Hi all, i’ve been updating some of my bladestyles and it was all going well until it started to show a bunch of error messages, so i cant really found out what the problem is.
The error message is here:
c:/users/tobis/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\tobis\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2’ not declared
c:/users/tobis/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:\Users\tobis\AppData\Local\Temp\arduino_build_637600/ProffieOS.ino.elf section .text' will not fit in region FLASH’
c:/users/tobis/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: region `FLASH’ overflowed by 3408 bytes
Using library Wire at version 1.0 in folder: C:\Users\tobis\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0\libraries\Wire
Thank you
