Hello everyone, so the title basically says it all. I went ahead and changed the color from blue to orange via hitting the power button four times and then twisting my saber. Then, when I turn off my saber and turn it back on, it now stays orange. Beforehand, whenever I would change the color and turn it off, for example, blue to orange, it would ignite blue again. How do I revert it back to what it was beforehand? I cam also coming from the Lightsaber Discord and Ryrog told me to seek someone by the name of Fredrik out.
Theory1Button.h (44.0 KB)
This is my config file by the way that I am using in ProffieConfig
Right. He doesn’t have SAVE_COLOR_CHANGE nor ENABLE_ALL_EDIT_OPTIONS enabled, and he says he has successfully uploaded the config, but the behavior persists.
I pointed him here in case there’s side effects of the other defines I’m not aware of.
Remove this define, it includes SAVE_COLOR_CHANGE automatically.
#define SAVE_STATE
Where do you see that in his config? Am I blind?
I don’t see it either
ProffieConfig won’t output SAVE_STATE unless it’s explicitly added (if have to check if it even does then), and prefers the expansion otherwise.
Anyways, CTRL+F says it’s not there, and my eyeballs can’t find it either ![]()
I don’t believe that’s the issue.
Hmm, apparently someone else must have asked a question with the same config name at some point (that’s why I prefer pastebin.com when viewing from a phone).
Are you sure it’s saving the color? Open presets.ini and see if there’s a “variation” saved on the preset.
Where do I find presets.ini?
On your SD card.
It will be in the blade_in folder.
