Asking for help programming servos for my wedding lightsaber build
A post was split to a new topic: Blaster Servo Help
Is this an analog or digital servo? 50Hz PWM?
Digital aparently: Amazon.com: 4-Pack Servo Motor MG995 Control Angle180 Metal Gear Servo 13KG Digital High Speed Torque Servo Motor for DIY Smart Robot Toys RC Toy Car Model Helicopter RC Boat : Toys & Games
I also tried tried one of these: Amazon.com: Sg90 9g Micro Servo Motor, Miuzei Mini Small Servos Motor Kit Metal Gear for Arduino RC Car Airplane Robot (10) : Toys & Games which is analog and also had no jitter.
yep
Could you let me know how your servo is wired. My first goal will be to replicate your positive results.
Thank you. As always, I appreciate your knowledge and help!
Servo+ ↔ BATT+
Servo- ↔ BATT-/GND
Servo Data ↔ Free3
It might be worth mentioning that the other person who had jitter tried a different board and the jitter went away:
Returning to this, It’s possible that this is my issue as well. the board I am struggling with this on is from aliexpress.
I’ll purchase another one, where would you recommend getting it from? I see tritium and TCCS are out of stock at the moment.
The Saber Armory/KR Sabers would be my next suggestion.
This would be my recommendation as well.
After a lot of fiddling and stuff,. it does seem to have been the board. I now have a working setup with another board. Thank you SO MUCH for all your help! Now it’s time to actually put all this in a lightsaber
I’m having the same issues. Servo starts twitching and then goes into a full on spin. I’ve gone through seven KR Saber proffie boards and 3 from Saberbay. I’ve swapped out 8 servos. I did get two blasters to work.
Makes me wonder what the difference is that makes it work in some cases…
