Hi all! Would love some help if possible. I’m getting an error compiling message. Could someone take a look at my config? If so, what’s the proper way to share my full config?
Thank you!
Thank you!
I’d be happy to take a look at your config, but you actually need to post it so I can see it. ![]()
Also post the error message you’re getting, and please let us know what version of ProffieOS you are using.
I’m getting: “Error compiling for board Proffieboard V2. exit status 1”
Config:
#define NUM_BLADES 2
#define VOLUME 2100
#define CLASH_THRESHOLD_G 2.0
#define FETT263_SWING_ON
#define FETT263_THRUST_ON
#define FETT263_NO_REPEAT_RANDOM
#define FETT263_BM_CLASH_DETECT 8
#define FETT263_MULTI_PHASE
#define IDLE_OFF_TIME 1 * 1 * 1000
{ "TFU2Trailer;common", "tracks/ShortDuelFates10db.wav",
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<24000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-1400>,Int<-100>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<2,72,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<250>>,TrWipeInX<RetractionTime<150>>,Black>>>(),
StylePtr<Layers<Pulsing<Black,RotateColorsX<Variation,Rgb<180,130,0>>,3000>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<White,Int<100>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrInstant,Layers<Black,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<130,130,180>>,Int<100>>,TrFade<1200>>,EFFECT_RETRACTION>>>()},
{ "FlexAwakensTFU;common", "tracks/UnleashedTrailer.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<100>,TrWipeIn<500>,Black>>>(),
{ "TheDarkTFU;common", "tracks/0Gm_Starkiller2.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<100>,TrWipeIn<500>,Black>>>(),
{ "TheSmuggler;common", "tracks/ValkorionTheme.wav",
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<255,255,0>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
{ "Vengeance;common", "tracks/MalgusTheme.wav",
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,Red>,Pulsing<RotateColorsX<Variation,Rgb<90,0,0>>,RotateColorsX<Variation,Red>,800>,RotateColorsX<Variation,Red>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<160,0,0>>>,TrDelay<30000>,RotateColorsX<Variation,Red>,TrFade<800>>,EFFECT_FORCE>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,150,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<Moccasin,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<200>,EFFECT_LOCKUP_BEGIN>,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<50>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,ResponsiveClashL<TransitionEffect<Rgb<255,150,0>,Moccasin,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<100>,TrWipeIn<500>,Black>>>(),
{ "SupremeBane;common", "tracks/Bane.wav",
{ 0, WS281XBladePtr<105, bladePin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
Button PowerButton(BUTTON_POWER, auxPin, "pow");
Button AuxButton(BUTTON_AUX, powerButtonPin, "aux");
This is only the final line of the error, and doesn’t say anything about why.
Try making the window at the bottom of the arduino app bigger to see the whole message.
And when you paste it here, use the “copy error messages” button. That will copy the whole thing, even if you can’t see it all.
Arduino: 1.8.19 (Mac OS X), Board: "Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from /Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/ProffieOS.ino:563:
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:114:1: error: 'SStylePtr' was not declared in this scope; did you mean 'StylePtr'?
114 | SStylePtr<Layers<Pulsing<Black,RotateColorsX<Variation,Rgb<180,130,0>>,3000>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<White,Int<100>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrInstant,Layers<Black,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<130,130,180>>,Int<100>>,TrFade<1200>>,EFFECT_RETRACTION>>>()},
| StylePtr
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:114:1102: error: expected primary-expression before '>' token
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:114:1104: error: expected primary-expression before ')' token
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:123:1: error: 'SStylePtr' was not declared in this scope; did you mean 'StylePtr'?
123 | SStylePtr<Layers<Pulsing<Black,RotateColorsX<Variation,Rgb<180,130,0>>,3000>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<White,Int<100>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrInstant,Layers<Black,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<130,130,180>>,Int<100>>,TrFade<1200>>,EFFECT_RETRACTION>>>()},
| StylePtr
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:123:1102: error: expected primary-expression before '>' token
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:123:1104: error: expected primary-expression before ')' token
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:133:1: error: 'SStylePtr' was not declared in this scope; did you mean 'StylePtr'?
133 | SStylePtr<Layers<Pulsing<Black,RotateColorsX<Variation,Rgb<180,130,0>>,3000>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AudioFlickerL<White>,TrInstant,TrFade<500>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<White,Int<100>>,TrFade<1200>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrInstant,Layers<Black,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_NEWFONT>,TransitionEffectL<TrConcat<TrInstant,RotateColorsX<Variation,White>,TrDelay<45000>,RotateColorsX<Variation,White>,TrFade<500>>,EFFECT_BOOT>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<RotateColorsX<Variation,Rgb<130,130,180>>,Int<100>>,TrFade<1200>>,EFFECT_RETRACTION>>>()},
| StylePtr
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:133:1102: error: expected primary-expression before '>' token
/Volumes/Personal/Lightsaber/1. Proffie/Proffie OS/Korbanth Rogue MK1/ProffieOS/config/Rogue_Renzo_mod1.h:133:1104: error: expected primary-expression before ')' token
In line 114 you have an SStylePtr when it should say StylePtr. Just take the first S.
Thank you, that worked in terms my board flashed correctly this time. I’m having another issue now. My saber doesn’t make sound when I turn it on. When off, and I hit the aux, it beeps (sounds like volume mode). But nothing else. Any idea what this could be?
Anything in the upper part of my config that would cause that?:
#define VOLUME 2100
OR bottom?:
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS >()
Button PowerButton(BUTTON_POWER, auxPin, “pow”);
Button AuxButton(BUTTON_AUX, powerButtonPin, “aux”);
Thanks!
Do you get a “font not found” message when you boot up?
Does it say anything interesting in the serial monitor?
No, I don’t get a “font not found”. I have a video, but don’t think I can upload.
What’s the serial monitor?
For video, you’ll need to upload to youtube, google photos, or some other such service, then post the link here.
Serial monitor: Serial Monitor · profezzorn/ProffieOS Wiki · GitHub
Thanks! Here is the video: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
The only sound is the beep when taping AUX, which I realize is changing the fonts. Can it be a hardware issue or damage to the board?
Shouldn’t that be somewhere between 0-1000?
Values up to 3000 can work, but for most speakers, somewhere around 2000 is reasonable.
No, it is making beep sounds, so clearly something is working. This is a software or config problem.
Please hook up the serial monitor and see what it says there, hopefully it will tell us what’s going on.
How do I hook it up to the serial monitor?
Thank you!
You just need the USB cable.
Thanks. Looks like I’m on OS6:
“Welcome to ProffieOS v6.7. Type ‘help’ for more info.”
That’s good! You’ve taken your first step into a larger world.
So now do stuff while it’s connected and observe what it says.
Pressing a button will generate an EVENT like pressed, held etc…
Which font is used, which sound is playing, what CANNOT be found should all be told in the messages.
This will help figure out what’s going on currently by comparing it to what is supposed to be going on normally.
Sorry, press what button and where? Also in this case, should I open up Arduino from the .ino file in my Proffie folder or just directly by clicking on the app after I connect my saber?
I like to open Arduino by double clicking ProffieOS.ino so that i’m sure I’m using the correct file.
In fact, I don’t ever even close Arduino once it’s open, just leave it dormant in the background.
By pushing buttons, I mean on the saber of course, while it’s connected with USB and Serial Monitor is open. Operate the saber and see what is reported as to what’s happening.
