I’m adding all the proper stuff to the greyscale fonts and I got to Analog, and upon adding the ‘Glitch On’ ignition it generates the following error.
Mult:Expected FUNCTION but got BendTimePowXClass[id = 9463892551] for argument 1 (FUNCTION1)
Without the ignition effect, it works perfectly fine.
Edit: Just the glitch on ignition doesn’t work.
There’s a specific thread for reporting errors and bugs for my OS7 library, it’s linked right at the top of the site with a note. The library is in Beta so I expect errors to pop up, just post in the thread so I can keep track of everything and document fixes. I’ll have a look when I get a chance.
I am kicking off the Early Access Beta for OS7 Style Library, this is for all Early Access or higher patrons ($10).
This library has been a ton of work and a long time coming, as such the initial launch is an “Early Access Beta” for my current Patreon patrons as a “Thank you” for the support. There are so many new features and interfaces I can’t list them all AND there are many more to come in future Phases. OS7 introduced so many new possibilities that I have a really long backlog of additions. Support for the new features required many new interfaces and new ways of doing things. My goal with the library was to make the UI as simple as possible while generating very complex styles. Many of the new features also introduce brand new concepts and approaches so support for these took a long time to develop and some of the features had to be moved to later Phases due to time needed to build everything to support.
I will run the “Early Access Beta” for at least 6 weeks with my Patrons (possibly longer depending on how many issues pop up). I’ve done a lot of testing and addressed all of the bugs I have encountered thus far, but there are 1000s of new features and combinations so I fully expect more to pop up. Once Phase 1 is “stable” I will begin working on my Phase 2 additions. Once Phase 2 is ready for testing I will move Phase 1 to public access and Phase 2 will be “Early Access” and this will continue through all necessary Phases, probably 4 or 5 depending on progress.
If you don’t see a style or a feature that has been previewed for OS7 trust me, it’s on the list along with hundreds of other things I haven’t even shown yet I am just one person and I build this in my free time so it will take me a while to get everything built and tested. Please don’t fill this thread with requests, some features simply require more work and updates than others so I am building them into Phases.
As you build and test these new styles, keep in mind that I’ve spent countless hours developing and testing these new features and tools. If you’re posting or showing these off on social media please be sure to mention me (Fett263) and the library and encourage more users to become Patrons if they want to get these capabilities. I put a lot of time into making these styles and features available for Proffieboard and I appreciate any publicity to get more users to contribute for my time and effort.
Phase 1 Additions:
All new Color support - select Color Ar…
