Would anyone know the correct wiring sequence for this component? This is the board at the top of the unit that has the push pins on top that meet the blade.
This the pogo pin board for reference. The current wiring was my attempt to troubleshoot but not sure of correct wiring sequence. Any help would be appreciated.
I’ve never seen a pogo connector quite like that.
What does the top pin configuration look like? And the base of the blade?
What issue were you having?
Whatever it is, the power wires gauge is too small.
