Wiring Diagram checks
I have a bunch of parts laying around. Enough to do these installs. I am an endless planner, so I would like any feedback about these installs… They are all pretty straight forward, imo.
This one is a Graflex with removable chassis, but it will mostly be locked in.
This is a skinny neck OWK.
This Reys Scavenger.
All are wired in “V2” configuration mirroring the hilt pcb and blade.
I have been working on the chassis files in fusion, With the exception of the scavenger, I have an eco chassis for that. I also have a blaster install planned, but I will start a new topic for that, as it differs from a saber.
Let me know what you think.
The switches attached to the rotary connector are cool. Which connector is that, if you don’t mind me asking?
Otherwise, without seeing your configs there’s no way to be absolutely certain. But they read well and seem fine as long as the code matches up :slight_smile: Data runs look good. Power is fine. Just not sure about the swtiches attached to the rotary connector, as that’s new to me.
Very nice diagrams!
Oh, and do you need a resistor for the clamp card data, or is that built in?
Oh, its these. Pretty neat, but I have yet to use it.
Its designed for just such a case.
Yes, I did consider this, but the images of the card indicate a built in data resistor.
As for the config, I have yet to make one… :smile:
Cool. Well then you can work off of these and it’ll be easy.
I’ve seen those connectors but never used them either. I’m curious but they give me alignment anxiety :sweat_smile:
The wire gauges all look good?
You don’t need 2x 22awg wires for the blade + & -, one for each is sufficient and just bridge the LED 2/3 pad. You can also use 30awg for speakers and data lines.
