Good afternoon,
I am new to Proffie. I am trying to program a v3.9 and during the Arduino verification process it returned with this error message -
"Compilation error" '$BLADES$' was not declared in this scope" I am setting up a cross-guard with lit PCB’s.
In using Fett263 config program the end coding is as follows:
WS281XBladePtr<144, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
SubBladeWithStride(0, 15, 2, WS281XBladePtr<16, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >()),
WS281XBladePtr<3, blade6Pin, Color8::GRB, PowerPINS<bladePowerPin4> >()
, CONFIGARRAY(presets) },
{ NO_BLADE, $BLADES$ CONFIGARRAY(no_blade_presets), "nb_save" }
Here is my question: Should I remove $BLADES$, if not how can I correct? The Proffie manual does not show $BLADES$ in the section for “no blade” configuration.
There are “no_blade” presets within the body of the file.
Thank you for your help.
