Ever since I had this Modded nerf blaster the one thing that has been a major bummer for me is that it has never had SFX.
MY QUESTION is has any one here ever tried to add a proffieboard to this type prop?
I know it will need a complete disassemble I have I have an rgb led 5mm that can do the blaster shots. I’ll need a kill switch.
But I got a spare board so…
EDIT:
I want to use an rgb led anode but i’m unsure how to configure the blaster_v3_config.h
I checked the configuration file which is as is.
#include "v3_config.h"
#define NUM_BLADES 2
#define VOLUME 2000
#define CLASH_THRESHOLD_G 1.0
#define ENABLE_BLASTER_AUTO
#define BLASTER_SHOTS_UNTIL_EMPTY 30
#define BLASTER_JAM_PERCENTAGE 3
#include "../props/blaster.h"
// Default basic blast color with red audio flicker on blast
{ "_blstr1", "tracks/mars.wav",
StylePtr<Lockup<BlastFadeout<BlastFadeout<Black,AudioFlicker<Black,Red>,250,EFFECT_FIRE>,AudioFlicker<Black,Blue>,1500,EFFECT_STUN>,AudioFlicker<Black,Red>>>(),
{ "bank1", "tracks/track01.wav",
{ "bank2", "tracks/track02.wav"
{ "bank3", "tracks/track02.wav"
{ "bank4", "tracks/track02.wav"
{ "bank5", "tracks/track02.wav"
{ "bank6", "tracks/track02.wav"
{ "extra", "tracks/track02.wav"
{ 0, SimpleBladePtr<CH1LED, CH2LED, CH3LED, NoLED, bladePowerPin4, bladePowerPin5, bladePowerPin6, -1>()
, CONFIGARRAY(presets) },
I’m using a 5mm anode rgb or is it just a matter of using the default and wiring the rgb where the neopixel connectors would go?
