BLAST_COLOR_ARG,White>,Mix<Int<2096>,Black,RgbArg<BLAST_COLOR_ARG,White>>>>,Int<100>,Int<300>,EffectPosition<>>>,TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,White>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,White>>>,TrFade<300>>>,EFFECT_BLAST>,
TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,White>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,
LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,IgnitionTime<>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<>,Int<16384>>,IgnitionTime<>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<RetractionTime<>,Int<16384>>,RetractionTime<>>>>>,
TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,White>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,White>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,White>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,White>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<4000>>>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),"JediFallenOrder"},
The code had been crossed up in the script, the style is actually “Random Pulse” under Unstable Blades.
I’ve added more css to handle smaller screens and mobile (too a lesser extent) and a few other display and layout improvements. You’ll need to refresh to apply.
Let’s Talk ProffieOS6 Style Library Live - Tuesday, February 1, 9:00pm EST
Join Megtooth Sith and I as we discuss the OS6 Library and some optimization concepts for your configs and answer questions.
Pushed one more small update, styles were missing argument for editing Melt effect color (uses STAB_COLOR_ARG). Refresh page to get new versions (bottom right of library will say “OS6.5 v1.0182” to show updated version)
just FYI
is exactly identical to
The OS uses aliases for the color names. Under the hood Blue literally = Rgb<0,0,255>
Found them, thanks. Nice to see that batch of bladestyle options!
So im pulling the code straight from the OS6 library, putting it in the style editor (Style Editor), clicking submit…and nothing happens with any of the blade styles in the library…sometimes the cursor highlights BASE_RGB_ARG or something to that extent sometimes…i really have never had issues…is there something im missing?
Actually just read the style editor needs to be updated…my apologies for a wasted post here i just didnt pick it up when i was searching the forum.
Check near the variation button, that’s where errors pop up. May look like nothing, but that’s where you’ll see what it’s complaining about.
Also, click submit 2x to get the right column to update.
The Editor is still in Beta, there is an ongoing thread for issues with it.
Forgive me if I’m missing something obvious.
I don’t think the crystal chamber lightning block effect is being added to the style in this instance even though it is included in the copyright recipe. Unless my understanding of the effect is wrong.
Thanks!
/* copyright Fett263 (Crystal Chamber) OS6 Style
https://fett263.s3.us-east-2.amazonaws.com/fett263-proffieOS6-style-library.html#Rotoscope
OS6.5 v1.0182
On Behavior: Kyber Flow Up
Off Behavior: Slow Pulse Dim-On
Ignition Effect: Instant
CoolDown Effect: Power Burst Reverse
LightningBlock Effect: Full Blade Lightning
StylePtr<Layers<Stripes<5000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>>,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>>,TransitionEffectL<TrConcat<TrExtendX<RetractionTime<0>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<85,85,200>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<85,85,200>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<85,85,200>>>>,TrFade<800>>,EFFECT_RETRACTION>,InOutTrL<TrInstant,TrFadeX<RetractionTime<0>>,Pulsing<Mix<Int<8192>,Black,RgbArg<OFF_COLOR_ARG,Rgb<30,60,200>>>,RgbArg<OFF_COLOR_ARG,Rgb<30,60,200>>,8000>>>>(),
Sorry, missed this post somehow. Yes, looks like there is a bug, it’s not actually adding the style code. I’m working on a larger update but I’ll try to fix and include when I push it up.
/* copyright Fett263 EnergyWeapon (Crystal Chamber) OS6 Style
https://fett263.s3.us-east-2.amazonaws.com/fett263-proffieOS6-style-library.html#EnergyWeapon
OS6.5 v1.0182
Base Style: ElectroStaff
Off Behavior: Pulsing Flicker (Single Color)
Ignition Effect: Cycle Up
Retraction Effect: Instant
Lockup Effect: Lockup Dissipate Up
Blast Effect: Full Blade Blast Fade
Clash Effect: Clash Wave Up
StylePtr<Layers<StaticFire<Strobe<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Strobe<Rgb<100,100,150>,RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Black>,50,1>,100,1>,Mix<Int<6425>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,0,5,2,1000,5>,MultiTransitionEffect<TrConcat<TrExtend<30,TrInstant>,RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,EFFECT_BLAST>,,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<ClashImpactF<>,Int<-4000>>>,TrFadeX<Scale<ClashImpactF<>,Int<100>,Int<300>>>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_LOCKUP_END>,InOutTrL<TrColorCycleX<IgnitionTime<0>>,TrInstant,AudioFlicker<Pulsing<RgbArg<OFF_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<OFF_COLOR_ARG,Rgb<191,255,255>>>,3000>,Mix<Int<10560>,Black,RgbArg<OFF_COLOR_ARG,Rgb<191,255,255>>>>>>>()},
Error: In file included from E:\Saber Stuff\Proffie6.5\ProffieOS\ProffieOS.ino:574:E: - Pastebin.com
