Hi, I’m using proffieOS 6.7 and arduino ide 2.0.3 and getting the following error message:
In file included from C:\Program Files\Arduino IDE\ProffieOS\ProffieOS.ino:218:0:
C:\Program Files\Arduino IDE\ProffieOS\common\common.h:9:24: error: missing binary operator before token "("
#if __has_cpp_attribute(no_unique_address)
Compilation error: missing binary operator before token "("
My config file is the one I found on my sd card for the eco cc desert wanderer saber:
#define NUM_BLADES 2
#define VOLUME 2500
#define CLASH_THRESHOLD_G 3.5
#define FETT263_TWIST_ON
#define FETT263_TWIST_ON_NO_BA
{ "Ben", "tracks/Ben.wav",
//main blade
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,
AlphaL<RotateColorsX<Variation,Blue>,SwingSpeed<600>>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL<Red>,
ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<10000>,Int<30000>>,Int<10000>,Int<20000>>,
TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<White>,TrFade<800>>,EFFECT_IGNITION>,
InOutTrL<TrWipe<250>,TrWipeIn<300>>>>(),
//crystal pixel
StylePtr<Layers<
LockupTrL<BrownNoiseFlickerL<White,Int<200>>,TrConcat<TrInstant,White,TrFade<300>>,TrFade<300>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<AlphaL<Red,Int<0>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,
BlastL<White>,
SimpleClashL<White>,
InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,10>>,3000>>>>(),
{ "OB4_V1", "tracks/OB4_V1.wav",
//main blade
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Rgb16<0,30086,65535>>,RotateColorsX<Variation,Rgb<0,0,128>>>,
AlphaL<RotateColorsX<Variation,DeepSkyBlue>,SwingSpeed<600>>,
LockupTrL<Layers<
InOutTrL<TrWipe<400>,TrWipeIn<500>>>>(),
//crystal pixel
StylePtr<Layers<
BlastL<White>,
InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Rgb16<0,30086,65535>>,RotateColorsX<Variation,Rgb<0,4,10>>,3000>>>>(),
{ "Cantina", "tracks/Cantina.wav",
//main blade
StylePtr<Layers<
LockupTrL<Layers<
InOutTrL<TrWipe<300>,TrWipeIn<500>>>>(),
//crystal pixel
StylePtr<Layers<
BlastL<White>,
{ "DeathStar", "tracks/DeathStar.wav",
//main blade
StylePtr<Layers<
LockupTrL<Layers<
InOutTrL<TrWipe<600>,TrWipeIn<700>>>>(),
//crystal pixel
StylePtr<Layers<
BlastL<White>,
{ "Rebels", "tracks/Rebels.wav",
//main blade
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Rgb16<23182,38402,64971>>,RotateColorsX<Variation,Blue>>,
AlphaL<RotateColorsX<Variation,Rgb16<23182,38402,64971>>,SwingSpeed<600>>,
LockupTrL<Layers<
//crystal pixel
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Rgb16<23182,38402,64971>>,RotateColorsX<Variation,Rgb<0,0,128>>>,
BlastL<White>,
InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Rgb16<23182,38402,64971>>,RotateColorsX<Variation,Rgb<0,4,10>>,3000>>>>(),
{ "Battery", "tracks/Battery.wav",
//main blade
&style_charging,
//crystal pixel
//main blade
//crystal pixel
WS281XBladePtr<2, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
CONFIGARRAY(presets) },
Any help is apreciated!!
Thanks
Arne
