Edit Mode only says 'Save'
Hey folks.
I’ve been trying to update one of my lightsabers with a fresh config, however I’m encountering a weird issue.
I believe I have Edit Mode set up correctly, but when I go to activate it on the saber it just plays the ‘save’ voice prompt and nothing else, then goes back to idle. I have tried replacing the common folder and reflashing a few times, but no joy.
I’m not sure if it’s a bug of some sort or just a basic error I have overlooked when doing the config, but I’ll include it here.
Thanks in advance for your help.
blademaster.h (144.0 KB)
It it only says “Save” that means Edit Mode is not enabled. My guess is you’re not uploading the config you attached.
You can check by introducing a typo. Go into your first preset and delete the “S” from the first “StylePtr<”, then save. Go upload that config, if it doesn’t give you an error you are uploading a different config than you’re editing.
If it does give an error, then replace the “S”, save and upload again and make sure it counts up from 0% to 100% and post the results from Arduino here.
Yeah, that was it. Thanks Fett. All working now
You’re welcome
