Asking for help with 1st time setup
reformat it using SD Memory Card Formatter for Windows/Mac | SD Association
Be careful using Mass Storage option if you are.
Always eject (unmount) the SD from the computer before disconnecting or uploading to the Proffieboard.
ya. i flashed, moment it stopped: font directory not found x2 sd card not foUNDDDDDDDD -_- i swear if this has been the root of all my problems ill be mad. lol sd card for this needs to be formatted fat 32?
i cant remember where to go to find that info
Correct.
I recommend using the SD association formatter.
sd card reformatted. now im getting font directory not found on some that were working before. this is the new styles i added. i can try renaming, it was mentioned earlier, i just dont know if thats my problem or what. here is the config.
GrandMasterLuke3.h (68.2 KB)
i renamed the files to reflect the blade styles. obi_ep3. now its rguecmndr i cant get to work. i think im on the right track, may replace that font, put highlander back on and slowly add others if i can get them to work. i just pick a blade style, havent changed settings. i did on the base config i frankenstiened with everyones help. some button controls i cant get to work like edit mode. battery. but always force push works for sure lol. i made my sensitivity levels too low now. -_- i believe i got it. its just a matter of figuring this mistake out, getting all the fonts on. then start deep diving into making crazy styles. i am happy with where i am at with my saber so far.
Make sure you added the Voice Prompts in “common” on the SD card, this is typically what users miss in set up. Without common and voice prompts certain features in my prop cannot run properly.
i have the voice prompts. My laptop died so i cant post my current config. Though all that has changed is fonts. I think ive turned of stap or thrust. I dont have those effects in battle mode.
here is my config as it stands. i have added the styles. can go in and out of edit mode. inside and out of battle mode no thrust or stab effects play, like disabled idk how. im skipping over a setting or slider and idk which it is. music also doesnt play. always force push. which i forget to turn that off so thats on me. battlemode clash. i have none. unless i smack my head they play lol.
is it in style edit or os config. or a mixture. i know the problem i just cant find the settings i need to tweak. XD anyways im going to enjoy and figure out what i have atm :smiley:
GrandMasterLuke4.h (95.2 KB)
Sounds like you need to review the controls in my prop, it’s all covered in this page.
(Note: if you use the Config Tool it will walk you through the selections for defines and output a completely custom Button/Control List based on everything you enabled and disabled to make it even easier).
“thrust” is only an ignition option, there’s no “effects”
Stab effects are controlled by the style
I don’t really understand the rest TBH, so review the controls and then try to explain what you’re trying to do and what’s not working based on using the correct controls.
alright now i know which is which. in battle mode you can swing saber, stop and it play clash or if stab, stab plays. im getting no stab on sound or blade. its as if its not being read. um to reword:
i initiate a clash i get clash. lockup locks up. stab. doesnt stab. the files are in the folders. ohhh controlled by style. so i need to take another delve into editor. fine tune there for awhile i take it? style editor. ive probly not clicked or have a slider to high.
on a lighter note as a joke with this: did i inadvertantly build a disney saber? lol explains why stabs dont kill. lightsaber stab dont work XD
Stab is a linear motion with a clash at the end, so stab the tip of your blade into something. Stab can required a little more force than clash to be detected depending on your chassis and saber in general. Sometimes if you have pogo pins for connecting they can absorb some of the impact.
In Battle Mode there is no Stab capability, it is replaced with Melt or Drag (refer to controls).
alright. maybe i was triggering another effect and mistook for melt. now to fix my clashing. i think i found were i went wrong thank you for your help boss.
yeah, i found what i was looking for. its a highlighted in red box labeled stab summon effect. i keep setting it to none. moments that make your brain skip like a very old cd. -_- change that setting. guess what. saber stabs now. well at least one font will. the others i’ll keep in “safety” for now. lol i apologize im having too much fun with this. like a ewok in a vat of berries i guess. i lost the analogy.
is there a sweet spot for clash settings? just curious.
Varies by saber and user. If you’re getting false clashes there are additional defines available.
heres current version of my config.
GrandMasterLuke4.h (103.5 KB)
so presets dont work. i have copy pasted fonts into new folders, like calkestis. named different and reflected everywhere it needs to. but on blade dont light up. the other lights up sound dont play. training saber should be only dark blade i have. i have not clicked the sound icon to enable picking specific font sounds for preons. first thing i tried. i might just apply the multiples to complete different fonts. i have to head out for a bit. thanks for the help.
i also got the clash issue sorted. thank you.
I have no idea what you’re asking or trying to do.
im an idiot. i just need to refresh my page when using the style library page.
Still not following. Try to specify the issue you’re having and the preset that’s having it, otherwise I can’t really help.
